POV-Ray : Newsgroups : povray.binaries.images : Art gallery IRTC WIP (52kbu) Server Time
23 Jun 2026 23:27:51 EDT (-0400)
  Art gallery IRTC WIP (52kbu) (Message 1 to 10 of 20)
Subject: Art gallery IRTC WIP (52kbu)
Date: 1 Feb 2002 09:25:15
Message: <3c5aa54b@news.povray.org>
Version 2
Still need to do the lights and add some water around the fish and
perhaps a subtle normal to the wall.
The fish is a poser model and the pictures in the frames were created
in vue d'espirit
Comments?
Gail
#macro G(H,S)disc{0z.4pigment{onion color_map{[0rgb<sin(H/pi)cos(S/pi)*(H<6)
cos(S/pi)*(H>6)>*18][.4rgb 0]}}translate<H-5S-3,9>}#end G(3,5)G(2,5.5)G(1,5)
G(.6,4)G(.5,3)G(.6,2)G(1,1)G(2,.5)G(3,.7)G(3.2,1.6)G(3.1,2.5)G(2.2,2.5)G(9,5
)G(8,5.5)G(7,5)G(7,4)G(7.7,3.3)G(8.3,2.7)G(9,2)G(9,1)G(8,.5)G(7,1)//GS
Download 'Painting.jpg' (52 KB)
Preview of image 'Painting.jpg'
Subject: Re: Art gallery IRTC WIP (52kbu)
Date: 1 Feb 2002 10:22:19
Message: <3c5ab2ab@news.povray.org>
<envy-suppressing mode>
Your concept keeps getting better and better.
That said, two comments: the surface of the water (ripples) seems too
regular, and could use some water drops emerging as the fish passes. Also,
did you try ro get parto of the fish tail to be inside the painting? I don't
even know if such is possible, but I believe that the emerging effect would
be improved if such was possible.
Keep up the good work.
Ruy
</envy-suppressing mode>
Date: 1 Feb 2002 11:39:23
Message: <3c5ac4bb$1@news.povray.org>
Ruy <ruy### [at] hipernetcombr> wrote in message news:3c5ab2ab@news.povray.org...
> Ruy
And a splash in the water from the fish breaking the surface.
That would add to the effect I think.
Tom Bates
#macro T(B)#local m=mod(B,8);#local B=floor(B/8);m#end#local C=126981491245202;#
local D=115694168992822;sphere_sweep{b_spline 16#local i=0;#while(i<16)<T(C)-4,T
(D)-4,10-i/10>.1#local i=i+1;#end pigment{rgb 1}}light_source{-10,1} //Tom Bates
Date: 1 Feb 2002 16:09:50
Message: <3C5B03C3.8040508@tiac.net>
Very nice. Definately needs water splashing and if
you can bend the fishes tail it might give it a little
more life.
Phil
Behold, for I am the keeper of the sacred coffee brewing method.
Date: 2 Feb 2002 00:35:39
Message: <slrna5mj3q.66o.steve@zero-pps.localdomain>
On Fri, 1 Feb 2002 16:24:51 +0200, Gail Shaw wrote:
> Version 2
How about some leaves of one of the trees sticking out too.
The fish jumping out is a great idea, how about a goldfish bowl on top
of that pedestal instead of the fractal, and a small goldfish inside it.
#local i=.1;#local I=(i/i)/i;#local l=(i+i)/i;#local ll=(I/i)/l;box{<-ll,
-((I/I)+l),-ll><ll,-l,ll>pigment{checker scale l}finish{ambient((I/l)/I)+
(l/I)}}sphere{<i-i,l-l,(I/l)>l/l pigment{rgb((I/l)/I)}finish{reflection((
I/l)/I)-(l/I)specular(I/l)/I}}light_source{<I-l,I+I,(I-l)/l>l/l} // Steve
Date: 2 Feb 2002 02:02:19
Message: <3c5b8efb$1@news.povray.org>
Or a goldfish painting floating just under the surface in the bowl... kinda
like a reverse of roles.  yin yang
Date: 2 Feb 2002 05:33:54
Message: <3C5BC0F0.9030809@web.de>
Gail Shaw wrote:
> Version 2
> in vue d'espirit
> Comments?
> Gail
Shouldn't the fish be in the image on the wall? :-)
Subject: Re: Art gallery IRTC WIP (16kbu)
Date: 2 Feb 2002 05:34:15
Message: <3c5bc0a7@news.povray.org>
"Ruy" <ruy### [at] hipernetcombr> wrote in message
thank you
Painting still needs work.
> Also,
don't
would
The fish tail is part of the painting. the image that's used in the painting
is attached.
Anything is possible (within reason) it's just a case of how much time you
are
willing to spend. Aligning the fish model with the picture so that it looks
like one
fish took the better part of two days of tweak and render.
Gail
Download 'Pond.jpg' (17 KB)
Preview of image 'Pond.jpg'
Date: 2 Feb 2002 05:35:15
Message: <3c5bc0e3@news.povray.org>
"Phil Clute" <pcl### [at] tiacnet> wrote in message
news:3C5### [at] tiacnet...
> more life.
It's as bent as I can. The poser model's not very good and
angles larger than I have make it look broken :-<
Gail
Date: 2 Feb 2002 05:35:44
Message: <3c5bc100@news.povray.org>
"Steve" <ste### [at] zeroppsuklinuxnet> wrote in message
news:slr### [at] zero-ppslocaldomain...
Sounds good
Gail
