POV-Ray : Newsgroups : povray.binaries.images : Turbulent Isosurface box? Server Time
15 May 2026 12:04:47 EDT (-0400)
  Turbulent Isosurface box? (Message 11 to 20 of 25)
<<< Previous 10 Messages Goto Latest 10 Messages Next 5 Messages >>>
Subject: Yes! Re: Turbulent Isosurface box?
Date: 23 Mar 2002 14:30:09
Message: <3c9cd7c1@news.povray.org>
Yes!  Thank you!
 isosurface {
     function { f_rounded_box(x,y,z,0,0.75,0.75,0.75) - f_noise3d(x, y, z)*
0.25 }
     contained_by { box { -1 , 1} }
     max_gradient 0.5
     pigment{Red}
     scale 0.2
I made the function smaller than the box and finally got something like I
want.
(I'm sorry I'm so dense about this.)
news:3C9CB8C2.E4D0FC55@gmx.de...
> Patrick Dugan wrote:
> >  isosurface {
> >      function { f_rounded_box(x,y,z,0,1,1,1) - f_noise3d(x*5, y*5, z*5)*
> > 0.25 }
> >      pigment{Red}
> >      scale 0.2
> > From the tutorial it
> > seemed to be the most likely function, but it apparently isn't.
> As said in the other post you need an appropriate container object.  In
> your example all surfaces are outside the (default) container, therefore
> you only see the container itself.
> Christoph
> POV-Ray tutorials, IsoWood include,
> TransSkin and more: http://www.tu-bs.de/~y0013390/
> Last updated 18 Mar. 2002 _____./\/^>_*_<^\/\.______
Subject: Final "Rock"
Date: 23 Mar 2002 14:56:28
Message: <3c9cddec@news.povray.org>
I tweaked it some more and finally got this:
 isosurface {
     function { f_rounded_box(x,y,z,0,0.85,0.85,0.85) - f_noise3d(x*5, y*5,
z*5)* 0.05 }
     max_gradient 25
        gradient y
        color_map {
           [0.00 color Gray90]
           [0.20 color Gray30]
           [0.40 color Gray80]
           [0.60 color Gray20]
           [0.80 color Gray10]
           [1.00 color Gray80]
        turbulence 0.75
        scale <1,0.1,1>
     finish {ambient 0.4}
     scale <0.3,0.1,0.3>
That was the look I was trying to achieve.  Thanks for your help!
> >  isosurface {
> > 0.25 }
> >      pigment{Red}
> >      scale 0.2
> Christoph
Subject: Re: Final "Rock"
Date: 23 Mar 2002 15:49:06
Message: <3c9cea42@news.povray.org>
this is the code i used.  scaling the wrinkles pigment gives different
'smoothness' of bricks.  i guess granite or bumps would do just as well.
the random seed also makes sure every brick is different.  you could also
try messing around with the gray value.
john
#declare f_rounded_box = function { internal(60) }
#declare rndm = seed(14577);
#macro aBrick(Seed)
#local W1 = function { pigment {wrinkles scale 2.5 translate
<Seed,Seed,Seed> } }
 isosurface {
 function { f_rounded_box(x,y,z,0.01,1.5,0.7,0.3) - W1(x,y,z).gray*0.65 }
 threshold 0
 max_gradient 1.7
 accuracy 0.01
 contained_by { box {<-2,-1,-1>,<2,1,0>} }
 scale 10
 pigment { rgb 0.975 }
 finish { ambient 0.1 diffuse 0.8 reflection  { 0 }specular 0.1 roughness
0.005 }
#declare yC = 0;
#while(yC < 50)
 #declare xC = -50;
 #while(xC < 50)
  object { aBrick(rand(rndm)*999999) translate <xC,yC,0> }
  object { aBrick(rand(rndm)*999999) translate <xC-16.5,yC+18,0> }
  #declare xC = xC + 33;
 #declare yC = yC + 36;
    location <50,50,-150>
    look_at <0,25,0>
 light_source { <100,50,-200> rgb 1 }
"Patrick Dugan" <pat### [at] netinsnet> wrote in message
news:3c9cddec@news.povray.org...
