POV-Ray : Newsgroups : povray.binaries.images : smooth height_fields Server Time
18 Nov 2026 23:07:35 EST (-0500)
  smooth height_fields (Message 1 to 32 of 32)
Subject: smooth height_fields
Date: 2 Mar 2002 11:36:53
Message: <3c80ffa5@news.povray.org>
How does POV-Ray smooth height_fields?  The results aren't really good in
any case.
At the left is an ordinary smoothed height_field, at the right the same
shape using smooth_triangles.
Wouldn't it be possible to use a better way of smoothing height_fields?  As
it is now, the smooth-keyword in height_fields isn't really useful...
cu!
ZK AKA SaD
http://www.povplace.be.tf
"You know what they say: No good deed goes unpunished."
Download 'heightfield.jpg' (16 KB)
Preview of image 'heightfield.jpg'
Subject: Re: smooth height_fields
Date: 2 Mar 2002 12:03:33
Message: <3c8105e5@news.povray.org>
I'm surprised the left result is so bad. But how did you make the right one?
Probably the difference is that more normals are averaged.
But you see, I'm really *fighting* with a macro to calc normals to a
triangle heightfield.. It's crazy, I code as "clean" as I can, and week
after week I return to my code to find the bugs, but ...argh... I know how
to calculate the normal of a triangle, but my macro construct the
heightfield in a (better) way that means, sometimes there are 3, 4, 5 or 6
faces connected to a vertex.
Any help will be appriciated!  It's a macro that I think would be generally
useful to many people.
Hugo
Date: 2 Mar 2002 12:43:32
Message: <3C810F25.C5BBB6B1@gmx.de>
> any case.
I can't say for sure of course, but those two shapes really don't seem to
have the same geometry to me.
Last updated 21 Feb. 2002 _____./\/^>_*_<^\/\.______
Date: 2 Mar 2002 12:55:38
Message: <3c81121a@news.povray.org>
Believe me, they have :)
They're both the bozo-pattern on the xz-plane from x=0 to 1 and z=0 to 1.
cu!
ZK AKA SaD
"The only thing that helps me maintain my slender grip on reality is the
friendship I share with my collection of singing potatoes."
Date: 2 Mar 2002 13:04:54
Message: <3c811446$1@news.povray.org>
so am I...
2 while loops.  The first one calculates a matrix of locations based on the
bozo-pattern, which is then used in the second loop to place triangles and
calculate normals.
maybe, but it almost looks like it just runs a smooth-filter on the final
image.  You can still see the edges of the triangles, but they're blurry.
Actually an interesting effect, but rather useless imho.
generally
This is how I did it, but I don't think it would be of much help.  To
calculate the normal of one point of a triangle, I average the normals of
every triangle that shares that point.  It's easy to know which triangles
share that point in a simple matrix of triangles, but I'm not sure how you
would do it with what you're doing...
cu!
ZK AKA SaD
"If you could see what I've seen with your eyes."
Date: 2 Mar 2002 13:07:04
Message: <3C8114C6.6B839116@gmx.de>
That's not what i meant, the triangle vertices need to be the same for
comparable results.
Date: 2 Mar 2002 13:09:18
Message: <3c81154e@news.povray.org>
> comparable results.
Maybe it's easier to compare this way: I mirrored one of them and moved the
light.
cu!
ZK AKA SaD
"we will make spears twice as long as a man, but some men are longer than
others"
Download 'heightfield2.jpg' (15 KB)
Preview of image 'heightfield2.jpg'
Date: 2 Mar 2002 13:12:13
Message: <3c8115fd$1@news.povray.org>
I don't think that it's practical to write a smoothing macro for all meshes,
although I think Warp did one. The calculations just take too long and
require that the user construct specific types of arrays to put into the
macro(at least coding it in PoV.) It's so much faster to just create a
little algorithm for whatever case on which you happen to be working.
 -Shay
"Hugo" <hua### [at] post3teledk> wrote in message
news:3c8105e5@news.povray.org...
Date: 2 Mar 2002 14:06:00
Message: <3c812298@news.povray.org>
> generally
I'm only after a macro that average normals based on a matrix, like in
ordinary heightfields. The tricky thing is that the faces can be connected
in 2 ways, based on what serves the curvature best.. I don't know the
mathematical names for it.. I call them "quad faces".. Two faces form a
square, but this can happen in 2 ways.. I use both ways and I need a macro
to smooth that matrix.. I think, ordinary heightfields also swap the
quad-faces depending on the curvature..
If your macro can handle this - please ! ...share it. :o)
Or if I didn't make myself clear, I can try again.
Hugo
Date: 2 Mar 2002 14:11:51
Message: <3C812367.41872833@gmx.de>
> > comparable results.
> light.
This obviously does not change anything, to really judge whether the
heightfield smoothing is broken would require perfectly identical
geometry.
Date: 2 Mar 2002 14:28:47
Message: <3c8127ef@news.povray.org>
> geometry.
