Hi, this is just my three day modeling and two day rendering test, it's not
perfect, but I won't render it again for awhile.
"Rendering time 2d 19h 31m 03s."
Download 'vesilasi.jpg' (36 KB)
Preview of image 'vesilasi.jpg'
Hm. How about stats like photon-spacing, radiosity-values,
max_trace_level...?
Triangles in scene, or blob? Isosurface? Image-maps?
Tim Nikias
Email: Tim### [at] gmx de
How about the source? I'm especially interested in your glass material
settings.
John
"Tim Nikias" <tim### [at] gmx de> wrote in message
news:3CD938DE.44E0E9C3@gmx.de...
> max_trace_level...?
Only normal primitives with CSG and the superellipsoids on the back wall and
wooden panels below the table. The room is a small closed room with one
CSG-carved window that you can see in the reflection. Small bubbles in the
water are randomly placed on the glass surface. Lighting is a combination of
a bluish sky_sphere and a bright yellowish area_light.
Photons were used only on the glass, water and table with default settings
and a count of 1000000 (one million). Radiosity with the default settings
except count 100, error_bound 1.0 and recursion_limit 5. I got some black
areas on the glass as I began with this scene, so I upped the
max_trace_level to 100 with no notable speed decrease.
"jkb" <joh### [at] hotmail com> wrote in message
news:3cd93a7b@news.povray.org...
> settings.
Basic glass.inc definitions and the ones I used were:
pigment { Col_Glass_Clear }
finish { F_Glass8 }
interior { I_Glass1 }
The source will be posted to p.b.s-f.
> rendering test, it's not perfect, but I won't render
Bah, it's a photo.
Tim Cook
http://personal.lig.bellsouth.net/lig/z/9/z993126
Version: 3.12
I enhanced/modified the image a little using Photoshop, see if you like it!
I am also going to try rendering it larger on a 1 GHz machine over the
entire weekend and performing the same corrections..
Mike
Download 'vesilasi-modified.jpg' (182 KB)
Preview of image 'vesilasi-modified.jpg'
"Michael Goldshteyn" <mik### [at] wwa com> wrote in message
news:3cda8a57@news.povray.org...
it!
Very nice! I especially like the bluish water/liquid. It makes the image
sharper. Maybe I should've toned down the yellow light a little and used a
little bit less focal blur. Waiting to see your render.
Here is what I did:
I auto-leveled/color corrected it, which removed the slightly "yellowish"
cast. Then, I selected just the glass. I did a hue adjustment on the glass
selection to make it more natural looking. Then I slightly desaturated the
rest of the scene (i.e. scene minus glass) to make the glass stand out more.
Finally, I applied an unsharp-mask to sharpen the entire image ever so
slightly.
What I did not do, but will for the larger scene:
The photon effects need a hue adjustment, as well, to be more inline with
the new hue of the glass. I am wondering if all of this could be made easier
by simply changing the glass color to a shade of blue, but in any case it
did come out looking nice, if I do say so myself :) .
Mike
message news:3cda8b6c$1@news.povray.org...
> it!
I forgot to ask, btw, what +a +r settings did you use for the trace you
posted?
Thanks,
Mike
> it!
