POV-Ray : Newsgroups : povray.binaries.images : Turbulent Isosurface box? Server Time
15 May 2026 12:04:47 EDT (-0400)
  Turbulent Isosurface box? (Message 16 to 25 of 25)
Subject: Re: Final "Rock"
Date: 23 Mar 2002 17:38:03
Message: <3c9d03cb@news.povray.org>
I played with this idea also, but tried to create the box as a math
function.  I quickly found a solution to creating a cubic box using a simple
equation, but it uses outrageous exponents, of course.  A moments though will
show why.  However, I did not want perfect edges; rather, a rounded box will
work fine for this idea.  I just took the absolute values of x^11, y^11, and
z^11 and added them to get a very decent rounded box structure.
    Then I added a crackle function that I scaled to produce "exfoliation"
layers like real slate or shale would have, and added it to that box function
with some turbulence.  Here are a few simple images that the functions created,
using a straight brown pigment scheme.  I will go back and play with the texture
and pigment now and see what emerges.
Cheers!
Chip Shults
Download 'Isobox02.jpg' (6 KB) Download 'Isobox03.jpg' (6 KB) Download 'Isobox05.jpg' (7 KB) Download 'Isobox06.jpg' (7 KB)
Preview of image 'Isobox02.jpg'
Preview of image 'Isobox03.jpg'
Preview of image 'Isobox05.jpg'
Preview of image 'Isobox06.jpg'
Subject: Re: Turbulent Isosurface box?
Date: 23 Mar 2002 17:57:34
Message: <3c9d085e$1@news.povray.org>
I probably should have mentioned that he would want to use a different
pigment to get a different rock... here is wood, which makes a good stone...
////////////// Camera //////////////////////
camera {                                  //
        right      <  1.333, 0.0, 0.0 >   //
        up         <  0.0, 1.0, 0.0 >    //
        direction  <  0.0, 0.0, 1.0 >     //
        location   <  3.0, 3.0, 3.0 >
        look_at    <  0.0, 0.0, 0.0 >     //
////////////// end Camera //////////////////
///////////////  Light  ////////////////
light_source { < 1000.0, 1000.0, 1000.0 >
color rgb < 1.0, 1.0, 1.0 > }
#declare Rock=function{
                 pigment{
                         wood
                         turbulence 0.125
                         color_map { [0 rgb 1] [1 rgb 0] }
                         scale < 0.5, 0.25, 0.5 >
#declare Wall = function { max((x*x-1),(y*y-1),(z*z-1)) }
#declare RockWall =
isosurface {
              function {
                         Wall(x,y,z)
                        +Rock(x,y,z).x
                        *0.125
              contained_by { box {
                                  <-1.5,-1.5,-1.5 >,
                                  < 1.5, 1.5, 1.5 >
              accuracy 0.0001
              max_gradient 20
              pigment { rgb 1 }
              finish  { ambient 0.0625 }
              translate < 0.0, 0.0, 0.0 >
 object { RockWall }
Download 'RockWall03.jpg' (17 KB)
Preview of image 'RockWall03.jpg'
Subject: Re: Turbulent Isosurface box? Maybe a tree...
Date: 23 Mar 2002 19:23:37
Message: <3c9d1c89@news.povray.org>
Man, I love this stuff- I have moved a few equations around and came up with
a pretty fair redwood tree trunk.  You can see a little container clipping on
the front, but I will get rid of that.  Here is the image, and it is not far
removed from the turbulent stone images except by a couple of math terms.
Cheers!
Chip Shults
#macro B(a,b)sphere{<a,b,13>.5pigment{agate}finish{phong.3}}#end#macro N(c,k,a)
#if(k<7)#if(mod(c,2))B(k,a)B(-k,-a)#end N(int(c/2)k+1a)#end#end light_source{0
rgb 1}N(61,1,1)N(37,1,0)N(55,1,-1)N(4,1,-2)N(4,1,-3)N(1,1,3)
Download 'Treetrnk.jpg' (31 KB)
Preview of image 'Treetrnk.jpg'
Date: 23 Mar 2002 20:00:53
Message: <3c9d2545$1@news.povray.org>
"Sir Charles W. Shults III" <aic### [at] cflrrcom> wrote in message
news:3c9d1c89@news.povray.org...
up with
on
far
> Cheers!
> Chip Shults
> My robotics, space and CGI web page - http://home.cfl.rr.com/aichip
N(c,k,a)
light_source{0
neat.  it would make a great petrified forest.
john
Date: 23 Mar 2002 22:34:31
Message: <3C9D48FD.9000007@tiac.net>
You mean like this?
Phil
Over 400 billion cups of coffee are consumed yearly. It's a
commodity that's 2nd only to oil...Maybe I should cut back.
Download 'iso_brick.jpg' (8 KB)
Preview of image 'iso_brick.jpg'
Date: 24 Mar 2002 08:55:48
Message: <3c9ddae4$1@news.povray.org>
Thanks alot.
"John & Amy Robinson" <jro### [at] columbusrrcom> wrote in message
news:3c9ceb50@news.povray.org...