I really don't understand what you mean.  These two object have exactly the
same geometry, haven't they?  They are derived from the same pattern, they
have the same shape, the same height, and in this image the same shading,
only the way they are smoothed is different.  If you still don't believe me
this 2 objects have the same shape, maybe I should post an unsmoothed
version, then you'll see they are exactly the same (which they should be),
but with smoothing, they are not (which is not good of course :)
Hmmm, I just rendered this, and they are indeed not exactly the same :)
Oh, I see, I forgot the hf_gray_16 in the height_field.  Here is the
smoothed version *with* the hf_gray_16.  Still rather ugly compared to the
right one, I think.  But this time the unsmoothed version seems to be
exactly the same!
cu!
ZK AKA SaD
"Brace yourself for a bit of a shock, Lister, but I just saw you die."
Download 'heightfield3.jpg' (15 KB)
Preview of image 'heightfield3.jpg'
Date: 2 Mar 2002 14:32:14
Message: <3c8128be@news.povray.org>
if that is true, the geometry of my own height_field-like object still isn't
the same as the real height_field.
But, Christoph: *if* it's true what Hugo says here, the results of the real
height_fields should be *better* than those of my own version, which it
clearly isn't.
At the moment there isn't really a macro (yet), but I'll post my code to
p.b.s-f
cu!
ZK AKA SaD
"It's my duty; my duty as a complete and utter bastard."
Date: 2 Mar 2002 14:39:49
Message: <3C812A68.F189BA73@gmx.de>
I would suggest you render a lower resolution version without smoothing so
you can see the single triangles and compare the results.
Date: 2 Mar 2002 14:51:07
Message: <3c812d2b@news.povray.org>
Ok, they are not 100% the same.  But close enough.  The smoothed versions
should not be that different.
I made a mistake in my scene.  The height_field had a resolution of 1 less
than the other version.  I fixed it, and now they *really* have the same
geometry, as you can see in the first attached image...  But still, the
smoothed height_field doesn't look as good as it should, as you can see in
the seconde attached image...
cu!
ZK AKA SaD
"I want my baby back, baby back, baby back ribs"
Download 'heightfield4.jpg' (19 KB) Download 'heightfield5.jpg' (12 KB)
Preview of image 'heightfield4.jpg'
Preview of image 'heightfield5.jpg'
Date: 2 Mar 2002 15:18:26
Message: <3C813380.CE5FC730@gmx.de>
All right, this seems suited for comparison, it's surely worth having a
look at the heightfield normal calculation code.
Date: 3 Mar 2002 03:01:02
Message: <4nl38ucbrua75pocmb2qjk2pamhrai1tn6@4ax.com>
On Sat, 2 Mar 2002 17:38:38 +0100, "Zeger Knaepen"
>any case.
What do you expect? It's only a guess at the normals, after all.
Yeah, and how do you know the normals of those triangles? By
interpolating between vertex positions (which is the only info
available to the hf code) or are you using info from the generating
pattern?
Aside from a different kind of interpolation (higher order), not
really.
Peter Popov ICQ : 15002700
Date: 3 Mar 2002 04:47:35
Message: <3c81f137$1@news.povray.org>
> pattern?
Zeager posted his code in p.b.s-f
The normals are derived from the vertices.
>>any case.
That's true, but a good guess, after all.. The native HF should be able to
look as good as Zeager's IMO.
Hugo
Date: 3 Mar 2002 06:14:15
Message: <3c820587@news.povray.org>
<blabla>
<blabla>
Just for the record: my name is Zeger, not Zeager :)
cu!
ZK AKA SaD
"Two hits: me hittin' you, you hittin' the floor."
Date: 3 Mar 2002 12:44:10
Message: <3c8260ea$1@news.povray.org>
"Zeger Knaepen" <zeg### [at] studentkuleuvenacbe> wrote in message
news:3c80ffa5@news.povray.org...
> any case.
I'm not sure how PoV does it, but it sure runs a lot faster than my
smoothing algorithms. I think that the new height-field macros in shapes.inc
3.5 use a smoothing algorithm more like the one you used. Haven't tried them
yet, though. Anyway, they will write out the vertices so you can do whatever
you like with them.
 -Shay
Date: 3 Mar 2002 14:04:28
Message: <chrishuff-6EB994.14043003032002@netplex.aussie.org>
In article <3c8260ea$1@news.povray.org>, "Shay" <shi### [at] houstonrrcom>
> you like with them.
The macros don't do any sort of normal averaging at all. The method I
used is actually closer to that used for normal perturbation in
textures, the  macros sample the function used to generate the height
field to determine the normal. This might apply to image-based height
fields as well, if interpolation is used, but I haven't tested it.
Date: 3 Mar 2002 18:55:41
Message: <3c82b7fd@news.povray.org>
I
height
height
Its a bit late at night for me but do I understand that I could use
trace() on a vertex and use the returned normal as an average for all
other triangles in a mesh sharing that vertex? I'm referring to
MegaPov, not 3.5 and just starting to play with generating triangles
for the first time.
Alf
Date: 3 Mar 2002 20:47:08
Message: <chrishuff-49380E.20470703032002@netplex.aussie.org>
In article <3c82b7fd@news.povray.org>,
> for the first time.
