POV-Ray : Newsgroups : povray.binaries.images : Dry stone wall - help! [12.4KB] Server Time
18 Jul 2026 21:22:42 EDT (-0400)
  Dry stone wall - help! [12.4KB] (Message 14 to 23 of 23)
Subject: Re: Dry stone wall - help! [12.4KB]
Date: 22 Mar 2002 10:47:03
Message: <3c9b51f7$1@news.povray.org>
"Shay" <sah### [at] simcopartscom> wrote in message news:3c9b5067$1@news.povray.org...
> I'm still confident that it is the trace problem. Leave your code exactly as
> it is in your post except for the following lines, and you will see what I
> mean.
> #declare XScale = 1;//rand(Rand1)*2 + 0.5;
> #declare YScale = 1;//rand(Rand1)*2 + 0.5;
> #declare ZScale = 1;//rand(Rand1)*2 + 0.5;
Hmm, okay - I'll have to think about this some more (probably when my brain
stops bleeding).
Date: 22 Mar 2002 10:57:55
Message: <3c9b5483$1@news.povray.org>
I have the solution if you want it. I won't post without asking, because you
may want to think about it more yourself.
 -Shay
Tom Melly <tom### [at] tomandlucouk> wrote in message
news:3c9b51f7$1@news.povray.org...
Date: 22 Mar 2002 11:04:58
Message: <3c9b562a$1@news.povray.org>
"Shay" <sah### [at] simcopartscom> wrote in message news:3c9b5483$1@news.povray.org...
Nghhh - okay, post. No, no, I didn't mean that. Ah, hell.
Date: 22 Mar 2002 11:23:41
Message: <3c9b5a8d$1@news.povray.org>
news:3c9b562a$1@news.povray.org...
I guess that's a "no." I see another possible bug when you switch over to
side trace.
 -Shay
Date: 22 Mar 2002 11:40:13
Message: <3c9b5e6d$1@news.povray.org>
I've been playing with your code a little bit, and I'm afraid that the
algorithm may be doomed. The only ways that I can think of for keeping the
bricks from overlapping are *very* complex. Hopefully someone can find a
simpler solution to the problems with the algorithm than I.
You might want to create another algorithm that places the stones
mathematically rather than with trace, but I don't think that any algorithm
will beat a random guess and check algorithm.
 -Shay
Shay <sah### [at] simcopartscom> wrote in message
news:3c9b5a8d$1@news.povray.org...
Date: 22 Mar 2002 11:49:07
Message: <3c9b6083@news.povray.org>
"Shay" <sah### [at] simcopartscom> wrote in message news:3c9b5e6d$1@news.povray.org...
Yes, some overlapping seems inevitable. My hope is that with the right random
seed the problem will not be visable. Partial results look ok.
Besides..... a lot of the wall will be hidden by snow ;)
Date: 2 Apr 2002 20:23:30
Message: <3caa5992@news.povray.org>
a)  Drive people absolutely nuts and job security...
b)  TOO complex
c)  TOO Much CODE.
Here's my solution...
#declare RS=seed(9938);
//------------------------------------------------Wall
#declare R1=1;
#while(R1<3000)
  #declare RX=rand(RS)*50;
  #declare RY=rand(RS)*10;
  #declare ROD=rand(RS)*1+.5;
  #declare RSY=rand(RS)*.5+.5;
  #declare RSX=rand(RS)*.5+.5;
  sphere{<0,0,0>,ROD scale<RSX,RSY,1> translate<RX,RY,0>
texture{pigment{color Red}}}
  #declare R1=R1+1;
I made it only 10 units tall instead of your 25.  Looks better.
Robert J Becraft
aka cas### [at] aolcom
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3c9b304f@news.povray.org...
> I'm working on a macro that will hopefully eventually generate a dry-stone
wall,
> but I'm running into problems. In the image below, the wall should approx.
fill
> the area marked out by the yellow cylinders, but it ain't.
