POV-Ray : Newsgroups : povray.binaries.images : Technology test pictures: Room Server Time
18 Jul 2026 07:31:31 EDT (-0400)
  Technology test pictures: Room (Message 11 to 13 of 13)
Subject: Re: Technology test pictures: Room
Date: 16 May 2002 07:13:52
Message: <Xns921087170CAC1seed7@povray.org>
in news:3ce2d9ab$1@news.povray.org Martin Hellwig wrote:
> The export function in our programm writes equal but
> format independent information to the POVRay scene
> file. So any format can be transformed to this form.
> Hope this helps.
Thanks,
I hoped for something like:
light_source {
    	<20,30,-10>
    	elumdat "BE1017.ldt"
    	rgb <1,0.9,0.8>
Ingo
Date: 16 May 2002 08:29:45
Message: <3ce3a639$1@news.povray.org>
> light_source {
>     <20,30,-10>
>     rgb <1,0.9,0.8>
here a fragment of a generated povray source file:
light_source
   <0,0,0>
  color <1,1,1>
  // IMax = 18076
  ldt_data
    // number of C and G angles, total flux of luminaire
    36, 36, 2200,
    // fully expanded ldt table
    18.076,    1.454,    0.11,    0.045,    0.063,    0.003,    0.003,
0.002,    0.002,    0.0002,    0.0002,    0.0002,    0.0002,    0.0002,
0.0002,    0.0002,    0.0002,    0.0002,    0.0002,    0.0002,    0.0002,
0.0002,
    [ ........34 rows deleted here]
    16.076,    1.354,    0.10,    0.045,    0.063,    0.003,    0.003,
0.0002
  looks_like
    //geometry of luminaire here...
  rotate <0, -90, 0>
  translate <0.475,3,1.31976>
  // move the ldt without the geometry (was needed for some special
luminaires)
  ldt_translate <0,-0.125,0>
All values between the given angles are linear interpolated, and because
they are polar
coordinates, this is more than enough for smooth results.
so for example
ldt_data
1,1, 100,
1
would be a perfect point light again.
Since the format is close to the existing formats, it would be easy to write
a converter
for example from IES or EULUMDAT .
Martin Hellwig
DIAL GmbH
http://www.dial.de
Date: 16 May 2002 10:14:50
Message: <Xns9210A5C54E4F1seed7@povray.org>
> to write a converter for example from IES or EULUMDAT .
Interesting patch, especialy in combination with such an convertor.
Thanks,
Ingo
