POV-Ray : Newsgroups : povray.binaries.images : SEM neuron Server Time
16 Jul 2025 14:05:03 EDT (-0400)
  SEM neuron (Message 11 to 20 of 20)
Subject: Re: SEM neuron
Date: 20 Feb 2002 12:26:35
Message: <3c73dc4b$1@news.povray.org>
> Check out www.uq.edu.au/nanoworld they have a database of SEM and TEM
> images.  The "Mystery Images" section seems pretty good.
Cool! Great reference images. Thanks.
> I think people would murder to get real images as good as yours...
Again, I wish I could mess it up a little with some displacement in the
mesh.
Date: 20 Feb 2002 12:28:12
Message: <3c73dcac@news.povray.org>
> Cool pic!
> I like it a lot.
Thanks.
> IMHO there should be something in the background, since the SEM probes are
> mounted on some surface before they get a gold coat, right?
I think your right, but I didn't like how it looked on a plane, so enter
artistic license.
John
Date: 20 Feb 2002 13:34:59
Message: <3c73ec53$1@news.povray.org>
"John Bradshaw" <joh### [at] nospamhotmailcom> wrote in message
news:3c73dbcf@news.povray.org...
>> Your image gives the feeling that the detector is in the center of
>> the sample, if there's not multiple light sources.
> I've added another light source about 80 degrees to the right, we'll see
if
> that helps.
Ooops. I meant it should be more like a single light source, fwiw.
Date: 20 Feb 2002 14:50:43
Message: <MPG.16de1c84b9b053b89896c4@news.povray.org>
In article <3c73c919$1@news.povray.org>, "Greg M. Johnson" <gregj:-)
565### [at] aolcom> says...
> news:3c72e14a@news.povray.org...
> > Also, would like comments on the scanning electron microscope effect. It's
> > not quite where I want it to be, but getting there. (see previous post SEM
> > texture)
> I reviewed that teapot image with an SEM expert and these were our comments
> there, many of which would apply to your image...
> An SEM has a detector off to one side.  So in effect surfaces which face the
> detector will be brighter (higher collection yield) than those which face
> away. Your image gives the feeling that the detector is in the center of the
> The image rightly shows how surfaces which are normal to the "camera" ie.,
> incident beam are brighter. Again, the secondary electron detection yield is
> higher as well on these surfaces.   This is a good *pigment*, FWIW.
> It looks, however, as if it were stainless steel, with very little beam
> penetration into the sample.  Contrast this with "record 22 of 700; Title:
> 'Blood cell' " in the image gallery at.
> http://www.uq.edu.au/nanoworld/images_1.html
> For an organic, low-atomic-number sample, I'd expect there to be some
> translucency, almost a 'media' effect, as in that blood cell image
> The "etched steel" effect in your texture normal is a bit troublesome.  Here
> the concern is not so much with SEM physics but with the intuitive feel of
> cells: things should be more round, even like "Lung surface: image 39 of
> 700" at that gallery.
> _________
> Greg M. Johnson
> 10-yr SEM user
It is true that a SEM has a detector somewhere to one side, but this
doesn't mean in any way that the resulting image can be compared to an
object illuminated by the detector as the light source!
The secondary electrons that make up the SEM image can very well
originate at the opposite side of the object. These electrons are low
energy particles and travel slowly, so their paths are easily bent.
And what i really miss in these images is the so-called "Kanten Effekt"
characteristic to SEM images. In short this means that thin and sharp
parts of the object show up much lighter than the more even and smooth
parts.
In general the image looks a bit like an SEM image...  :))
Sander (who spent half his working life behind an SEM!)
Date: 20 Feb 2002 16:55:20
Message: <3c741b48$1@news.povray.org>
"Sander" <san### [at] stolscom> wrote in message
news:MPG.16de1c84b9b053b89896c4@news.povray.org...
I just saw some SEM's where the "north-facing slope" of raised features is
darker than the "south slope".  The question is one of different detection
efficiency.  What do you think of the "double illumination" effect of the
teapot image??
My mentor has left for the day and all Yahoo! searches of this term end up
with German web sites........
Date: 20 Feb 2002 17:09:50
Message: <3c741eae$1@news.povray.org>
> parts.
Do you have an example of this effect? Could it be simulated with media?
Date: 20 Feb 2002 18:31:23
Message: <3c7431cb$1@news.povray.org>
John Bradshaw <joh### [at] nospamhotmailcom> schrieb in im Newsbeitrag:
3c741eae$1@news.povray.org...
> > parts.
I have. The sawtooth-like structures in the upper part of the picture get
thinner on the right side. So more secondary electrons emerge from the
sample which brighten up the image in that parts. ("Kante" means "edge", for
those who don't speak german.)
BTW, there _can_ be a "directional lighting" in SEM images. It just depends
on how much voltage you apply to the detector grid. If, for example, the
voltage is zero, you collect only those electrons flying directly into the
detector, leaving the surfaces facing away from it completely dark.
In POV you could perhaps simulate SEM images by radiosity. If you put a thin
horizontal ring around the scene, with ambient=1 all parts facing horizontal
would be the brightest, and all facing vertical would be the darkest,
assumed the camera is looking along -y.
Michael
Date: 20 Feb 2002 18:32:13
Message: <3c7431fd@news.povray.org>
D'oh!
Download '33412_1.JPG' (42 KB)
Preview of image '33412_1.JPG'
Date: 21 Feb 2002 06:18:41
Message: <3C74D785.6E3C8ACA@namtar.qub.ac.uk>
Yowch! This one's scary...
36/700  http://www.uq.edu.au/nanoworld/images_1.html
signature{
Date: 21 Feb 2002 07:01:57
Message: <MPG.16df002147b7105b9896c6@news.povray.org>
In article <3c7431cb$1@news.povray.org>, zie### [at] atlantiswh2tu-dresdende
says...
True: in that case you collect back-nscattered electrons only.
> Michael
Sander