>  isosurface {
y*5,
> z*5)* 0.05 }
>      max_gradient 25
>       pigment {
>         gradient y
>         color_map {
>            [0.00 color Gray90]
>            [0.20 color Gray30]
>            [0.40 color Gray80]
>            [0.60 color Gray20]
>            [0.80 color Gray10]
>            [1.00 color Gray80]
>         turbulence 0.75
>         scale <1,0.1,1>
>      scale <0.3,0.1,0.3>
> "Christoph Hormann" <chr### [at] gmxde> wrote in message
> > >  isosurface {
z*5)*
> > > 0.25 }
> > >      pigment{Red}
> > >      scale 0.2
> > Christoph
Download 'wall.jpg' (19 KB)
Preview of image 'wall.jpg'
Subject: Re: Turbulent Isosurface box?
Date: 23 Mar 2002 15:53:36
Message: <3c9ceb50@news.povray.org>
i had to set the light source to be a really high rgb value.  for some
reason i had to also put a plane behind the stain glass or it just came out
looking dull.  heres a 'makeshift' bit of code.
john
global_settings {
    ambient_light rgb 0.0
    max_trace_level 10
    radiosity {
      pretrace_start 0.08
      pretrace_end   0.02
      count 100
      nearest_count 8
      error_bound 1.15
      recursion_limit 6
      low_error_factor 0.6
      adc_bailout 1/255
      gray_threshold 0.05
      minimum_reuse 0.015
      brightness 0.125
      max_sample -1
      normal on
media {
    intervals 50
    scattering { 2, rgb 0.005 }
    samples 1, 5
    confidence 0.95
    variance 1/128
    ratio 0.9
#declare Dull = finish { ambient 0.05 diffuse 0.3 reflection 0.0 specular 1
roughness 0.001 }
#declare Cutty =
union {
 box {<-15,-40,-2>,<15,0,2>}
 intersection {
  cylinder {<-10,0,-2>,<-10,0,2>,25}
  cylinder {<10,0,-2.1>,<10,0,2.1>,25}
difference {
 box {<-210,-110,31>,<210,130,-340>}
 box {<-200,-50,29>,<200,125,-330>}
 object { Cutty translate <0,40,30> }
 pigment { rgb 1 }
 finish {
  ambient 0.1
  diffuse 0.8
  reflection  { 0 }
  specular 0.1
  roughness 0.005
 normal { granite 0.2 scale 1 }
 box {<-16,-1,30.5>,<16,70,30.6>
  image_map { gif "bruce4.gif" interpolate 2 filter all 0.6}
  translate <-0.5,0,0>
  scale <32,75,1>*0.8
 finish { Dull }
    perspective
    location <85,-30,-190>
    direction <0,0,1.5>
    look_at <-55,0,30>
 light_source { <0,60,-260> rgb <1,0.5,0.2>*0.4 media_interaction off  }
 light_source { <0,1200,2000> rgb 25 }
 background { rgb 1 }
 plane {<0,0,1>,2100 hollow pigment { rgb 0.05 } finish { Dull }}
/////////////////// the end
"Alastair Murray" <ala### [at] hotmailcom> wrote in message
news:3c9cab9b$1@news.povray.org...
> How did you get the light to shine through the dust like that?
> Sources would be incredibly useful.
> "John & Amy Robinson" <jro### [at] columbusrrcom> wrote in message
> news:3c9ca1c3$1@news.povray.org...
> > news:3c9c9e4e@news.povray.org...
> > > How do/can you make a isosurface box that has a "rough" surface?
> > > I have a (poor) image I made by hand of a "turbulent" box shape.
> > Basically
> > > I am trying to
> > > make boxes that look like randomly made rectangular stones that have
> been
> > > placed within
> > > a stone wall (like a fireplace) but have been chipped to be somewhat
> > > rectangular so they
> > > can be placed somewhat close together.
> > i used the f_rounded_box function for the walls in this image
> > http://www.fishinglog.com/Art/bigThe%20Keep.html
Download 'light.jpg' (9 KB)
Preview of image 'light.jpg'
Date: 23 Mar 2002 16:31:33
Message: <3c9cf435@news.povray.org>
Bill, that looks about perfect for the type of walls you see along highways (where
they've cut through hills). Evaluating the
pigment
properly might be problematical, but I think there's a use for what you have here.
