POV-Ray : Newsgroups : povray.binaries.images : PoV modeling Server Time
15 May 2026 11:48:09 EDT (-0400)
  PoV modeling (Message 1 to 10 of 23)
Subject: PoV modeling
Date: 3 Mar 2002 12:25:21
Message: <3c825c81@news.povray.org>
This is about 34K triangles lovingly placed by hand. I wanted to demonstrate
the kind of awesome control that scripting can provide. Something similar
could have been done much simpler, but if you look closely at the model you
will notice that the peaks of the curves at the holes follow the curve of
the main body and that the curves all merge smoothly into the body.
I would also like to know what y'all think of my texture. I put as much time
into getting that look as I did the modeling.
The first person to show me how this could have been done in 5 minutes with
an iso-blob wins a free video tape of me screaming and pulling out my
hair.<g>
 -Shay
Download 'PoV_Model.jpg' (33 KB)
Preview of image 'PoV_Model.jpg'
Subject: Re: PoV modeling
Date: 3 Mar 2002 12:49:37
Message: <3c826231@news.povray.org>
demonstrate
Wow! Did you use macros for this? How did you get that much control over
shape, plus having normals.... I don't see an easy pattern to this... Is it
a heightfield lathe?
The texture is good but looks a bit confusing. It would benefit from blurred
reflection! Have you tried this? Since your model is triangle based, it
renders very fast so it won't be killed by blurred reflection .. and soft
shadows of course!
Very good work.  :o)
Hugo
Date: 3 Mar 2002 15:29:41
Message: <3C8287BD.A89AE2E9@unforgettable.com>
> hair.<g>
Why didn't you just use the included "thingy full of holes" function?
-Xplo
Date: 3 Mar 2002 15:42:21
Message: <3C828A36.1C9E3088@amc.uva.nl>
Sorry for asking, but what is it?
	Andrel
> hair.<g>
>  -Shay
Date: 4 Mar 2002 02:34:43
Message: <3c832393$1@news.povray.org>
Why can't you tell? A combination napkin ring/cheese grater;-)
Date: 4 Mar 2002 03:11:43
Message: <3c832c3f$1@news.povray.org>
Nooo it's a trashcan!
Of course!
Hugo
Date: 4 Mar 2002 05:38:33
Message: <3c834ea9$1@news.povray.org>
> Of course!
you must be blind, its obviously part of a darlek
PGP Public Key
Date: 4 Mar 2002 10:24:35
Message: <3C8391B8.32ECF2D2@durham.ac.uk>
The child of a tarlik and a blowfish.
Oliver Wood
University Of Durham
aka : adm### [at] coldclimatecouk
[home] - www.coldclimate.co.uk
[cold][wet][durham] - a daily blog - www.coldclimate.co.uk/blog
[cold][wet][world]  - a communal blogwww.coldclimate.co.uk/glog
Date: 4 Mar 2002 11:13:27
Message: <3c839d27$1@news.povray.org>
Hugo <hua### [at] post3teledk> wrote in message news:3c826231@news.povray.org...
it
Thanks. I did use macros, but there is no easy pattern. The shape is made up
of 56 unique sets of radially arranged vertices. Each row of vertices starts
at the side of a set, heads towards the center, and then heads back out to
another side of the set on the inside wall.
A heightfield would have the problem that the vertices are arranged in a
grid. This is not optimal because so many of the vertices would be on
flat(ish) areas. Arranging the vertices in a radial pattern allows you put
more of the vertices where they are needed. Also, a heigtfield would not
have holes.
blurred
> shadows of course!
I tried blurred-reflection as you suggested. The realism drastically
increased! Thanks! I will use blurred-reflection when I use this in a
scene.The texture I posted is only for showing the details and looking a
little like a catalogue shot (I tried.) The render time did go from 3
seconds to 30 minutes, but I used a 10x10 area light as well.
 -Shay
Date: 4 Mar 2002 11:14:41
Message: <3c839d71@news.povray.org>
Clever ideas, guys, but what did you think of the modeling?
Rick [Kitty5] <ric### [at] kitty5com> wrote in message
news:3c834ea9$1@news.povray.org...
