POV-Ray : Newsgroups : povray.binaries.images : Spiral wrapped around a sphere. How? Server Time
27 Mar 2026 15:09:23 EDT (-0400)
  Spiral wrapped around a sphere. How? (Message 1 to 6 of 6)
Subject: Spiral wrapped around a sphere. How?
Date: 3 Feb 2002 18:42:42
Message: <3c5dcaf2@news.povray.org>
I've posted information about this image in povray general.
I'm requesting some help for creating a small object.  I want to basically
wrap a rounded spiral around a sphere.
Patrick Dugan
Download 'SpiralSphere.jpg' (11 KB)
Preview of image 'SpiralSphere.jpg'
Subject: Re: Spiral wrapped around a sphere. How?
Date: 3 Feb 2002 18:53:40
Message: <3c5dcd84@news.povray.org>
This is probably the simplest way
Just start at the top
Put an object at <cos(pi/2)*radius, sin(pi/2)*radius, 0>
Incremently increase your angle from pi/2 to 3*pi/4
each time you place an object, rotate it a little bit around the y-axis
Hope this helps,
 -Shay
"Patrick Dugan" <pat### [at] netinsnet> wrote in message
news:3c5dcaf2@news.povray.org...
Date: 3 Feb 2002 20:02:39
Message: <3c5dddaf$1@news.povray.org>
Well I probably butchered the formula but here is what I made:
#declare MinRad = pi/2;
#declare MaxRad = (3*pi/4)*10;
#declare Test =
union {
   #while (MinRad < MaxRad)
      object {sphere {<0,0,0>, 0.1 translate <cos(MinRad)*1, sin(MinRad)*1,
MinRad/10> pigment {Red}}}
   #declare MinRad = MinRad + 0.01;
object {Test rotate x * -90 translate <0,-2,0>}
This created a spiral but always the same distance from the center.  I was
trying to make something that would get closer to the center as it moved up
or down.
What did I do wrong?  (I'm sorry my math skills are really poor...)
"Shay" <shi### [at] houstonrrcom> wrote in message
news:3c5dcd84@news.povray.org...
> Hope this helps,
>  -Shay
Date: 3 Feb 2002 20:17:47
Message: <3c5de13b$1@news.povray.org>
I'm sorry. 3*pi/4 should have been 3*pi/2
You don't need to translate the spiral any along the y-axis. Setting x and y
to the cos and sin of the angle will do that for you.
The formula itself zill make a half-moon arc. Rotating each sphere some will
give you the twist.
Like this:
#declare MaxRad = (3*pi/2);
#declare Test =
union {
      object {sphere {<0,0,0>, 0.01 translate <cos(MinRad)*1, sin(MinRad)*1,
0> rotate y*degrees(MinRad)*20 pigment {rgb <1,0,0>}}}
   #declare MinRad = MinRad + 0.0001;
object {Test /*rotate x * -90 translate <0,-2,0>*/}
#declare Test =
union {
news:3c5dddaf$1@news.povray.org...
Date: 3 Feb 2002 20:29:36
Message: <3c5de400@news.povray.org>
That is perfect!!
Thank you!
news:3c5de13b$1@news.povray.org...
y
will
> give you the twist.
> Like this:
> #declare Test =
> union {
sin(MinRad)*1,
>    #end
> #declare Test =
> union {
sin(MinRad)*1,
>    #end
Date: 3 Feb 2002 22:09:40
Message: <3C5DFAD7.DE3572E7@hotmail.com>
> give you the twist.
> Like this:
> #declare Test =
> union {
>    #end
> #declare Test =
> union {
>    #end
Also try this:
#declare SphereRadius = 1.5;
#declare SpiralRadius = 0.05;
#declare NrOfTurns = 5;
#declare NrOfSpheres = 1000;
#declare dAngle = 180/NrOfSpheres;
#declare SphereSpiral =
union {
  #declare Cnt = 0;
  #while (Cnt < NrOfSpheres)
    sphere {
      -SphereRadius*y, SpiralRadius
      rotate Cnt*dAngle*<1, 2*NrOfTurns, 0>
    #declare Cnt = Cnt + 1;
  #end // while
object {
  SphereSpiral
  pigment { color rgb <1, 1, 1> }
light_source { <-2, 2, -3>*10 color rgb <1, 1, 1> }
  location <0, 1, -2>*2
  look_at <0, 0, 0>
Tor Olav