> If anyone can be bothered to:
> a) work out what I'm trying to do
> b) work out how I'm trying to do it
> and
> c) what's going wrong
> then here is the code:
> //start code
> #version 3.5;
> #include "colors.inc"
> global_settings {
>   assumed_gamma 1.0
> camera {
>   location  <0.0, 1.5, -100.0>
>   look_at   <0.0, 1.5,  0.0>
> light_source {
>   <0, 0, 0>            // light's position (translated below)
>   color rgb <1, 1, 1>  // light's color
>   translate <-30, 30, -30>
> #macro BuildWall()
>   #declare Rand1 = seed(142);
>   #declare Brick = sphere{0,1 pigment{Red}}
>   #declare Ground = plane{y,0 pigment{Green}}
>   #declare WallLen = 50;
>   #declare WallHi = 15;
>   #declare ThisLen = 0;
>   #declare ThisHi = 0;
>   #declare Wall = object{Ground}
>   #while(ThisLen <= WallLen & ThisHi <= WallHi)
>     #declare XScale = rand(Rand1)*2 + 0.5;
>     #declare YScale = rand(Rand1)*2 + 0.5;
>     #declare ZScale = rand(Rand1)*2 + 0.5;
>     #declare ThisBrick = object{Brick scale<XScale, YScale, ZScale>}
>     #if(ThisLen = 0)
>       #declare Norm = <0, 0, 0>;
>       #declare Start = <0,WallHi*2,0>;
>       #declare InterA = trace ( Wall, Start, <0, -1, 0>, Norm );
>       #declare Wall = union{
>         object{Wall}
>         object{ThisBrick translate y*(InterA.y + YScale)}
>       #declare ThisLen = XScale;
>       #declare ThisHi = InterA.y + YScale;
>     #else
>       #declare Start = <ThisLen+XScale,WallHi*2,0>;
>       #if(InterA.y < ThisHi)
>         #declare Start = <WallLen*2,InterA.y + YScale,0>;
>         #declare InterB = trace ( Wall, Start, <-1, 0, 0>, Norm );
>           object{Wall}
>           object{ThisBrick translate<InterB.x + XScale, InterA.y + YScale,
0>}
>       #end
>       #declare ThisLen = InterB.x + (XScale*2);
>       #if(ThisLen > WallLen & ThisHi <= WallHi)
>       #end
>     #end
>   #end
> #end
> BuildWall()
> object{Wall}
> cylinder{0,y*25, 0.2 pigment{Yellow}}
> cylinder{0,y*25, 0.2 pigment{Yellow} translate x*50}
> cylinder{x*-10,x*60, 0.2 pigment{Yellow} translate y*15}
> //end code
> ... and here is the image
> #macro G(D,E,F)#local I=array[3]{D,E,F}#local B=0;triangle{#while(
> B<3)#while(I[B])A[mod(I[B],10)]+#local I[B]=div(I[B],10);#end<-5,-
> 2,9>#local B=B+1;#end}#end #local A=array[7]{x,x*2,x*4,y,y*2,y*4,z
> }light_source{-x*6-z*9,1}mesh{G(105,10,146)G(105,246,10)G(105,56,
> 146)G(105,1256,246)G(1256,126,220)G(22156,2216,201)pigment{rgb 1}}//TM
Download 'TESTwall.jpg' (10 KB)
Preview of image 'TESTwall.jpg'
Date: 2 Apr 2002 20:32:48
Message: <3caa5bc0@news.povray.org>
Version 2 w/ a color randomizer for the components...
#declare RS=seed(938);
#declare R1=1;
#while(R1<3000)
  #declare RC=int(rand(RS)*5+1);
       #switch(RC)
       #case(1) Gray10 #break
       #case(2) Gray40 #break
       #case(3) Gray50 #break
       #case(4) Gray80 #break
       #case(5) Gray90 #break
  #declare R1=R1+1;
"Robert J Becraft" <cas### [at] aolcom> wrote in message
news:3caa5992@news.povray.org...
> b)  TOO complex
> c)  TOO Much CODE.
> #declare R1=1;
> #while(R1<3000)
>   #declare R1=R1+1;
> #end
> Regards,
> Robert J Becraft
dry-stone
> wall,
approx.
> fill
> > and
> > //start code
> > #version 3.5;
> > global_settings {
> >   assumed_gamma 1.0
> > camera {
> > light_source {
> > #macro BuildWall()
> >     #if(ThisLen = 0)
> >         object{Wall}
> >     #else
> >           object{Wall}
YScale,
> 0>}
> >       #end
> >       #end
> >     #end
> >   #end
> > #end
> > BuildWall()
> > object{Wall}
> > //end code
Download 'TESTwall.jpg' (11 KB)
Date: 2 Apr 2002 23:34:57
Message: <3caa8671@news.povray.org>
The problem with this solution is that the "stones" blend into each other.
IIRC... the original problem was to build a realistic stone wall.
Scott
news:3caa5bc0@news.povray.org...
> #declare R1=1;
> #while(R1<3000)
>        #switch(RC)
>        #end
>   #declare R1=R1+1;
> #end
> > b)  TOO complex
> > c)  TOO Much CODE.
> > #declare R1=1;
> > #while(R1<3000)
> >   #declare R1=R1+1;
> > #end
> > Regards,
> > Robert J Becraft
> dry-stone
> > wall,
> approx.
> > fill
> > > and
> > > //start code
> > > #version 3.5;
> > > global_settings {
> > >   assumed_gamma 1.0
> > > camera {
> > > light_source {
> > > #macro BuildWall()
> > >     #if(ThisLen = 0)
> > >         object{Wall}
> > >     #else
> > >           object{Wall}
> YScale,
> > 0>}
> > >       #end
> > >       #end
> > >     #end
> > >   #end
> > > #end
> > > BuildWall()
> > > object{Wall}
> > > //end code
Date: 3 Apr 2002 07:18:40
Message: <3caaf320@news.povray.org>
Ooo - not bad. I'm still working on my version (now much more simplified). RL
has got in the way, but hopefully something to post soon. Currently running into
a problem where, under certain conditions, the macro finds the same hole that
needs filling, fails to fill it, then finds the hole again - aka infinite loop.
