POV-Ray : Newsgroups : povray.binaries.images : Re: srry for the large file but i need help Server Time
24 Jun 2026 23:26:33 EDT (-0400)
  Re: srry for the large file but i need help (Message 1 to 5 of 5)
Subject: Re: srry for the large file but i need help
Date: 17 May 2002 17:48:41
Message: <3ce57ab9@news.povray.org>
We'll probably need the source to help you.
I suspect you have some sort of slightly blue object which is being
reflected over and over again, each time picking up a little more blue. But
I really can't be sure.
Sometimes it helps to render with +SP64 in the command line to get a general
idea of what your picture will look like. Try it and you'll see what it does
 - Slime
[ http://www.slimeland.com/ ]
Date: 17 May 2002 18:24:16
Message: <3ce58310@news.povray.org>
While I am usually the last one to be bothered by this kind of thing, I
thought I might just offer a little help with the file size issue. I've
attached three jpg versions of these images that in total are less than the
file size of one of the images you posted. I agree that these images are not
too JPG friendly, you need to compress them a lot of save file size, and
this compression does lead to bluring, but it does work. Perhaps you could
post the PNG versions on the web somewhere and post a link to them. If these
versions are acceptable then you might want to cancel your other post. Sorry
for the nagging:-)
Download 'Mirriors3.jpg' (199 KB) Download 'Mirriors.jpg' (52 KB) Download 'Mirriors2.jpg' (100 KB)
Preview of image 'Mirriors3.jpg'
Preview of image 'Mirriors.jpg'
Preview of image 'Mirriors2.jpg'
Date: 17 May 2002 20:13:14
Message: <3ce59c9a$1@news.povray.org>
> >... versions are acceptable then you might want to cancel your other
post.
> Not me, but how does one cancel a post?
> I use OE, but often use news.povray.org as well
In OE highlight a message that you have posted and want to cancel, then go
to Message/Cancel Message. This will delete the post on the server, but you
will still see the post because OE has already downloaded the post to your
HD.
Note: Of course you can only cancel your own posts.
Date: 18 May 2002 02:15:29
Message: <slrnaeb6t5.ri2.steve@zeropps.org.uk>
On Fri, 17 May 2002 18:32:30 -0400, Lieut_Data wrote:
>>... versions are acceptable then you might want to cancel your other post.
I think you select/hilighte the message and then select cancel message from
the messages menu, you may also get this option by right clicking on the
message and selecting the option from the context menu that appers.
I don't use OE, but I think those guesses should help.  BTW you can only
cancel your own messages.
sphere{z*5,1pigment{rgb.5}finish{reflection.3specular.5}}box{<-50,-3,-50>
<50,-2,50>pigment{checker/*\__\\__/  * \_\\__*/scale 2}finish{ambient.7}}
light_source/*__\\__\\__\\__\\__\(    ~ )\__\\__\\__\\__\\*/{<2,5,1>*4,1}
/*\\__\\__\\__\\__\\__\\__\\__\\__\~  -/__\\__\\__\\__\\__\\*//* Steve */
Date: 18 May 2002 08:24:13
Message: <3ce647ed@news.povray.org>
Yay!
Thanks guys
"Lieut_Data" <lIe### [at] yahOOcom> wrote in message
news:3ce584ec@news.povray.org...
post.
