POV-Ray : Newsgroups : povray.binaries.images : For Hugo. Irregular mesh smoothing idea. Server Time
19 Jul 2026 12:08:35 EDT (-0400)
  For Hugo. Irregular mesh smoothing idea. (Message 17 to 26 of 36)
Subject: Re: Yeaah! I got it to work!!
Date: 6 Mar 2002 10:21:20
Message: <2tcc8uk708tgec598p843g17v5gf6ajjld@4ax.com>
wrote:
> universal formula for area of triangle:
btw: if you are interested in background theory then
http://mathworld.wolfram.com/HeronsFormula.html
ABX
Date: 6 Mar 2002 10:31:35
Message: <3c863657@news.povray.org>
Thank you again, ABX. It seems that you are always waiting in a dark corner
ready to jump out with a formula the way Ken is with a link.
I never went to college, so most of the math I know is self tought. This
leaves BIG holes in my math knowledge.
The formula you supplied will help a lot, because I will henceforth be
adding a "weighted" switch to all of my vertex normalizing macros.
 -Shay
news:2tcc8uk708tgec598p843g17v5gf6ajjld@4ax.com...
Date: 6 Mar 2002 12:00:56
Message: <3c864b48$1@news.povray.org>
Thanks for the formulas and explanations, but I am not sure how to implement
them.. I like math too (more than I did in school!) but I'm not educated
enough to understand what ABX wrote.. I'd very much like to have the best
smoothing algoritm in my program.. If Shay codes it for personal use, maybe
I will get a copy too and some insight.  :o)  At the moment I'm
concentrating on another part of my macros that needs to be written before
the overall results will look good enough to open your eyes.  ;o)
Hugo
Date: 6 Mar 2002 12:12:31
Message: <3c864dff$1@news.povray.org>
Hugo <hua### [at] post3teledk> wrote in message
news:3c864b48$1@news.povray.org...
implement
You do. For heightfields, the method I used is as effecient as any. Nothing
can simplify (Base*Height)/2. Writing the formula as a function MIGHT speed
it up, but with only 2 operations per calculations I'm not sure.
The method described by ABX is necessary only for non-square meshes.
 -Shay
Date: 6 Mar 2002 12:15:17
Message: <8tic8ugj54obbclgs7jrjedqg7spe4mell@4ax.com>
Algorithm is very simple:
1. start loop on all triangles and calculate
a) triangle has vertices V1,V2,V3
b) normal=vnormalize(vcross(V2-V1,V3-V1))
c) area=triangle_area(V1.x,V1.y,V1.z,V2.x,V2.y,V2.z,V3.x,V3.y,V3.z)
d) multiply above and store area*normal in temporary array
2. start second loop on all vertices
a) for each vertex find all its triangles: triangle1, triangle2, ... triangleN
b) calculate weighted normal with equation:
Normal=(area1*normal1+area2*normal2+...+areaN*normalN)/N
(note all multiplications was precalculated and stored in array)
c) store new weighted normal for triangle
That's all.
Of course there can be variations and optimizations according to particular
situation but it is how it looks in general
ABX
Date: 6 Mar 2002 12:26:28
Message: <opjc8u8qk2a9s20e037adocejo9ccvii6i@4ax.com>
Well, you can check my investigation in
http://news.povray.org/f4sa5uomgj1v158rjs159ms75midq7qm52%404ax.com
that function is fastest way of calculations
I can be wrong becouse I not studied your sources enough but looking at
pictures on http://news.povray.org/3c84365e%40news.povray.org your triangles
are non-square. Only projection onto xz plane (considering y is up) are
square.
ABX
Date: 6 Mar 2002 12:37:25
Message: <pskc8u41r19r8tskteah60mdn8cq06ukj6@4ax.com>
should be:
c) store new weighted normal for vertex
sorry
ABX
Date: 6 Mar 2002 12:53:33
Message: <3c86579d$1@news.povray.org>
news:opjc8u8qk2a9s20e037adocejo9ccvii6i@4ax.com...
triangles
> square.
OH DAMN!!! I really screwed up. I was only thinking about elevating one
vertex in ... (well, not important what I was thinking).
I will implement the method you outlined ASAP. This is really going to slow
the macro down, but as long as you're writing out the results for possibly
hundreds of renders, you may as well get the best results possible.
 -Shay
Subject: Does this look right to you, ABX?
Date: 6 Mar 2002 13:44:09
Message: <3c866379@news.povray.org>
news:5mdc8ukvplcavtnekp4f0cvtebe8rtlbob@4ax.com...
> #include "functions.inc"
> #local triangle_area_engine=function{(x+y+z)*(y+z-x)*(x+y-z)*(x+z-y)/16}
> #local triangle_area=
>   function(x1,y1,z1,x2,y2,z2,x3,y3,z3)
>     {sqrt(triangle_area_engine(
>         f_r(x2-x1,y2-y1,z2-z1),
>         f_r(x3-x2,y3-y2,z3-z2),
>         f_r(x3-x1,y3-y1,z3-z1)
I've haven't used any functions yet, so I would like to know if my version
of your function will work..
I see a slight problem with your function in that the lengths of most of the
triangle sides will be calculated twice.
The demonstration file I wrote finds all of the side lengths first and
stores them in an array. A #local statement at the beginning  of each "case"
macro could find the length of the diagonal. So, would this give an accurate
result?
 #local Triangle_Area =  triangle_area_engine(Side_1_Length, Side_2_Length,
Side_3_Length);
Seems right to me, but I might be missing something.
Thank you,
 -Shay
Subject: Re: Does this look right to you, ABX?
Date: 6 Mar 2002 14:24:20
Message: <3c866ce4@news.povray.org>
Well, the results *look* correct. I implemented the formula you suggested,
and the parse is still pretty quick. I tested a 100x100 mesh on my P2 650 at
work with lots of memory-hogging programs running on it, and the parse was
still under a minute.
I cancelled the version from pbs-f that I posted from work and will cancel
the others when I get home, but I might run several tests, or at least get
confirmation from ABX that my function is correct, before I post this new
version.
 -Shay
Shay <sah### [at] simcopartscom> wrote in message news:3c866379@news.povray.org...
"case"
accurate
> result?
Side_2_Length,
> Side_3_Length);
> Thank you,
>  -Shay
