POV-Ray : Newsgroups : povray.binaries.images : A fearful monster (60kbu) Server Time
3 May 2026 08:57:33 EDT (-0400)
  A fearful monster (60kbu) (Message 15 to 24 of 24)
Subject: Re: A fearful monster (60kbu)
Date: 14 Jan 2002 19:57:36
Message: <3C437DEE.6080102@videotron.ca>
Gail Shaw wrote:
> Bill DeWitt wrote in message <3c42dd94$1@news.povray.org>...
>>"Francois Labreque" <fla### [at] videotronca> wrote :
>>>But, but, but... she can't.  According to my worn out copy of the AD&D
>>>Monster Manual, the Beholder needs that big eye.[1]
>>   Ah... I thought 'Beholder" was her own name (Never played the game).
> No. I chose it 'cause I thought it'd be an easy intro to organic modelling.
> Easy is one thing it wasn't <grin>
> For those who don't know, here's the description of the beholder from the
> AD&D
> monsterous manual
> "The beholder is the stuff of nightmares. This creature, also called the
> sphere of
> many eyes or the eye tyrant, appears as a large orb dominated by a central
> eye
> and a large toothy maw, has 10 smaller eyes on stalks sprouting from the top
> of the orb.
Yours only has 9.
/*   videotron.ca  */}camera{location<6,1.25,-6>look_at a orthographic}
Date: 14 Jan 2002 20:25:36
Message: <3C43876A.E21DFEF9@aol.com>
I think you just need to cook it somemore.  Make the maw more maw-like, with
protruding teeth, and maybe more ragged around the lips.  Maybe pus and scabbing
around the edge of the eye.  Work the eye some more, maybe with some radial
texturing to make it look veined.
Date: 15 Jan 2002 00:09:19
Message: <3c43b97f$1@news.povray.org>
"JRG" <jrg### [at] hotmailcom> wrote in message news:3c435546@news.povray.org...
> Apart from a SDL boning system include file (something for the brave ones) I
don't
> think that's possible at all...
I disagree. I hope to prove it before the year is out. That gives me awhile to
work out all of the details. :)
light_source{0,1}#macro c(J,a)sphere{0,1pigment{rgb z}scale a translate J+O}
#end#macro B(R,V,O)c(0,4)intersection{c(V,R)difference{c(-z*4x+10)c(-z*4.1x+
10)c(0<7.5,45,5>)}}#end B(12,0z*25)B(8y*4<0,12,50>)          // Batronyx ^"^
Date: 15 Jan 2002 00:33:44
Message: <3c43bf38@news.povray.org>
"Gail Shaw" <gsh### [at] monotixcoza> wrote in message
news:3c42b0ba@news.povray.org...
> A beholder model I've been working on for a couple of months in Rhino. It's
> supposed to look terrifying. Looks to me more like it's terrified <g>
I never got into D&D or anything like that. Have you seen Monsters Inc., or any
shots of it on the web? This looks like it could be one of Mike Wakowski's
offspring. ( He was dating a one eyed medusoid character).
The main thing that makes yours look terrified is the facial expression.
Close the eye more, make the mouth more narrow laterally and then pull the
corners down some more while raising the upper lip towards each side(snarl)
v-down the head lump similar to the shape of a pair of angrily knitted eyebrows.
Aww heck! Here's a cheesy PSP clone 'n' smudge to show you what I'm trying to
say.
Download 'beholder2_post.jpg' (66 KB)
Preview of image 'beholder2_post.jpg'
Date: 15 Jan 2002 00:40:17
Message: <3c43c0c1@news.povray.org>
"Francois Labreque" <fla### [at] videotronca> wrote in message
news:3C4### [at] videotronca...
> Yours only has 9.
Lost one in a fight.  (I got lazy)  Pick your prefered reason.
