POV-Ray : Newsgroups : povray.binaries.images : For Hugo. Irregular mesh smoothing idea. Server Time
19 Jul 2026 03:26:44 EDT (-0400)
  For Hugo. Irregular mesh smoothing idea. (Message 27 to 36 of 36)
Subject: Re: Does this look right to you, ABX?
Date: 6 Mar 2002 15:21:47
Message: <3c867a5b@news.povray.org>
Very good. Let me just add that I'm going to turn the heightfield data
around lathes and let them follow the path of splines. I don't know if this
is going to break the non-square type of mesh. It's still a grid. But these
turns will, of course, happen before normal calculations.
> This is really going to slow the macro down
I can always have both methods, and let the user decide which one to use.
:o)
Hugo
Subject: Re: Yeaah! I got it to work!!
Date: 6 Mar 2002 15:37:31
Message: <3C867FF9.6040903@smileyface.com>
> universal formula for area of triangle:
> S=sqrt(p*(p-a)*(p-b)*(p-c))
> where a,b,c are lengths of edges and p is half of perimeter = (a+b+c)/2
Is that faster than using half the cross product of two of the sides?
(cosidering vcross is internal...)
Something like:
area = vlength(vcross(P1-P2,P3-P2))/2;
-josh
Date: 6 Mar 2002 15:39:05
Message: <3c867e69$1@news.povray.org>
Hugo <hua### [at] post3teledk> wrote in message news:3c867a5b@news.povray.org...
this
these
It's not as slow as I thought it might be, and nothing will break this new
algorithm. As long as the vertices can be put into an n-by-n array, the
algorithm will work.
 -Shay
Date: 6 Mar 2002 16:39:47
Message: <3c868ca3$1@news.povray.org>
Don't think so. sqrt needs more cpu cycles. But maybe I'm wrong!
Apache
http://geitenkaas.dns2go.com/experiments/
apa### [at] yahoocom
Date: 6 Mar 2002 16:51:22
Message: <3c868f5a$1@news.povray.org>
Apache <apa### [at] yahoocom> wrote in message
news:3c868ca3$1@news.povray.org...
PoV's going to use square root anyway to find those lengths.
 -Shay
Date: 6 Mar 2002 16:57:51
Message: <3c8690df$1@news.povray.org>
>> Something like:
Vlength uses sqrt internally. But the major slowdown is Povrays interpreter
and not the cpu.
Regards
Hugo
Date: 6 Mar 2002 18:40:55
Message: <3C86A730.785EA5C1@hotmail.com>
> Something like:
I have not looked at their mesh code yet,
but I assume that they are calculating
the normal vectors for the triangles by
just taking the cross product of a pair
of each triangle's "edge vectors".
And if this is the case, then I don't see
the point in first calculating this cross
product, normalize it and then multiply
it by your area expression.
I.e.:
vnormalize(vcross(P1 - P2, P3 - P2))
*vlength(vcross(P1 - P2, P3 - P2))/2
They could just use the cross product
directly:
vcross(P1 - P2, P3 - P2)/2
And they don't even have to divide it
by 2 prior to the summing. Because
every triangle normal will be "double"
length.
The final normalizing of the sum of
all the "weighted" normal vectors will
eliminate it anyway.
Tor Olav
Subject: Re: For Hugo. Irregular mesh smoothing idea.
Date: 6 Mar 2002 19:04:25
Message: <3C86ACB1.FF58C201@hotmail.com>
> On Tue, 5 Mar 2002 09:12:47 -0600, "Shay" <sah### [at] simcopartscom> wrote:
> > The weighted normals look better. Is this the case with every mesh?
> This is just more accurate method of averaging.
> > This goes against everything I have seen concerning mesh normals.
> Not exactly. Weighting is just longer and result is visible when there are
> differences in triangle area.
> > By a weighted average, do you mean simply not normalizing the normal of each
> > triangle?
> Considering you have N triangles with vertex P:
> - take all N normals as previously
> - normalize them as previously
> - new step: multiply/adjust according to area of triangle
> - add all N normals as previously
> - normalize this sum as previously (I'm not sure it is necessary)
> So only new thing is muliplying. This is done to save larger triangles more
> float.
Wlodek,
if the triangle normals are calculated
with cross products, then step 2 and 3
above are not necessary.
Also see my reply in this thread to Josh
Seagoe some minutes ago:
http://news.povray.org/%3C3C86A730.785EA5C1%40hotmail.com%3E
news://news.povray.org/3C86A730.785EA5C1%40hotmail.com
Tor Olav
Date: 7 Mar 2002 02:43:31
Message: <7c6e8u88j07g71u11aci5g14l4avb92vbo@4ax.com>
On Thu, 07 Mar 2002 00:56:33 +0100, Tor Olav Kristensen
<tor### [at] hotmailcom> wrote:
> Wlodek,
I feeled this...
ABX
Date: 7 Mar 2002 02:57:04
Message: <t47e8ugr5d8n0bucu9tu5la1fsrgbc4mel@4ax.com>
On Wed, 6 Mar 2002 12:45:09 -0600, "Shay" <sah### [at] simcopartscom> wrote:
> > #local triangle_area_engine=function{(x+y+z)*(y+z-x)*(x+y-z)*(x+z-y)/16}
> > #local triangle_area=
> >   function(x1,y1,z1,x2,y2,z2,x3,y3,z3)
> >     {sqrt(triangle_area_engine(
> >         f_r(x2-x1,y2-y1,z2-z1),
> >         f_r(x3-x2,y3-y2,z3-z2),
> >         f_r(x3-x1,y3-y1,z3-z1)
> #include "functions.inc"
> #local Triangle_Area =  triangle_area_engine(Side_1_Length, Side_2_Length,
Side_3_Length);
> Seems right to me, but I might be missing something.
You forgot about sqrt applied but since others mentioned that not normalized
cross product is sufficient then I think my method is wasting of pov-time ;-)
ABX
