POV-Ray : Newsgroups : povray.binaries.images : smooth height_fields Server Time
19 Jul 2026 12:03:00 EDT (-0400)
  smooth height_fields (Message 23 to 32 of 32)
Subject: Re: smooth height_fields
Date: 4 Mar 2002 14:40:04
Message: <npi78us6q6d2j26cb36bas87g60s17hhhv@4ax.com>
On Sun, 3 Mar 2002 10:54:44 +0100, "Hugo" <hua### [at] post3teledk> wrote:
>Zeager posted his code in p.b.s-f
>The normals are derived from the vertices.
I haven't had the time to look there, sorry. I'll trust you on this
one :)
>That's true, but a good guess, after all.. The native HF should be able to
>look as good as Zeager's IMO.
Ditto, but I fear it is too late for such deep changes in the 3.5
code.
Having it as a macro in the distro could be useful, though.
Peter Popov ICQ : 15002700
Date: 4 Mar 2002 16:14:56
Message: <3c83e3d0$1@news.povray.org>
>code.
But maybe it should be considered a bug.. There has been other recent
discussions about heightfields and several people have noticed strange
phenomenes like this.. I think we all agree it looks wrong.. I don't know
how complex the sourcecode is but Zeger's is only a few lines.. It's
probably more complex in C, but a bug like this shoudn't really be able to
hide for more than an evening or two.. imho.. (though I'm not skilled in C.)
Hugo
Date: 4 Mar 2002 17:06:25
Message: <chrishuff-2A6C82.17063004032002@netplex.aussie.org>
In article <npi78us6q6d2j26cb36bas87g60s17hhhv@4ax.com>,
> code.
I think it would depend on how hard it is to find and fix. It would be a
bug fix, not a new feature...
Um, have you looked? The HF_Square() macro in shapes.inc doesn't use
this method, but it should give better results, especially when using
entirely procedural height fields.
Date: 4 Mar 2002 18:59:01
Message: <3c840a45@news.povray.org>
"Christopher James Huff" <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
> In article <3c82b7fd@news.povray.org>,
>  "Alf Peake" <alf### [at] peake42freeservecouk> wrote:
> > Its a bit late at night for me but do I understand that I could
use
> > trace() on a vertex and use the returned normal as an average for
all
> > other triangles in a mesh sharing that vertex? I'm referring to
> > MegaPov, not 3.5 and just starting to play with generating
triangles
> > for the first time.
> I'm not sure what you mean here...if you trace a ray directly at a
> vertex of a mesh, there is no way to predict which triangle it will
hit.
> POV certainly won't pick all the possible triangles and average
their
> normals for you. If the mesh is non-smooth, the returned normal will
be
> the normal of any one of the adjacent triangles. You have to compute
a
I'm trying to convert a non-rendered object, blueprints, but with with
known points on the surface. Inventing the wheel. At least I'll
understand the script ;-)  I was trying to figure ways to calculate
the average normal for smoothing.
Your comment made me think that after storing each _unique_ vertex in
an array indexed by the triangle's number I could use trace with each
vertex. It only needs to be used once per vertex and will cover all
triangles sharing that vertex.
#declare Average_Norm = <0,0,0>;
#declare Temp = trace( Object, Vertex*2, -Vertex, Average_Norm );
<wimper> Ahhh! The light dawns - I need Object in the first place. I
don't have it :( Excuse me while I arrange a brain transplant.
</wimper>
Alf
Date: 4 Mar 2002 19:19:47
Message: <3c840f23$2@news.povray.org>
FYI: the image was rendered with POVMan, but I don't think the height_field
code has changed in POV3.5, so it would give the same problems.
cu!
camera{location-z*3}#macro G(b,e)b+(e-b)*(C/50)#end#macro L(b,e,k,l)#local
C=0
;#while(C<50)sphere{G(b,e),.1pigment{rgb G(k,l)}finish{ambient 1}}#local
C=C+1
;#end#end
L(y-x,y,x,x+y)L(y,-x-y,x+y,y)L(-x-y,-y,y,y+z)L(-y,y,y+z,x+y)L(0,x+y,
<.5,1,.5>,x)L(0,x-y,<.5,1,.5>,x)               // ZK
http://www.povplace.be.tf
Date: 5 Mar 2002 01:47:13
Message: <f5q88u8ceh2m2a51338rn85k11o372ho3e@4ax.com>
On Mon, 04 Mar 2002 17:06:31 -0500, Christopher James Huff
Yeah, with a procedural it makes sense to produce better results. And
maybe no one thought of using it with an image as a source :)
I'll have to check whether it looks better with that macro using an
image as a source, with interpolation, of course. Just not today...
Date: 5 Mar 2002 06:02:00
Message: <3C84A5A3.A1855B05@gmx.de>
> > code.
I just had a look at the 3.1/megapov source and found there is some change
in megapov supplying new interpolation routines, but it isn't activated
(HField->smooth_type is always 1)
The normal calculation code seems fairly understandable although i don't
have time to check it right now.
BTW, i wonder how much slower it would be not to store the normals and
calculate them from the vertices during trace.  This could save a lot of
space when dealing with large heightfields.
Last updated 21 Feb. 2002 _____./\/^>_*_<^\/\.______
Date: 5 Mar 2002 06:41:17
Message: <3c84aedd@news.povray.org>
Actually, after a quick look at the code, I had the idea that that's how it's
done now...
But it was a *very* quick look! :)
cu!
Date: 5 Mar 2002 07:07:09
Message: <3C84B4E8.72BDCFBB@gmx.de>
> done now...
The normals for all vertices are calculated in 'smooth_height_field()' in
hfield.c, the code in 'HField_Normal()' only interpolates these normals.
Date: 5 Mar 2002 08:07:38
Message: <3c84c31a@news.povray.org>
oh, I see :)
cu!