Gail
#macro G(H,S)disc{0z.4pigment{onion color_map{[0rgb<sin(H/pi)cos(S/pi)*(H<6)
cos(S/pi)*(H>6)>*18][.4rgb 0]}}translate<H-5S-3,9>}#end G(3,5)G(2,5.5)G(1,5)
G(.6,4)G(.5,3)G(.6,2)G(1,1)G(2,.5)G(3,.7)G(3.2,1.6)G(3.1,2.5)G(2.2,2.5)G(9,5
)G(8,5.5)G(7,5)G(7,4)G(7.7,3.3)G(8.3,2.7)G(9,2)G(9,1)G(8,.5)G(7,1)//GS
Date: 15 Jan 2002 00:43:33
Message: <3c43c185@news.povray.org>
"Rune" <run### [at] mobilixnetdk> wrote in message
news:3c434591@news.povray.org...
> I really like this one! :)
> I also agree with many of the suggestions from the others though.
> Rhino exports a mesh (or similar) which is then used in POV-Ray, right?
Will
> it be possible to animate it then?
I exported to obj so I could run it through UV-mapper then converted the obj
to pov (though I had a lot of problems with that conversion)
Theoretically it's possible to animate. Not sure how practical though.
Gail
Date: 15 Jan 2002 01:08:48
Message: <3c43c770@news.povray.org>
"Batronyx" <bat### [at] alliancecablenet> wrote in message
news:3c43bf38@news.povray.org...
side(snarl)
eyebrows.
to
> say.
Much closer to what I intended. I did some changes to the model last
night and got it looking a bit better. Still need to change all the
eyestalks.
Gail
Date: 15 Jan 2002 12:46:06
Message: <3c446ade@news.povray.org>
Hmm, do you mean something like the PCM macros? Morphing between two meshes with the
same number of triangles? Or something completely different?
#local j=text{ttf"arial""JRG".2,0}#local J=0;#while(J<10)#local R=0;#while
(R<2)#local G=0;#while(G<1)#if(inside(j<R,G.1>))object{j scale.025translate
<R-1G-J/20J/-40+2>pigment{rgb<9J>}}#debug"O"#else#debug" "#end#local G=G+
.025;#end#local R=R+.05;#debug"\n"#end#local J=J+1;#end// JRG
Home: http://digilander.iol.it/jrgpov  //New: Kitchen scene WIP
"Batronyx" <bat### [at] alliancecablenet> ha scritto nel messaggio
news:3c43b97f$1@news.povray.org...
> don't
Date: 15 Jan 2002 22:22:59
Message: <3c44f213@news.povray.org>
"JRG" <jrg### [at] hotmailcom> wrote in message news:3c446ade@news.povray.org...
with the
That's more or less exactly what I'm talking about. That is completely possible
now. However, as Rune once pointed out when I mentioned this before, the current
set of morphing macros use linear interpolation and that would require a lot of
'key' meshes to get anything smooth.
Initially, I thought that wasn't really an issue because that's exactly how
Imagine for Windows implements its morphing routines. However, upon further
thought, Imagine likely uses an optimized internal format for storing the state
data. Using the PCM macros would require "a lot" of data and "a lot" of drive
space. Much more than the .iob file Imagine creates, even if the PCM files are
compressed.
I've been stewing on another method to use the .pcm file just once (or at least
with much fewer key-states). This likely means a custom morphing macro or two,
and some thought on how to get this all set up in a useable manner.
Date: 17 Jan 2002 18:52:47
Message: <K2JHPP7PstD+sH4NtUAp9jCIyxTR@4ax.com>
On Mon, 14 Jan 2002 12:19:34 +0200, "Gail Shaw" <gsh### [at] monotixcoza>
with one eye it's a obviously a lot more difficult to put some expression
in there, but how about this:
Make the top center of the eyeball curve down a little, so you put a bit of
a 'frown' at the top of the eye... that way you don't have the big-eyed
'surprise'-look it currently has...
Pretty good model, btw.
Marc van den Dikkenberg
The PowerBasic Archives -- http://www.xlsior.org