Salute,
Grim
Date: 23 Mar 2002 17:38:03
Message: <3c9d03cb@news.povray.org>
I played with this idea also, but tried to create the box as a math
function.  I quickly found a solution to creating a cubic box using a simple
equation, but it uses outrageous exponents, of course.  A moments though will
show why.  However, I did not want perfect edges; rather, a rounded box will
work fine for this idea.  I just took the absolute values of x^11, y^11, and
z^11 and added them to get a very decent rounded box structure.
    Then I added a crackle function that I scaled to produce "exfoliation"
layers like real slate or shale would have, and added it to that box function
with some turbulence.  Here are a few simple images that the functions created,
using a straight brown pigment scheme.  I will go back and play with the texture
and pigment now and see what emerges.
Cheers!
Chip Shults
Download 'Isobox02.jpg' (6 KB) Download 'Isobox03.jpg' (6 KB) Download 'Isobox05.jpg' (7 KB) Download 'Isobox06.jpg' (7 KB)
Preview of image 'Isobox02.jpg'
Preview of image 'Isobox03.jpg'
Preview of image 'Isobox05.jpg'
Preview of image 'Isobox06.jpg'
Date: 23 Mar 2002 17:57:34
Message: <3c9d085e$1@news.povray.org>
I probably should have mentioned that he would want to use a different
pigment to get a different rock... here is wood, which makes a good stone...
////////////// Camera //////////////////////
camera {                                  //
        right      <  1.333, 0.0, 0.0 >   //
        up         <  0.0, 1.0, 0.0 >    //
        direction  <  0.0, 0.0, 1.0 >     //
        location   <  3.0, 3.0, 3.0 >
        look_at    <  0.0, 0.0, 0.0 >     //
////////////// end Camera //////////////////
///////////////  Light  ////////////////
light_source { < 1000.0, 1000.0, 1000.0 >
color rgb < 1.0, 1.0, 1.0 > }
#declare Rock=function{
                 pigment{
                         wood
                         turbulence 0.125
                         color_map { [0 rgb 1] [1 rgb 0] }
                         scale < 0.5, 0.25, 0.5 >
#declare Wall = function { max((x*x-1),(y*y-1),(z*z-1)) }
#declare RockWall =
isosurface {
              function {
                         Wall(x,y,z)
                        +Rock(x,y,z).x
                        *0.125
                                  <-1.5,-1.5,-1.5 >,
                                  < 1.5, 1.5, 1.5 >
              accuracy 0.0001
              max_gradient 20
              pigment { rgb 1 }
              finish  { ambient 0.0625 }
              translate < 0.0, 0.0, 0.0 >
 object { RockWall }
Download 'RockWall03.jpg' (17 KB)
Preview of image 'RockWall03.jpg'
Subject: Re: Turbulent Isosurface box? Maybe a tree...
Date: 23 Mar 2002 19:23:37
Message: <3c9d1c89@news.povray.org>
Man, I love this stuff- I have moved a few equations around and came up with
a pretty fair redwood tree trunk.  You can see a little container clipping on
the front, but I will get rid of that.  Here is the image, and it is not far
removed from the turbulent stone images except by a couple of math terms.
Cheers!
Chip Shults
#macro B(a,b)sphere{<a,b,13>.5pigment{agate}finish{phong.3}}#end#macro N(c,k,a)
#if(k<7)#if(mod(c,2))B(k,a)B(-k,-a)#end N(int(c/2)k+1a)#end#end light_source{0
rgb 1}N(61,1,1)N(37,1,0)N(55,1,-1)N(4,1,-2)N(4,1,-3)N(1,1,3)
Download 'Treetrnk.jpg' (31 KB)
Preview of image 'Treetrnk.jpg'
Date: 23 Mar 2002 20:00:53
Message: <3c9d2545$1@news.povray.org>
"Sir Charles W. Shults III" <aic### [at] cflrrcom> wrote in message
news:3c9d1c89@news.povray.org...
up with
on
far
> Cheers!
> Chip Shults
> My robotics, space and CGI web page - http://home.cfl.rr.com/aichip
N(c,k,a)
light_source{0
neat.  it would make a great petrified forest.
john
Date: 23 Mar 2002 22:34:31
Message: <3C9D48FD.9000007@tiac.net>
You mean like this?
Phil
Over 400 billion cups of coffee are consumed yearly. It's a
commodity that's 2nd only to oil...Maybe I should cut back.
Download 'iso_brick.jpg' (8 KB)
Preview of image 'iso_brick.jpg'
