POV-Ray : Newsgroups : povray.binaries.images : Cell Shader: my try Server Time
15 May 2026 11:19:40 EDT (-0400)
  Cell Shader: my try (Message 31 to 34 of 34)
Subject: Re: Cell Shader: my try
Date: 30 Apr 2002 04:00:01
Message: <3CCE4EFD.571664DA@atosorigin.com>
Vahur Krouverk wrote:
> Nice. Did you 'invented' this shader by yourself? ARM book contains
> examples of such shaders. Unfortunately most advanced of them can't be
> applied to POVMan, as POVMan doesn't support surface derivatives, which
> are necessary for calculation of cel lines with uniform width. As it
> could be seen on this picture and other 'pure-povray' approaches, line
> widths depend from object geometry. Perhaps better results could be
> achieved with specific patch by J. Grimbert, but this requires as well
> surface derivative calculation...
Until YOU are going to provide EACH pov object with a function which
provide the derivative at any point of the object, including at the
surface, but also inside and outside, the only approach would be
to make a kind of guess by casting more rays.
Thus it would require more rewrite of the pov-engine, and a serious
slowdown. (I remind you that some object provide a normal only
for a previously computed intersection... so you cannot 'sample' around
the intersection to get a feeling about the variation of the normal...)
So, the only safe approach would probably be a new function per object,
It should be easy for sphere, but already with a box the problems
start coming out... What is the derivative on a edge ? on a vertex ?
With CSG, it's even more difficult!
Blob is not funny either!
and Isosurface is probably better handled only by the user:
 user provide both the isosurface formulae and its derivatives!
quartic, quadric and all poly objects are on the contrary rather
simple to get the derivative automatically and easily.
And the same probably goes for superellipsoid (?).
Non Sine Numine
http://grimbert.cjb.net/
Puis, s'il advient d'un peu triompher, par hasard,
Date: 30 Apr 2002 13:27:07
Message: <3CCED458.6050106@comtrade.ee>
[Snip]
Yes, I know all these problems.
Additional problem, which comes with use of RenderMan shaders, is the
fact, that in RenderMan all surfaces are parametric (with respect to uv)
and surface derivatives are usually taken with respect of u and v (this
is done 'analytically' in BMRT (don't know about PRMan), other
derivatives are made by 'supersampling': running shader in u+du or v+dv
points and calculating required expression). This means, that using
RenderMan shaders with surface derivatives could be done to small subset
of POV-Ray objects (sphere, plane, box, mesh, ??).
I intend to create method for POV-Ray objects, which returns surface
derivatives and implement it for 'parametrizable' objects (as you put
it: 'safe approach'). For other objects dummy implementation (or
approximation??) could be made. This is not 'perfect' solution, but it
allows to use some advanced shaders with POV-Ray (current implementation
of shader support is limited and it will not be fully supported anyway,
for it would require too much work, easier would be to use RenderMan
compliant renderer in such case).
Date: 2 May 2002 06:55:49
Message: <3CD11B38.672EF733@atosorigin.com>
> [Snip]
Before wasting to much of your time patching and for my own enlightment,
is there any real interest for this kind of shader information ?
What does it allow to make ?
For the time being, I even hardly see any interest even just for
the edge detection/celluloid thing...
so I wonder if it is really worth something.
P.S.: These questions are serious, not rethorical or ironical.
I would really be interested in URLs which show the advantage of such
derivative information for a shaders, so feel free to reference pages
that contain Renderman pictures...
Non Sine Numine
Date: 2 May 2002 15:10:51
Message: <3CD18F3B.1090405@comtrade.ee>
Don't know. Perhaps not, as POVMan itself is already niche product. But
this is my way of wasting time and perhaps I can learn something during
this process :-)
Analytical anti-aliasing. Of course this can be achieved with POV-Ray
means and probably more efficiently. Additionally, writing shaders which
antialiase well ain't easy task (although one can use number of already
created shaders).
But if analytical antialiasing is too complex for given shader, then
shaders frequency could be limited, if we know sampling frequency (IOW
surface derivatives). This approach could be applied to many shaders,
which use noise or its variants. (Of course more-or-less similar results
could be achieved by giving estimated derivatives as parameters, but
this works only for fairly 'flat' shapes.)
Other application is nonphotorealistic shaders. Cel shading is one of
them, other application could be shaders in 'Pen-and-Ink', woodblock or
engraving style. (PDF document describing pen and ink rendering could be
found at
http://citeseer.nj.nec.com/winkenbach96rendering.html
though not directly renderman related. ARM book contains shader, which
gives similar results).
Yes, it could be discouraging. There is quite number of patches, which
have very little recognition, either because they are hard to use or
they are too specific or they copy already existing functionality.
But there are other areas in shader support, which could be implemented
or improved. One of them is displacement shader, which could give nice
support for displacement, other is light shader, which could be used for
creation of user-specified light-sources. Or Imager shader, which could
be used for post-processing image. Or support for transformations
between camera and screen spaces, which give more flexibility to
shaders. So possibilities for shaders are huge, if I had only time enough...