> i had to set the light source to be a really high rgb value.  for some
> reason i had to also put a plane behind the stain glass or it just came
out
> looking dull.  heres a 'makeshift' bit of code.
> john
> global_settings {
>     ambient_light rgb 0.0
>     max_trace_level 10
>     radiosity {
>       pretrace_start 0.08
>       pretrace_end   0.02
>       count 100
>       nearest_count 8
>       error_bound 1.15
>       recursion_limit 6
>       low_error_factor 0.6
>       adc_bailout 1/255
>       gray_threshold 0.05
>       minimum_reuse 0.015
>       brightness 0.125
>       max_sample -1
>       normal on
> media {
>     intervals 50
>     scattering { 2, rgb 0.005 }
>     samples 1, 5
>     confidence 0.95
>     variance 1/128
>     ratio 0.9
> #declare Dull = finish { ambient 0.05 diffuse 0.3 reflection 0.0 specular
1
> roughness 0.001 }
> #declare Cutty =
> union {
>  box {<-15,-40,-2>,<15,0,2>}
>  intersection {
>   cylinder {<-10,0,-2>,<-10,0,2>,25}
>   cylinder {<10,0,-2.1>,<10,0,2.1>,25}
> difference {
>  box {<-210,-110,31>,<210,130,-340>}
>  box {<-200,-50,29>,<200,125,-330>}
>  object { Cutty translate <0,40,30> }
>  pigment { rgb 1 }
>  finish {
>   ambient 0.1
>   diffuse 0.8
>   reflection  { 0 }
>   specular 0.1
>   roughness 0.005
>  normal { granite 0.2 scale 1 }
>  box {<-16,-1,30.5>,<16,70,30.6>
>  pigment {
>   image_map { gif "bruce4.gif" interpolate 2 filter all 0.6}
>   translate <-0.5,0,0>
>   scale <32,75,1>*0.8
>  finish { Dull }
> camera {
>     perspective
>     location <85,-30,-190>
>     direction <0,0,1.5>
>     look_at <-55,0,30>
>  light_source { <0,60,-260> rgb <1,0.5,0.2>*0.4 media_interaction off  }
>  light_source { <0,1200,2000> rgb 25 }
>  background { rgb 1 }
>  plane {<0,0,1>,2100 hollow pigment { rgb 0.05 } finish { Dull }}
> /////////////////// the end
> "Alastair Murray" <ala### [at] hotmailcom> wrote in message
> news:3c9cab9b$1@news.povray.org...
> > How did you get the light to shine through the dust like that?
> > Sources would be incredibly useful.
> > news:3c9ca1c3$1@news.povray.org...
> > > "Patrick Dugan" <pat### [at] netinsnet> wrote in message
> > > news:3c9c9e4e@news.povray.org...
> > > > How do/can you make a isosurface box that has a "rough" surface?
> > > > I have a (poor) image I made by hand of a "turbulent" box shape.
> > > Basically
> > > > I am trying to
> > > > make boxes that look like randomly made rectangular stones that have
> > been
> > > > placed within
> > > > a stone wall (like a fireplace) but have been chipped to be somewhat
> > > > rectangular so they
> > > > can be placed somewhat close together.
> > > i used the f_rounded_box function for the walls in this image
> > > http://www.fishinglog.com/Art/bigThe%20Keep.html
Date: 24 Mar 2002 10:46:26
Message: <3c9df4d2@news.povray.org>
Hey! Makes a decent termite mound?
Alf
Date: 25 Mar 2002 04:48:42
Message: <test9ug25obfe81hmcgtqc740bcn65t224@4ax.com>
On Sat, 23 Mar 2002 11:18:29 -0600, "Patrick Dugan" <pat### [at] netinsnet>
wrote:
> I tried:
> isosurface {
>     function { f_rounded_box(x,y,z,0,1,1,1) - f_noise3d(x, y, z)* 0.25 }
>     contained_by { box { -1 , 1} }
>     pigment{Red}
>     scale 0.2
> but this yields a perfectly square box.  No roughness at all.  Would the
> max_gradient make or break this?
Becouse f_rounded_box has strange definition of inside probably. Try IC_Box
function from iso_csg library.
http://www-public.tu-bs.de:8080/~y0013390/pov/ic/index.html
ABX
Date: 25 Mar 2002 05:56:52
Message: <3c9f0274$1@news.povray.org>
"Alf Peake" <alf### [at] peake42freeservecouk> wrote in message
news:3c9df4d2@news.povray.org...
LOL! Yeah it does!
Corey
> Alf
Date: 25 Mar 2002 14:04:05
Message: <3C9F745E.70402@tiac.net>
Oops I forgot some code...(watch out for word wrap)
#declare Pig1=
function{
   pigment{
           wrinkles
           color_map{[0 rgb 1][.75 rgb 0][1 rgb<.3,.95,.3>]}
           scale 0.75
isosurface {
     function { max(abs(x)-1, abs(y)-1, abs(z)-1)+(Pig1(x,y,z).gray*.24)}
     contained_by{box{-1,1}}
     threshold 0
     accuracy 0.001
     max_gradient 4.105
     texture{T_Stone43}
Phil
