Nice first effort. Good window frame.
Here are some tips:
- Do not use fully saturated colors. The wall looks a bit too orange and the green
grass is, well, a bit too green. If your pic starts to look like a cartoon, that's
the sign that you have to lower the saturation (it's pretty simple if you're using
HBS).
- Forget finish ambient, or make it as low as possible. Either use radiosity or a
shadowless fading light_source (placed at the same location of the camera).
- Add a bit of specular to every material. For the wood something like 0.1-0.3 should
be good.
- Remember that normals add to the overall realism of the scene. Get used to them.
- Dirt it up! Add a partially transparent layer of dirt to your textures.
- Clutter. Those block are placed with a rule ;)
- Use area lights.
- Put glass panels on your window to repair from wind ;)
Question: is this a present for you chat friend? :-D
#local j=text{ttf"arial""JRG".2,0}#local J=0;#while(J<10)#local R=0;#while
(R<2)#local G=0;#while(G<1)#if(inside(j<R,G.1>))object{j scale.025translate
<R-1G-J/20J/-40+2>pigment{rgb<9J>}}#debug"O"#else#debug" "#end#local G=G+
.025;#end#local R=R+.05;#debug"\n"#end#local J=J+1;#end// JRG
Home: http://digilander.iol.it/jrgpov //New: Kitchen scene WIP
"MR" <a### [at] b net> wrote in message news:3c39af17@news.povray.org...
> hi everybody!
> long time listener, first time image-poster.
A fan of talk radio?
> 1. so you grow your grass in rows in indiana just like your
> corn?
psssst. If you told us it was 'young' corn to begin with, you wouldn't have to
cover here. ;D
> 1. that picture frame is awesome! can i get the code for it?
The picture frame really is the best thing in the picture. Great job there.
> 4. would you like to meet my sister?
I would consider this, but, there seem to be romantic overtures in the picture
itself. I might be messing up something. :)
light_source{0,1}#macro c(J,a)sphere{0,1pigment{rgb z}scale a translate J+O}
#end#macro B(R,V,O)c(0,4)intersection{c(V,R)difference{c(-z*4x+10)c(-z*4.1x+
10)c(0<7.5,45,5>)}}#end B(12,0z*25)B(8y*4<0,12,50>) // Batronyx ^"^
> hi everybody!
> long time listener, first time image-poster. i've got a ton
> of time in this. mostly just coming up to speed, and some
> time (like playing with moray) that wasn't ever incorporated
> into the picture. thanks to gilles for the grass and trees,
> and i couldn't find a name in the alphabet block include.
Nice. The grass looks just like the mielie fields round here <grin>
The window frame is very nice
Suggestions and nitpicks
Tone down the sunlight, and use an arealight for the sun.
Slightly dirty glass in the window
are the blocks and frame on the floor or a desk? Looks like the floor
(no gap between the edge and the wall and level with the base of the
tree)
A texture on the desk. Looks like it's just pigment {White} at
the moment
Gail
* gsh### [at] monotix co za * Chaos, disorder and panic *
* http://www.rucus.ru.ac.za/~gail/ * My job here is done. *
* Just think of me as the storm before the calm Magic: The Gathering*
hi steve,
thanks for the words of encouragement. i really enjoyed
doing the image. and yes, its probably "overdone." the
image evolved as i went. at first i was gonna have the
scene pointed towards a monitor and keyboard, with the
photo and the window off to the side, but i changed my
mind. i'm not even gonna talk about how many times i
jockeyed the camera and light position. and although i did
wrestle with the media demon (i lost), i never fooled with
radiosity.
in the end, i knew that i just didn't know what was right.
but at least i knew that.
thanks again, miker
povray and the people that use it never
ceased to amaze me. i'm not a good artist, and i doubt
that i ever will be. but i am sorta math and physics oriented,
and the way that povray
"Steve" <ste### [at] zeropps uklinux net> wrote in message
news:slr### [at] zero-pps localdomain...
> The trees and sky look good, and I like the window frame.
> I think that using the alphabet blocks is a bit over the top
> for this scene, the words would look good carved into the
> table roughly or written in condensation on the window.
