POV-Ray : Newsgroups : povray.binaries.images : Athene - radiosity/smoothing/dynamic range compression (78kB) Server Time
15 Sep 2025 09:55:37 EDT (-0400)
  Athene - radiosity/smoothing/dynamic range compression (78kB) (Message 1 to 8 of 8)
Subject: Athene - radiosity/smoothing/dynamic range compression (78kB)
Date: 1 May 2002 01:41:05
Message: <3ccf7ff1@news.povray.org>
Kari I've been experimenting with your suggestions on the two-pass radiosity
method, and I think I'm starting to get some decent results. I've made a
handy .inc file to switch between passes. Also, I applied the film curve in
photoshop and I think thats what really made the image come into its own.
George Pantazopoulos
Download 'Athene_test1.jpg' (79 KB)
Preview of image 'Athene_test1.jpg'
Subject: Re: Athene - radiosity/smoothing/dynamic range compression (78kB)
Date: 1 May 2002 02:33:26
Message: <3ccf8c36@news.povray.org>
radiosity
in
Here is a version after some levels adjustment in photoshop I think it looks
better.
Download 'Athene_test1_contrastcorrect.jpg' (26 KB)
Preview of image 'Athene_test1_contrastcorrect.jpg'
Date: 1 May 2002 03:37:27
Message: <3ccf9b37@news.povray.org>
looks
> better.
I prefer this one too, it looks at least just as good as brazil, though
still not quite realistic (?).. But why should it be necessary to use a
third party program, when POV can adjust levels on it's own, with
assumed_gamma plus the usual texture / light setup.
Hugo
Date: 1 May 2002 04:13:27
Message: <3ccfa3a7$1@news.povray.org>
1. I didn't create the image.
2. I'm not as familiar with pov, giving that I use Moray a lot, as I should
be.
Date: 1 May 2002 04:59:45
Message: <3CCFAE99.83E902B5@luxlab.com>
Looks nice and smooth. Too much smoothing will erase detail though.
_____________
Kari Kivisalo
Date: 1 May 2002 05:02:00
Message: <3CCFAF20.CDF4EC64@luxlab.com>
If a hammer is the only tool available, everything begins to look like a nail.
_____________
Kari Kivisalo
Date: 1 May 2002 09:12:25
Message: <3ccfe9b9$1@news.povray.org>
Thomas, yes that looks better, it appears that you upped the contrast?
George
"Thomas Lake" <tla### [at] REMOVE-THISshawca> wrote in message
news:3ccf8c36@news.povray.org...
> radiosity
> in
own.
looks
> better.
Date: 1 May 2002 09:21:24
Message: <3ccfebd4$1@news.povray.org>
Kari,
   Yes youre correct. I've discovered ( in Pass 2) to get less smoothing,
you need to increase count, or else there can be some strange artifacts
(such as black or white lines at borders). With error_bound of 0.7 I've gone
as low as count 10 without artifacts (depends on the image) For this image I
used error_bound 0.400 and count 150. A Count of less than 100 tended to
produce artifacts around the feet. Raising count in Pass 2 does not seem to
improve image quality but it does prevent artifacts from appearing, so its a
matter of finding the magic number it seems. Its a balancing act because a
larger count slows down Pass 2
All the above info is for the second, quick smoothing pass. For Pass 1 I
used count 200, error_bound 0.180, recursion_limit 12 (both passes),
nearest_count 1 (both passes), and brightness 1.4 (both passes).
Thanks,
Kari Kivisalo" <pro### [at] luxlabcom> wrote in message
news:3CCFAE99.83E902B5@luxlab.com...
radiosity
> _____________
> Kari Kivisalo