I'm not sure what you mean here...if you trace a ray directly at a
vertex of a mesh, there is no way to predict which triangle it will hit.
POV certainly won't pick all the possible triangles and average their
normals for you. If the mesh is non-smooth, the returned normal will be
the normal of any one of the adjacent triangles. You have to compute a
normal yourself. The POV 3.5 macros can do it accurately because they
have access to the geometry of the surface around each vertex, not just
the vertices. Averaging the normals of the triangles around the point
usualy produces acceptable results as well, but trace() won't be very
useful for this.
Date: 4 Mar 2002 14:40:04
Message: <npi78us6q6d2j26cb36bas87g60s17hhhv@4ax.com>
I haven't had the time to look there, sorry. I'll trust you on this
one :)
Ditto, but I fear it is too late for such deep changes in the 3.5
code.
Having it as a macro in the distro could be useful, though.
Date: 4 Mar 2002 16:14:56
Message: <3c83e3d0$1@news.povray.org>
>code.
But maybe it should be considered a bug.. There has been other recent
discussions about heightfields and several people have noticed strange
phenomenes like this.. I think we all agree it looks wrong.. I don't know
how complex the sourcecode is but Zeger's is only a few lines.. It's
probably more complex in C, but a bug like this shoudn't really be able to
hide for more than an evening or two.. imho.. (though I'm not skilled in C.)
Hugo
Date: 4 Mar 2002 17:06:25
Message: <chrishuff-2A6C82.17063004032002@netplex.aussie.org>
In article <npi78us6q6d2j26cb36bas87g60s17hhhv@4ax.com>,
> code.
I think it would depend on how hard it is to find and fix. It would be a
bug fix, not a new feature...
Um, have you looked? The HF_Square() macro in shapes.inc doesn't use
this method, but it should give better results, especially when using
entirely procedural height fields.
Date: 4 Mar 2002 18:59:01
Message: <3c840a45@news.povray.org>
"Christopher James Huff" <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
use
all
triangles
> > for the first time.
hit.
their
be
a
I'm trying to convert a non-rendered object, blueprints, but with with
known points on the surface. Inventing the wheel. At least I'll
understand the script ;-)  I was trying to figure ways to calculate
the average normal for smoothing.
Your comment made me think that after storing each _unique_ vertex in
an array indexed by the triangle's number I could use trace with each
vertex. It only needs to be used once per vertex and will cover all
triangles sharing that vertex.
#declare Average_Norm = <0,0,0>;
#declare Temp = trace( Object, Vertex*2, -Vertex, Average_Norm );
<wimper> Ahhh! The light dawns - I need Object in the first place. I
don't have it :( Excuse me while I arrange a brain transplant.
</wimper>
Alf
Date: 4 Mar 2002 19:19:47
Message: <3c840f23$2@news.povray.org>
FYI: the image was rendered with POVMan, but I don't think the height_field
code has changed in POV3.5, so it would give the same problems.
cu!
camera{location-z*3}#macro G(b,e)b+(e-b)*(C/50)#end#macro L(b,e,k,l)#local
C=0
;#while(C<50)sphere{G(b,e),.1pigment{rgb G(k,l)}finish{ambient 1}}#local
C=C+1
;#end#end
L(y-x,y,x,x+y)L(y,-x-y,x+y,y)L(-x-y,-y,y,y+z)L(-y,y,y+z,x+y)L(0,x+y,
<.5,1,.5>,x)L(0,x-y,<.5,1,.5>,x)               // ZK
Date: 5 Mar 2002 01:47:13
Message: <f5q88u8ceh2m2a51338rn85k11o372ho3e@4ax.com>
On Mon, 04 Mar 2002 17:06:31 -0500, Christopher James Huff
Yeah, with a procedural it makes sense to produce better results. And
maybe no one thought of using it with an image as a source :)
I'll have to check whether it looks better with that macro using an
image as a source, with interpolation, of course. Just not today...
Date: 5 Mar 2002 06:02:00
Message: <3C84A5A3.A1855B05@gmx.de>
> > code.
I just had a look at the 3.1/megapov source and found there is some change
in megapov supplying new interpolation routines, but it isn't activated
(HField->smooth_type is always 1)
The normal calculation code seems fairly understandable although i don't
have time to check it right now.
BTW, i wonder how much slower it would be not to store the normals and
calculate them from the vertices during trace.  This could save a lot of
space when dealing with large heightfields.
Date: 5 Mar 2002 06:41:17
Message: <3c84aedd@news.povray.org>
Actually, after a quick look at the code, I had the idea that that's how it's
done now...
But it was a *very* quick look! :)
cu!
Date: 5 Mar 2002 07:07:09
Message: <3C84B4E8.72BDCFBB@gmx.de>
> done now...
The normals for all vertices are calculated in 'smooth_height_field()' in
hfield.c, the code in 'HField_Normal()' only interpolates these normals.
Date: 5 Mar 2002 08:07:38
Message: <3c84c31a@news.povray.org>
oh, I see :)
cu!
