POV-Ray : Newsgroups : povray.binaries.images : It's not friday, and it's not meant to be an abstract, but anyway... Server Time
15 May 2026 12:53:54 EDT (-0400)
  It's not friday, and it's not meant to be an abstract, but anyway... (Message 1 to 10 of 10)
Subject: It's not friday, and it's not meant to be an abstract, but anyway...
Date: 18 Feb 2002 17:23:33
Message: <3c717ee5@news.povray.org>
I knocked this together at lunch time. It's not supposed to look like this, but
some interesting errors occured in the media formula! I particularly like the
line of ufos that appeared in the first image, I didn't put them there!!
I found that I could remove these "errors" by reducing the size of the object
the media is in and increasing the samples, but I thought I'd post the error
'cause it looks much nicer than the proper version!
For those who are curious, the media density looks like this:
    density {
     function {
      1/(0.001 + sqrt(x*x + z*z)*y)
     scale 1000
     translate -10*y
     poly_wave 3
     colour_map {
      [0 rgb 0]
      [1000 rgb 10]
Though the formula was a bit different for the first image.
Do you like it?
Tek
http://www.evilsuperbrain.com
Download 'spikemedia1.jpg' (28 KB) Download 'spikemedia2.jpg' (37 KB)
Preview of image 'spikemedia1.jpg'
Preview of image 'spikemedia2.jpg'
Subject: Re: It's not friday, and it's not meant to be an abstract, but anyway...
Date: 18 Feb 2002 17:51:11
Message: <chrishuff-C300D6.17505618022002@netplex.aussie.org>
The inner surface of an space ring structure, like Larry Niven's
Ringworld or Bungie's HALO?
Can't really tell for sure...if there is any solid ring, it is hidden by
the media, but that looks like the curve of a ring rising up above.
Date: 18 Feb 2002 19:22:38
Message: <3c719ace@news.povray.org>
Nope, it's just a spike. y=1/x, kinda thing (okay slightly more complicated than
that but that's the basic shape).
I was thinking of the Final Fantasy games when I did it, they have a tendency to
have those kinds of gigantic glowing spikes sticking up into the sky whenever
there's some serious magic going on. They even have one at the end of the film
Tek
Christopher James Huff <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
Date: 19 Feb 2002 09:48:55
Message: <3c7265d7@news.povray.org>
"Tek" wrote:
>Do you like it?
I think it's great! The second image looks like a contrail left
by some space-warping stardrive :)
- Pete.
Date: 20 Feb 2002 20:43:50
Message: <slrna78jhq.mp3.steve@zero-pps.localdomain>
They turned out really good, wish I could have errors like that:-)
                                             or http://start.at/zero-pps
  1:32am  up 5 days,  7:21,  1 user,  load average: 1.02, 1.04, 1.06
Date: 20 Feb 2002 22:54:34
Message: <3C746F79.2001088A@earthlink.net>
Ok i'm a lil lost... I clipped the density but i just get a lot of static when i
apply it to an object... How did you do this... ???
>     density {
>      function {
>      scale 1000
>      translate -10*y
>      poly_wave 3
>      colour_map {
>       [0 rgb 0]
>       [1000 rgb 10]
> Do you like it?
> Tek
Date: 21 Feb 2002 14:27:54
Message: <3C754A30.4ACB37AB@spiritone.com>
It's beautiful! Both images!
I'm a little confused by the color_map, though. I though all color_map
indexes had to be between 0 and 1
Josh English
eng### [at] spiritonecom
http://www.spiritone.com/~english
Date: 21 Feb 2002 19:22:28
Message: <3c758f44$1@news.povray.org>
Well it depends what type of media you're using. If you're using POV 3.5 it
defaults to method 3, but in megapov it uses method 1 by default IIRC. I'm using
3.5, so you should probably just put "method 3" somewhere in the media
statement.
For reference, I'll put the source in p.b.s-f :)
Tek
Ryan Mooney <rdm### [at] earthlinknet> wrote in message
news:3C746F79.2001088A@earthlink.net...
i
but
the
object
> >     density {
> >      function {
> >      scale 1000
> >      translate -10*y
> >      poly_wave 3
> >      colour_map {
> >       [0 rgb 0]
> >       [1000 rgb 10]
> > Do you like it?
> > Tek
> >  [Image]
> >  [Image]
Date: 21 Feb 2002 19:30:56
Message: <3c759140$1@news.povray.org>
Josh English <eng### [at] spiritonecom> wrote in message
news:3C754A30.4ACB37AB@spiritone.com...
Thank you :)
I confess I'm not entirely sure of the limitations. I think colour maps may span
any range, but obviously only values the pigment formula uses will be used. So
in this case my function is in the range 0 to 1000, so I use that for my colour
map. But maybe it just clamps the values at 1...
Tek
Date: 21 Feb 2002 20:36:49
Message: <3C75A0B1.B1A70882@earthlink.net>
Thanks... =]
I guess i will have to make my way to 3.5... i am reluctant though... Like dragging
a bat into the light.... =] I would like to see the color scheme as well... Not one
of my bat areas... Even when i draw on paper i find it hard to incorporate color...
> statement.
> Tek
> i
> but
> the
> object
> > >     density {
> > >      function {
> > >      scale 1000
> > >      translate -10*y
> > >      poly_wave 3
> > >      colour_map {
> > >       [0 rgb 0]
> > >       [1000 rgb 10]
> > > Do you like it?
> > > Tek
> > >  [Image]
> > >  [Image]
