POV-Ray : Newsgroups : povray.binaries.images : Fourier-Isosurfaces Server Time
19 Jul 2026 11:06:34 EDT (-0400)
  Fourier-Isosurfaces (Message 13 to 22 of 22)
Subject: Re: Fourier-Isosurfaces
Date: 26 Feb 2002 16:49:41
Message: <3c7c02f5$1@news.povray.org>
news:3c7bdf46@news.povray.org...
> I know that this may have a useful application, but I find it very beautiful
> per se!
Thanks!
> I once found a Java applet in which you could play with the first 5
> or 6 fourier coeficients and automatically you would see the periodic
> function graphed. This was kind of the same thing but in 2D. I spent lots of
> time playing with that little applet.
> I've always liked graphics of converging series.
Yes, i can imagine that. I've already written a prog to do fourier-analysis
of sound-files, and spent quite some time filtering around and such, was fun
> Congratulations,
Thank you
> Fernando.
Thies Heidecke
Date: 26 Feb 2002 16:54:24
Message: <3c7c0410@news.povray.org>
"Slime" <noo### [at] hotmailcom> schrieb im Newsbeitrag
news:3c7bf8c6$1@news.povray.org...
> This is an interesting idea, but since you're only working with one series
> per axis, won't that make it impossible to create non-symmetrical shapes?
currently i use one series for all 3 axis(es?), so the shapes are always
symmetrical. but that is just for ease of use while testing. If i use
distinct series for each axis with combined sine and cosine parts there are
no restrictions how the object may look like.
> - Slime
Thies Heidecke
Date: 26 Feb 2002 19:44:43
Message: <omao7u8dbrh4n4l5ndem0r9h9j2fe909ma@4ax.com>
On Tue, 26 Feb 2002 15:32:21 -0500, Alberto Mendoza <jef### [at] usbve>
wrote:
>What about of a Fourier series of a whole scene?
Ladies and Gentlemen, please welcome JPEG-3D!
Seriously, why not? Break up the scene into voxels, then analyze each
voxel separately. It'd be interesting to see how 3D JPEG artifacts
will look.
Peter Popov ICQ : 15002700
Date: 26 Feb 2002 19:56:49
Message: <3C7C2EC4.7E76E2D9@interlog.com>
Thies Heidecke wrote:
> Hi,
> I'm currently experimenting with Fourier-Series as isosurface-functions.
Does this imply the possibility of applying DSP techniques like band-pass
filtering and convolution to the output data sets?  I have no problem with
this in the 1-D and 2-D world so shall I assume that we could, given
sufficient memory and CPU, be able to form spatially smoothed objects by using
a low-pass digital filter to the output from the fourier transform?
Dennis
Date: 27 Feb 2002 11:55:49
Message: <chrishuff-CEECAF.11554327022002@netplex.aussie.org>
In article <omao7u8dbrh4n4l5ndem0r9h9j2fe909ma@4ax.com>,
> will look.
I think this is a fairly common technique, actually.
http://www.google.com/search?q=wavelet+voxel
Date: 27 Feb 2002 13:03:40
Message: <3c7d1f7c@news.povray.org>
Thies Heidecke <h3i### [at] gmxnet> wrote:
> For those who don't know what Fourier-Series are, short explanation:
> The theory behind Fourier-Series is that every (periodic) function can
> be represented through addition of sine/cosine-waves with variable
> amplitude and a frequency that is an integer multiple of a certain
> base frequency.
  I think that the Fourier series definition is more general than that.
IIRC it was something like: Every function can be represented with the
addition of any two orthogonal functions (sin and cos are just one example
of an orthogonal function pair).
Date: 27 Feb 2002 19:18:23
Message: <3c7d774f$1@news.povray.org>
I'd like to synthesize tones from the same parameters; very simple with
additive synthesis. Do you plan to release the code for this work? Very
interesting indeed.
D.
"Thies Heidecke" <h3i### [at] gmxnet> wrote in message
news:3c7bb095@news.povray.org...
> Hi,
Date: 27 Feb 2002 19:34:05
Message: <3c7d7afd@news.povray.org>
> interesting indeed.
> D.
I would also like to see this code.  Could have lots of fun playing around!
David
smuchrusher <at> ameritech <dot> net
ICQ#: 118347772
3:16pm up 16:34, 0 users, load average: 1.13, 1.08, 1.04
Date: 28 Feb 2002 00:57:24
Message: <3c7dc6c4@news.povray.org>
"Dennis Miller" <dhm### [at] attbicom> schrieb im Newsbeitrag
news:3c7d774f$1@news.povray.org...
Sure, i will release the code if someone is interested, but at the moment
the code is just experimental and not very well structured. I wanted to
post a final version as a nice .inc-file but if u like i can post what i
have so far.
> Very interesting indeed.
Thanks
> D.
Thies Heidecke
Date: 28 Feb 2002 01:21:24
Message: <3c7dcc64@news.povray.org>
"David F" <smu### [at] ameritechnet> schrieb im Newsbeitrag
news:3c7d7afd@news.povray.org...
> > interesting indeed.
> > D.
ok, i just posted the source in p.b.s-f.
have fun with it
Thies Heidecke