> A great first scene, you can be proud of it, I look forward
> to seeing your work in the future.
hi grimdude,
i'm just sucking up everybody's suggestion like a sponge. your
comment about adding a texture beyond the grass is interesting.
and so is your comment about adding a surface normal to the
wall. i had thought it needed a texture. i know that a normal is
a line perpendicular to a surface, but i'll have to look into what
you're talking about. my only experience with messing with the
normal has been a brief encounter with smoothed meshes and
i believe thats how bump maps are done, too.
and radiosity is definitely something i want to experiment with,
but it scares me. i don't really have any "instinctive" feel yet for
what kind of effect different code will have on an image. my
standard operating procedure involved a small tweak and then
rerendering. i'll bet i rendered the scene a thousand times. no
kidding. and anything that dramatically increases the render
time slowed my work down to a snail's pace. thats why i'm nervous
about radiosity.
thank you for your comments and encouragement.
miker
"GrimDude" <vos### [at] gulf net> wrote in message news:3c3a09c6@news.povray.org...
> I understand about first images.
> You might consider a few things, though you suggested not commenting in
some excellent directions.
> 1) Adding glass would add to the realism.
> 2) Decrease the grass elements by bunching them up tighter close to the
house, and then add a turbulated texture beyond that in the
> same color. This would help preserve the impression that grass covered the
view, without increasing the render time dramatically.
> 3) Add a surface normal to the walls and counter/desk surface.
> 4) Use an area light.
> 5) Render with radiosity and use the 'normal on' statement.
> For a first post you have created quite a scene and it came off very well!
> Grim
hi jrg,
oh yeah! i could look at the image and see most of those problems
that you mentioned. BUT, i didn't have any idea how to remedy
them. you gave me a lot of good ideas on surface modelling, like
specularity, color saturation, ambience, and normals.
and thanks for phrasing them for a beginner. knocking down on
color saturation to reduce the cartoon effect is straightforward.
and so was everything else, like bailing on finish ambience and
adding specular. i need to do some renders and get a feel for
this.
thanks for your comments and encouragement. and yes, you hit
the nail on the head with your question... it was a christmas gift.
thank goodness its the thought that counts. hahaha.
miker
"JRG" <jrg### [at] hotmail com> wrote in message
news:3c3a30db@news.povray.org...
> Here are some tips:
the green
cartoon, that's
you're using
> HBS).
radiosity or a
camera).
0.1-0.3 should
> be good.
to them.
> - Use area lights.
scale.025translate
"MR" <a### [at] b net> wrote in message news:3c39f535$1@news.povray.org...
> now cut that out! ;-) and yes! you are confused, cuz thats not my
> sister or me in the picture. she's a chat friend from the internet.
> i think we need to concentrate more on my image and less on my
> sister. NO! wait! not MY sister... your sister! no, wait... its not
> your sister either! thats not what i meant! oh, heck with it! ;-)
Well now I've gone right off your sister and wouldn't want to meet her
with a ten foot pole. But if -you- want to meet... the same place.. wear
white and be holding a single red flower.
hi batronyx,
yeah, the grass thing really made me smile. like i mentioned
earlier, i used a standard square patch that gilles had used as
an example, and i simply tiled it. there were so many tiles i
had to write a loop macro to do it. i not only incremented x and
z, but the grass was sorta thin so i overlapped it.
when i seen the row pattern, i dug into the documentation, and
figured out how to work with random and added a randomness
to the tiling, along with even some random rotation of the patch.
when the code was finished i was very proud of it... of course it
didn't do a darn thing as far as eliminating the rows. hahaha.
thanks, miker
hi gail,
thank you for your comments. i think i'm going to give the image
a month or two rest and then attack it again. i needed a break
from it. i spent about 3 months working on that thing! of course,
like i mentioned earlier, i'm counting in a lot of stuff that never
even showed up in the picture, like working with patches and
the texture editor in moray, and my failed attempts with media.
another thing... i thought that because the image was obviously
newbie-ish and unfinished, that maybe i shouldn't post it. your
encouragement in povray general prompted me to post it. i'm
glad i did. i would never have come up with all the modelling
improvements on my own... not even close.
thanks again, miker
"Gail Shaw" <gsh### [at] monotix co za> wrote in message
news:3c3a8fbd@news.povray.org...
> > hi everybody!
> tree)
> the moment
> Gail
"MR" <a### [at] b net> wrote in message news:3c3ae7b3@news.povray.org...
> hi grimdude,
Normal is part of a texture. It makes the surface look bumpy. Most of
the patterns used in pigments (bozo, crackle, granite, etc) can be used
in the normal statement
eg
box {
-1,1
pigment {rgb 1}
finish {specular 0.2 roughness 0.05}
normal {
wrinkles 0.5
scale 0.2
check the section on normal in the docs for more info
Gail
