![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
( Let's try this again, see if the pic will come through this time)
Hello Everyone,
I wanted to wait to do my first image post with something good..but this
is all I Got now..
I didn't do the "cliche" ball posts or anything like that.. I was
watching my daughter color one day and though.. I Bet I could do one of
those crayons.
There are a few things missing fromt the crayon, I know.
Ie: The black circle behind "crayola" and the Wavy Border at the top and
bottom.
But I'm a newbie with Pov still.. I know a few things, but not alot, so this
was the best I could do wiht my limited knowledge....
Comments would be appreciated..
Stats:
Scene contains 3 frame level objects; 0 infinite.
Statistics for C:\Program Files\POV-Ray for Windows v3.5\mine\crayon.pov,
Resolution 512 x 384
Pixels: 197770 Samples: 1774730 Smpls/Pxl: 8.97
Rays: 1803556 Saved: 0 Max Level: 4/5
Ray->Shape Intersection Tests Succeeded Percentage
Cone/Cylinder 1024425 302826 29.56
Bounding Box 1875348 870200 46.40
Light Buffer 880702 675023 76.65
Vista Buffer 3385350 2157491 63.73
Calls to Noise: 0 Calls to DNoise: 10
Shadow Ray Tests: 456419 Succeeded: 2212
Radiosity samples calculated: 67 (0.04 percent)
Radiosity samples reused: 184010
Smallest Alloc: 25 bytes Largest: 12056
Peak memory used: 179750 bytes
Time For Trace: 0 hours 2 minutes 2.0 seconds (122 seconds)
Total Time: 0 hours 2 minutes 2.0 seconds (122 seconds)
POV-Ray finished
Download 'Crayola1.jpg' (27 KB)
Preview of image 'Crayola1.jpg'
![Crayola1.jpg](/povray.binaries.images/attachment/%3C3cedb450%40news.povray.org%3E/Crayola1.jpg?ttop=430894&toff=8750&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Well, radiosity probably isn't doing too much, since you have only a single
concave object.
The flaws I see are that the paper needs to be a separate object (give it
some thickness) and a lot less shiney. Give both the paper and the crayon a
small normal map.
- Slime
[ http://www.slimeland.com/ ]
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> bottom.
An image_map might be the way to go there. Even pov 'purists' use image_maps :)
~ Samuel Benge
sbe### [at] caltel com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
nonono!
You do have to get thru reflective ball upon checkered plane! ;-)
Well be carefull with yourself, you show already the YKYBRTTL symptoms as
"hey nice object, how could I render it".
I agree with other replies: need a separate paper with a bitmap, a
surrounding (why not a reflective ball upon... nooo nooo don't slap meee
noo)
But a nice 1st post pict :-)
Marc
3cedb450@news.povray.org...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
The label is another object it's an open cylinder. :)
I will play with the normal map and see what I Get.. yeah radiosity made it
brigther.. I Rendered it with it just to see if there was a difference.. :)
"Slime" <slm### [at] slimeland com> wrote in message
news:3cedc3b9@news.povray.org...
single
> concave object.
a
> small normal map.
> - Slime
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yeah I 've used image maps too.. I was just seeing "How far I Could go"
"Samuel Benge" <sbe### [at] caltel com> wrote in message
news:3CEDD15F.C1272E60@caltel.com...
> > bottom.
image_maps :)
> ~ Samuel Benge
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
As stated, the paper is seperate, it's just "close" to the crayon.. A ball
huh.. Hrmmmmmm..
Yes I have the YKYBRTTL Syndrome.. :) I know.. Everything I See I say... I
could model that.. But then say... How would I model that..
And don't get around too it..
"Marc Jacquier" <jac### [at] wanadoo fr> wrote in message
news:3cedec71$1@news.povray.org...
> nonono!
> noo)
> Marc
news:
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I don't know Maps well enough..so I kinda used one out of the DOC Tutorial
and modified it to look okay..
Added a normal map and some turbulence to the paper..
Took out the RAdiosity and it put the Darkness back to where I remember it..
And I added something just for Marc.. ;)
I originall rotated the camera, so that's why the plane is funny.. :) But I
ThoughtI Would make you all dizzy.. :)
"Dave Bates {[Norman]}" <dab### [at] msn com> wrote in message
news:3cedb450@news.povray.org...
> Hello Everyone,
this
> is all I Got now..
> those crayons.
> bottom.
this
> Stats:
> POV-Ray finished
Download 'Crayon2.jpg' (30 KB)
Preview of image 'Crayon2.jpg'
![Crayon2.jpg](/povray.binaries.images/attachment/%3C3cee37d9%40news.povray.org%3E/Crayon2.jpg?ttop=430894&toff=8750&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Well okay..
Here it is.. my 3rd incarnation of this... Of course.. Now I used an image
map ( that I made myself ) on the label, played with the normal map a little
.. but everything else is the same...
news:3cedac1d$1@news.povray.org...
> Hello Everyone,
this
> is all I Got now..
> those crayons.
> bottom.
this
Download 'Crayon3.jpg' (48 KB)
Preview of image 'Crayon3.jpg'
![Crayon3.jpg](/povray.binaries.images/attachment/%3C3ceef432%40news.povray.org%3E/Crayon3.jpg?ttop=430894&toff=8750&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Well, well well, Okay, Now you are free to model anything you want ;-)
But why did you put Rad off? Did you try it on?
Marc
3cee37d9@news.povray.org...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
