POV-Ray : Newsgroups : povray.binaries.images : smooth height_fields Server Time
20 Jul 2026 05:16:25 EDT (-0400)
  smooth height_fields (Message 13 to 22 of 32)
Subject: Re: smooth height_fields
Date: 2 Mar 2002 14:39:49
Message: <3C812A68.F189BA73@gmx.de>
Zeger Knaepen wrote:
> I really don't understand what you mean.  These two object have exactly the
> same geometry, haven't they?  They are derived from the same pattern, they
> have the same shape, the same height, and in this image the same shading,
> only the way they are smoothed is different.
I would suggest you render a lower resolution version without smoothing so
you can see the single triangles and compare the results.
Last updated 21 Feb. 2002 _____./\/^>_*_<^\/\.______
Date: 2 Mar 2002 14:51:07
Message: <3c812d2b@news.povray.org>
Ok, they are not 100% the same.  But close enough.  The smoothed versions
should not be that different.
I made a mistake in my scene.  The height_field had a resolution of 1 less
than the other version.  I fixed it, and now they *really* have the same
geometry, as you can see in the first attached image...  But still, the
smoothed height_field doesn't look as good as it should, as you can see in
the seconde attached image...
cu!
ZK AKA SaD
http://www.povplace.be.tf
"I want my baby back, baby back, baby back ribs"
Download 'heightfield4.jpg' (19 KB) Download 'heightfield5.jpg' (12 KB)
Preview of image 'heightfield4.jpg'
Preview of image 'heightfield5.jpg'
Date: 2 Mar 2002 15:18:26
Message: <3C813380.CE5FC730@gmx.de>
All right, this seems suited for comparison, it's surely worth having a
look at the heightfield normal calculation code.
Date: 3 Mar 2002 03:01:02
Message: <4nl38ucbrua75pocmb2qjk2pamhrai1tn6@4ax.com>
On Sat, 2 Mar 2002 17:38:38 +0100, "Zeger Knaepen"
<zeg### [at] studentkuleuvenacbe> wrote:
>How does POV-Ray smooth height_fields?  The results aren't really good in
>any case.
What do you expect? It's only a guess at the normals, after all.
>At the left is an ordinary smoothed height_field, at the right the same
>shape using smooth_triangles.
Yeah, and how do you know the normals of those triangles? By
interpolating between vertex positions (which is the only info
available to the hf code) or are you using info from the generating
pattern?
>Wouldn't it be possible to use a better way of smoothing height_fields?
Aside from a different kind of interpolation (higher order), not
really.
Peter Popov ICQ : 15002700
Date: 3 Mar 2002 04:47:35
Message: <3c81f137$1@news.povray.org>
> pattern?
Zeager posted his code in p.b.s-f
The normals are derived from the vertices.
>>any case.
That's true, but a good guess, after all.. The native HF should be able to
look as good as Zeager's IMO.
Hugo
Date: 3 Mar 2002 06:14:15
Message: <3c820587@news.povray.org>
<blabla>
<blabla>
Just for the record: my name is Zeger, not Zeager :)
cu!
ZK AKA SaD
"Two hits: me hittin' you, you hittin' the floor."
Date: 3 Mar 2002 12:44:10
Message: <3c8260ea$1@news.povray.org>
"Zeger Knaepen" <zeg### [at] studentkuleuvenacbe> wrote in message
news:3c80ffa5@news.povray.org...
> any case.
I'm not sure how PoV does it, but it sure runs a lot faster than my
smoothing algorithms. I think that the new height-field macros in shapes.inc
3.5 use a smoothing algorithm more like the one you used. Haven't tried them
yet, though. Anyway, they will write out the vertices so you can do whatever
you like with them.
 -Shay
Date: 3 Mar 2002 14:04:28
Message: <chrishuff-6EB994.14043003032002@netplex.aussie.org>
In article <3c8260ea$1@news.povray.org>, "Shay" <shi### [at] houstonrrcom>
> you like with them.
The macros don't do any sort of normal averaging at all. The method I
used is actually closer to that used for normal perturbation in
textures, the  macros sample the function used to generate the height
field to determine the normal. This might apply to image-based height
fields as well, if interpolation is used, but I haven't tested it.
Date: 3 Mar 2002 18:55:41
Message: <3c82b7fd@news.povray.org>
I
height
height
Its a bit late at night for me but do I understand that I could use
trace() on a vertex and use the returned normal as an average for all
other triangles in a mesh sharing that vertex? I'm referring to
MegaPov, not 3.5 and just starting to play with generating triangles
for the first time.
Alf
Date: 3 Mar 2002 20:47:08
Message: <chrishuff-49380E.20470703032002@netplex.aussie.org>
In article <3c82b7fd@news.povray.org>,
> for the first time.
I'm not sure what you mean here...if you trace a ray directly at a
vertex of a mesh, there is no way to predict which triangle it will hit.
POV certainly won't pick all the possible triangles and average their
normals for you. If the mesh is non-smooth, the returned normal will be
the normal of any one of the adjacent triangles. You have to compute a
normal yourself. The POV 3.5 macros can do it accurately because they
have access to the geometry of the surface around each vertex, not just
the vertices. Averaging the normals of the triangles around the point
usualy produces acceptable results as well, but trace() won't be very
useful for this.
