POV-Ray : Newsgroups : povray.binaries.images : A simple rad. test. (+149k) Server Time
26 Mar 2026 22:30:43 EDT (-0400)
  A simple rad. test. (+149k) (Message 1 to 8 of 8)
Subject: A simple rad. test. (+149k)
Date: 8 May 2002 20:19:37
Message: <3cd9c099@news.povray.org>
This is no big deal.
I'm experimenting with radiosity (still learning it) and come up with this
image.
No lights, just a "sky sphere" with ambient 1 and the radiosity settings of
the "high quality" example from the advanced tutorial.
Render time 4 hours 34 minutes  50.0 seconds (16490 seconds) on my PIII 500,
196 Mb
I've rendered it with the default AA settings (0.3) but I'm not satisfied
with the result.
In some places the texture lines are jagged or incomplete, and the left side
of the sphere is a mess.
Can it be from the radiosity?
I would like some advice on how to correct those problems, because as these
are my first trys at radiosity Im not quite shure what to try next.
Sorry for the size of the file but the smaller ones have a REAL lousy
quality.
Best regards.
Download 'RadTest.jpg' (149 KB)
Preview of image 'RadTest.jpg'
Subject: Re: A simple rad. test. (+149k)
Date: 8 May 2002 23:23:09
Message: <3cd9eb9d@news.povray.org>
these
Radiosity is a tricky beast that you never really master, you always find
yourself tweaking it for the particular scene you are on and you can't
expect the same results twice on different scenes. I'm not quite sure what
you are testing here but the textures you chose are not the best for showing
off radiosity. Most radiosity tests feature scenes with light/pastel or dull
mat textures. Reflection can hide some of the effect of radiosity, though I
do notice it in your scene a little.
Date: 9 May 2002 04:09:54
Message: <3cda2ed2$1@news.povray.org>
> with the result.
side
the best you can do is set AA threshold to 0.0 and you'll see this is almost
a magic zero. Focal_Blur is the alternative but won't be faster. Either the
left side of the sphere needs to be out of focus, or your blur needs
variance 0.0 which is similar to AA 0.0
Rendering in double resolution or so, won't help... My suggestion will be:
+AM2 +A0.0 +R2 -J
Hugo
Date: 9 May 2002 08:56:33
Message: <3CDA721E.A3091134@luxlab.com>
Copy & paste from newusers:
  This was rendered with +a0.0 +r9. http://luxlab.com/tmp/aa.png
  Rendered at 500% resolution +a0.3 +r3, Gaussian blur 2.5 pixels in
  Photoshop and resampled (nearest-neighbour) to final size.
  http://luxlab.com/tmp/aa_hq.png
  The most important part is the Gaussian blur. I used 500% resolution
  just to get those very thin lines. For normal a scene 200% to 300% and
  1 to 1.5 pixel blur radius should be enough. The 50% blur radius seemed
  to be the minimum required to prevent visible aliasing. The image will
  look soft. Sharpening filter will just bring back the the jagged edges.
  It's a delicate balance between artefact free and sharp image.
I feel the Gaussian filter produces optimal anti-aliasing. It's so good
it's banned from IRTC :D The example image has maximum contrast. When
local contrast in image is lower less filtering is needed. The default
POV-Ray aa is enough for low local contrast.
This scene and camera position are less than optimal for radiosity
demonstration :) Try lowering the camera near a corner. The contrast
ratio in this scene is naturally low. If you don't wan't to post-process
drop assumed_gamma or use higher value as a kludge to increase contrast.
_____________
Kari Kivisalo
Date: 9 May 2002 18:26:06
Message: <3cdaf77e$1@news.povray.org>
"Thomas Lake" <tla### [at] REMOVE-THISshawca> wrote in message
news:3cd9eb9d@news.povray.org...
> .... I'm not quite sure what
showing
dull
I
Well, I was just trying radiosity to see if I could achieve a more realistic
look in that scene, and to learn too :))
Thnx for your comment.
Best regards.
Subject: Re: A simple rad. test. (+149k) (1/2)
Date: 9 May 2002 18:36:45
Message: <3cdaf9fd$1@news.povray.org>
I've tried the setting you suggest and they worked just fine :)))
Thank you very much.
I've never tried different settings for AA (never needed, cause I've always
rendered simple test scenes :P) so your help was very welcome.
I enclose in the next post the resulting pic (without reflections, cause
they took LOTSA resources), just to show the difference.
almost
the
> +AM2 +A0.0 +R2 -J
> Regards,
> Hugo
Subject: Re: A simple rad. test. (+149k) (2/2) [+138k]
Date: 9 May 2002 18:38:54
Message: <3cdafa7e@news.povray.org>
Here is the pic.
No reflections this time :))
Download 'RadTest2.jpg' (138 KB)
Preview of image 'RadTest2.jpg'
Date: 9 May 2002 18:47:01
Message: <3cdafc65$1@news.povray.org>
"Kari Kivisalo" <pro### [at] luxlabcom> wrote in message
news:3CDA721E.A3091134@luxlab.com...
I saw the pics and I am impressed. This method really achieve great results.
But if I would render this again at 500% or even 200% resolution would take
an ETERNITY for such a simple scene (with all those reflections) and I would
abort the render for sure, cause I want the renders to be as fast as they
can so I can try more things he he he :))
I know, but I was just testing, and trying to get a more "real" look, not a
tipical radiosity scene :)
Best regards
