POV-Ray : Newsgroups : povray.binaries.images : Salt Shaker Server Time
23 Apr 2026 17:21:35 EDT (-0400)
  Salt Shaker (Message 1 to 8 of 8)
Subject: Salt Shaker
Date: 10 Apr 2002 19:30:01
Message: <3cb4caf9@news.povray.org>
This image is for a website Im designing, about Salt (well, kind of :-)
Overall, Im pleased with the results of this test render, however Im not
satisfied with the salt quite yet, and well, if a salt shaker is turned
upside down, salt should come out, but hey :-)
Any criticism? Comments?
This scene is my first using radiosity (default settings)
Download 'salt shaker.png' (34 KB)
Preview of image 'salt shaker.png'
Subject: Re: Salt Shaker
Date: 10 Apr 2002 20:25:09
Message: <3cb4d7e5$1@news.povray.org>
"Lieut_Data" <lIe### [at] yahOOcom> wrote in message
news:3cb4caf9@news.povray.org...
I don't know if the inside of the glass looks wierd because of low rad
settings, low photon settings, but it needs a lil work. Also, I don't see
ANY salt but that could be because of the glass artifacts. I'd make the cap
more reflective and give it something to reflect. Perhaps image map a
screenshot of the website onto a plane and let it reflect that? That could
yield some interesting results.
Corey
Date: 10 Apr 2002 20:31:11
Message: <3cb4d94f@news.povray.org>
Yes, I and my mother definitely noticed that... thanks!
> Also, I don't see ANY salt but that could be because of the glass
artifacts.
Same error I saw... Im trying to simplify the salt by defining its shape and
giving it a texture that looks like salt, but the glass is interfering.
> I'd make the cap more reflective and give it something to reflect. Perhaps
image map a
Very intuitive! I think ill try that :-)
Thankyou very much!!!
> Corey
Date: 10 Apr 2002 20:46:23
Message: <3cb4dcdf$1@news.povray.org>
the corners are too sharp, they should be rounded slightly.  (I know this is
difficult to do, but it would improve the appearance of the glass quite a
bit)
-tgq
Date: 10 Apr 2002 21:19:00
Message: <3cb4e484@news.povray.org>
is
> bit)
Good point -- actually not too hard, if I employ the use of bezier
splines... of course figuring out those points will be hard...gotta get back
to work on my spline editor :-)
Thanks!
Date: 11 Apr 2002 09:27:27
Message: <3cb58f3f$1@news.povray.org>
Lieut_Data <lIe### [at] yahOOcom> wrote in message
news:3cb4e484@news.povray.org...
> splines...
That might make it a little too round. Just plotting 5 or so mesh points at
each corner would likely give a more realistic shape. Mesh might also
increase your render speed because you wouldn't need to use subtraction to
make the inside hollow.
 -Shay
Date: 11 Apr 2002 14:21:48
Message: <3cb5d43c$1@news.povray.org>
at
How would I go about applying interior to a mesh?
Date: 11 Apr 2002 14:28:29
Message: <3cb5d5cd$1@news.povray.org>
news:3cb5d43c$1@news.povray.org...
As long as the mesh is closed, you can apply interior to it just as you
would any solid object.
 -Shay
