POV-Ray : Newsgroups : povray.binaries.images : Soccer! Server Time
18 Jul 2026 12:13:09 EDT (-0400)
  Soccer! (Message 21 to 30 of 30)
Subject: Re: Soccer!
Date: 14 Apr 2002 00:01:38
Message: <3CB8FF08.3BEB175D@pobox.com>
Corey Woodworth wrote:
> I know some C. I could try to write a converter but this would
> definetly be the most ambitious project I've ever done and I havn't
> coded since last semester.
Coincidentally, I wrote a converter today (for Surface Evolver output)
in Python; it took less than an hour.  No more C for me, unless I need
speed.
http://www.ogre.nu/source/evolpov.py
Anton Sherwood, http://www.ogre.nu/
Date: 14 Apr 2002 00:03:23
Message: <3CB8FF71.4A3CA734@pobox.com>
> . . . In Wings I changed the materials of the hexagons to black
> so that it'd look more soccerbally. . . .
Black pentagons and white hexagons are more traditional.
(http://www.ogre.nu/soccer.html)
Date: 15 Apr 2002 18:44:07
Message: <3cbb57b7$1@news.povray.org>
I posted a feature request on the source forge page and got this response:
>Comment By: Bjorn Gustavsson (bjorng)
>Date: 2002-04-15 12:06
>I expect that there will be built-in POV export within a few
>releases of Wings.
YAY!
Corey
Date: 16 Apr 2002 03:16:30
Message: <3cbbcfce@news.povray.org>
> >releases of Wings.
I know. A guy names KayosIII are currently working on it, and I'm giving
some advices.
Hugo
Date: 16 Apr 2002 14:23:18
Message: <3cbc6c16$1@news.povray.org>
> some advices.
Cool. Have you had a chance to play around with Wings3D yet?
Corey
> Regards,
> Hugo
Date: 17 Apr 2002 08:48:20
Message: <3cbd6f14@news.povray.org>
Yes, after you told me about it. It's a nice program at first glance and I
could immediately get some results. The interface is clean. I was actually
missing a good polygon modeller, and this one works. That said, the program
is still in a child state. Documentation is poor and scattered, facts change
rapidly. Either I'm very clumsy or some things are still incredibly slow to
carry on with it because it's not written in C but some strange (unknown to
me) language.
It's a handy tool to have aside POV, obviously not a replacement because of
countless things, but probably going to play it professional. Btw, the Pov
plugin will soon be working.
And what do you think about the program?
Hugo
Date: 17 Apr 2002 14:51:17
Message: <3cbdc425$1@news.povray.org>
"Hugo" <hua### [at] post3teledk> wrote in message
news:3cbd6f14@news.povray.org...
program
change
to
to
> me) language.
of
I like it. I think its the interface that makes it so cool. Its easy to jump
in and start messing around (Unlike Blender for ex.) I can see myself making
so cool objects for POV scenes since it really is only a single object
modeller. I havn't made anything useful yet though, I'm still getting the
hang of modelling at all!
Corey
Subject: Wings3D (was Re: Soccer!)
Date: 19 Apr 2002 16:22:22
Message: <Xns91F5A68D84E99csbhccse@204.213.191.226>
"Hugo" <hua### [at] post3teledk> wrote in news:3cbd6f14@news.povray.org:
> Documentation is poor and scattered, facts change rapidly. Either I'm
> very clumsy or some things are still incredibly slow to model with the
> program.
What are you having problems with?  I've been using Wings for quite a while
and have become fairly proficient with it.  I might be able to help you
out.
Subject: Re: Wings3D (was Re: Soccer!)
Date: 23 Apr 2002 03:41:45
Message: <3cc51039$1@news.povray.org>
> >  slow to model with the program.
while
> out.
Thanks! This post is getting old, so I don't know if you'll ever read
this... I have begun a spaceship project where a polygon modeller would be
handy (just for a few things).. And Wings3d is the best program I've
encountered because it's so easy to understand.. But.. Until now I end up
placing all vertices manually because bevel, scale and extrude makes a mess.
Yes, even if I select an origin, those commands can't guess what I want;
they don't follow my shape.. If I could "scale along edges" this would
to understand with this example:
home3.inet.tele.dk/huas/strange.wings
Try to smooth out the "hill" by adding another line of vertices. Try to
scale them, and see the mess! Any solution that doesn't require a lot of
manual work?
There are also other things I'd like to see in Wings: The ability to connect
any vertices to make a polygon. Boleean operations (ala POV's "difference
{}").. Spline extrusion.. More options to smooth a shape.. A face
decimaition algoritm.. More options to mirror things.. Bridging any two
polygons.. Make single sided objects.. Lastly, animation capabilities..
Hugo
Date: 23 Apr 2002 14:31:15
Message: <Xns91F993B6AF6B7CQ@204.213.191.226>
"Hugo" <hua### [at] post3teledk> wrote in news:3cc51039$1@news.povray.org:
> Until now I end up placing all vertices manually because bevel, scale and
> extrude makes a mess. Yes, even if I select an origin, those commands
> can't guess what I want; they don't follow my shape..
It sounds like you're not doing something quite right, but I don't have
enough information to hazard a guess yet.
Have you tried extruding (etc) by normal rather than by the standard axes?
This is the only way to produce usable results when extruding faces that
don't all point in roughly the same direction.
Another trick to remember when using extrude is that, if you want to
extrude two or more adjacent faces and have them stay together (i.e. the
edges sharing vertexes), delete the dividing edges before extruding and
recreate them afterwards.
> If I could "scale along edges" this would probably solve the problem.
scale->region is probably close to what you want, but it's only available
in faces mode.
Keep in mind, too, that the effects of scale are different in vextexes mode
than in edges or faces mode.  Scale in vertexes mode will scale the
vertexes relative to the origin but scale in the other modes will scale the
items relative to eachother.
> of manual work?
Unless I've misunderstood what you want to do, it works fine for me:
'e' to enter edge mode
select all vertical edges in the hill
'2' to subdivide edges
'c' to connect the new vertexes.
menu->scale->uniform (left mouse button).
> connect any vertices to make a polygon.
If the faces are adjacent (or close to it), delete the intervening edges
and recreate the edges as needed.
> Bridging any two polygons..
It takes a bit of messing around if the faces are adjacent (see above), or
if they have a different number of vertexes (think extrude & add or remove
vertexes as needed), but Wings can do this already.  Faces mode->select two
faces->menu->bridge.
Hope this helps.
