POV-Ray : Newsgroups : povray.binaries.images : Sword Stand (final?) 107 KB Server Time
18 Jul 2026 14:35:01 EDT (-0400)
  Sword Stand (final?) 107 KB (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: Sword Stand (final?) 107 KB
Date: 2 Apr 2002 13:36:00
Message: <3ca9fa10$1@news.povray.org>
Yes they are isosurfaces.  My math skills are poor at best.  I felt luckly
to get them to look like that!  :)
Here is some of the code I used:
 isosurface {
     function { f_rounded_box(x,y,z,0,0.70,0.85,0.70) - f_noise3d(x*5.2,
y*4.9, z*4.7)* 0.05 }
     contained_by { box { -1 , 1} }
     max_gradient 25
     pigment {RockColor3 translate <0,-1.8,0>}
     scale RockScale
If you could explain how that could be added here I will certainly try that.
Thanks!
Patrick Dugan
"Skip Talbot" <sta### [at] uiucedu> wrote in message
news:3ca9f3cd$1@news.povray.org...
> The coloring on the blade looks very artistic, I like the colors.  I
believe
> that it adds to the scene instead of taking away from it because of
realism.
> The stone bricks are isosurfaces, no?  What if you added a pigment
function
> on top of them giving them a small grain?
> Skip
Date: 2 Apr 2002 13:39:44
Message: <3ca9faf0$1@news.povray.org>
Sorry I left out the scale I used for the rocks.
#declare RockScale = <0.360,0.1,0.360>;
believe
realism.
function
> Skip
Date: 2 Apr 2002 13:58:33
Message: <3ca9ff59@news.povray.org>
"Patrick Dugan" <pat### [at] netinsnet> wrote in message
news:3ca91752@news.povray.org...
> Here is the (maybe) finished sword stand picture.  I'm not sure if it's done
> or I need to do something else in the image.  The idea was to highlight the
> sword and dagger (in a black leather sheath) on a wrought-iron sword stand.
> The entire mess sitting on a fireplace mantel.  I thought about adding
> something cloth-like to offset the hardness of the image but I'm not sure.
> Any ideas?
  Excellent! I've been following this. I think you could be right. A 'drape' hanging
behind the sword would look good IMHO. Either
red and yellow or red and black with some kind of FE.Asian text? I have to say that
your sword looks a beast in lambs clothing.
Those two straight bits with the curve on the ends, (near the hilt), are quite
in-humane are they not? Cruelly interesting. Are they
for real? I haven't seen that before myself...
      Back to the image...  A bevel line would look good also....  straight down the
middle of the blade...
      Very nice image.
       ~Steve~
> Patrick Dugan
Date: 2 Apr 2002 14:10:04
Message: <3caa020c@news.povray.org>
Perhaps add some focal blur?
Looks very good so far!
Marc-Hendrik
Date: 2 Apr 2002 14:19:25
Message: <3caa043d@news.povray.org>
Thank you!  Once I figure out a cloth method (or someone else posts a clith
include for Povray 3.5) I'll add something in there.
Well I actually own the sword and dagger.  I haev tried to model them as
close as I can to the real thing.  The "horns" on the hilt
could be a bit dangerous.  The sword is very heavy.  I didn't add a "blood
channel" down the blade since the real one doesn't have it.
Patrick Dugan
"25ct" <25c### [at] lineonenet> wrote in message news:3ca9ff59@news.povray.org...
done
the
stand.
sure.
> > Any ideas?
'drape' hanging behind the sword would look good IMHO. Either
say that your sword looks a beast in lambs clothing.
quite in-humane are they not? Cruelly interesting. Are they
straight down the middle of the blade...
>       Very nice image.
>        ~Steve~
> > Patrick Dugan
Date: 2 Apr 2002 14:21:07
Message: <3caa04a3$1@news.povray.org>
Thank you!
I'm not sure where I would blur the image though.  Maybe near the bottom of
the wall?
Patrick Dugan
"Marc-Hendrik Bremer" <Mar### [at] t-onlinede> wrote in message
news:3caa020c@news.povray.org...
> Marc-Hendrik
Date: 2 Apr 2002 14:48:40
Message: <3caa0b18@news.povray.org>
"Patrick Dugan" <pat### [at] usnetcomcorpcom> wrote in message
news:3caa043d@news.povray.org...
> Thank you!  Once I figure out a cloth method (or someone else posts a cloth
> Well I actually own the sword and dagger.  I have tried to model them as
     Ah! That's what it's called! A ' Blood Channel' ? Ie, a groove for the blood to
run down?? - Obviously.
        Eek!!  ;)
    Heheh.. I was thinking more along the lines of the actual manufacture of the
sword. Don't they usually have 'bevelled' angles to
the blade? (Possibly with a groove too?)
    The whole cross section being a thin/narrow diamond shape? I'm very possibly
wrong, so forgive me for *digging* too deep with
this...  <..sheesh....>  ;)
    ~Steve~
Date: 2 Apr 2002 15:25:14
Message: <MPG.17142409dbf1d231989b14@news.povray.org>
>blood to run down?? - Obviously.
Actually, the main purpose was to release suction on the blade and make
it easier to remove from your opponents body IIRC...
Jamie.
Date: 2 Apr 2002 23:16:50
Message: <3caa8232$1@news.povray.org>
"Jamie Davison" <jam### [at] ntlworldcom> wrote in message
news:MPG.17142409dbf1d231989b14@news.povray.org...
as
"blood
the
oops...common misconception...
True purpose of the fullered groove in a blade is to reduce weight and add
strength.  (If you don't have the strength to give the blade a bit of a
twist when pulling it out, you didn't have the strength to put it in there
either.)
Scott
Date: 3 Apr 2002 06:57:15
Message: <3caaee1b@news.povray.org>
I would suggest the focal point on the name-plaque (or what ever it is
called), perhaps a little bit up and to the left. Start with some arbitrary
aperture. I don't know what will look better: some strong blurring, or just
a tiny bit.
Marc-Hendrik
