Fabien Mosen wrote:
> In France, that particular kind of corkscrew is sometimes
> called a "de Gaulle", as a reference to General de Gaulle's
> typical attitude with his arms lifted.
LOL. Yeah, I can notice a certain resemblance.
And de Gaulle was called 'corkscrew'?
#local j=text{ttf"arial""JRG".2,0}#local J=0;#while(J<10)#local R=0;#while
(R<2)#local G=0;#while(G<1)#if(inside(j<R,G.1>))object{j scale.025translate
<R-1G-J/20J/-40+2>pigment{rgb<9J>}}#debug"O"#else#debug" "#end#local G=G+
.025;#end#local R=R+.05;#debug"\n"#end#local J=J+1;#end// JRG
Home: http://digilander.iol.it/jrgpov
Davey B wrote:
> Excellent work m8
Thank you.
> Nice bit of DOF but did you also use some kind of blurred reflection? (it
> looks slightly blurred in the corkscrew nearest the camera) and if so how
> did you achieve this.
Nope. I only used simple normals. The real model does show blurred reflections, but I
don't think the scene will be a close up of this corkscrew so I don't think I will
add that extra detail. ;)
> Don't wish to sound like an echo, but, can't wait to see the finished
> kitchen :)
I'm having SOOO many exams this month, and I would like to make something for the
IRTC either, so this scene could take a while (I would be happy if I could come up
with 2-3 objects per week though).
Well good luck with the exams and I will keep an eye open for the updates.
Davey B
JRG wrote:
> Thank you very much! I'm using a standard photographic set to show (and
> model) every single object. Just a box, one light behind the camera, one
> light in front of the camera and another one just over the origin.
Ah! The old 3-light system... fine.
> 'tirabuzon' sounds funny too. Is it used normally? I aks because Altavista
> suggested me a 'sacacorchos'...:)
That's the funny part: today it is not used for this appareil, but for
ringlets (you see the similarity, isn't?). The change on the use must be
really old, tough...
Jaime Vives Piqueres
http://www.ignorancia.org
LOL!
Actually, here's what I've found:
1 m. Sacacorchos.
2 fig. Rizo de cabello largo y pendiente en espiral.
3 DEP. Salto en el que el cuerpo del deportista imita con su movimiento la forma de
So ringlet is just the figurative meaning.
Home: http://digilander.iol.it/jrgpov //New: Kitchen scene WIP
news:3c3727e0@news.povray.org...
Er... Ummm... fantast... Unbeliev....
(I have no words, sorry)
> So, a good 5/4 of the model consists of blobs.
Txemi Jendrix
tji### [at] euskalnet net
http://www.geocities.com/txemijendrix
"JRG" <jrg### [at] hotmail com> wrote in message news:3c3727e0@news.povray.org...
> This is a simple corkscrew modelled for the elsewhere mentioned kitchen scene.
The
> modelling was a bit more tricky this time, mostly because I wanted smooth
transitions
> between the surfaces (i.e. I didn't want to get sharp edges). So, a good 5/4
of the
> Cheers.
This is excellent! As was/is your coffeepot. I used to think I was pretty good
with POV, but scenes like this let me know I'm just a "wannabe" :)
light_source{0,1}#macro c(J,a)sphere{0,1pigment{rgb z}scale a translate J+O}
#end#macro B(R,V,O)c(0,4)intersection{c(V,R)difference{c(-z*4x+10)c(-z*4.1x+
10)c(0<7.5,45,5>)}}#end B(12,0z*25)B(8y*4<0,12,50>) // Batronyx ^"^
Great work! but one thing isn't the corckscrew part on backwards???? all the ones i
have had in the past had points at the end of the screw not where the screw meets with
the shaft.
JRG wrote:
> This is a simple corkscrew modelled for the elsewhere mentioned kitchen scene. The
transitions
> between the surfaces (i.e. I didn't want to get sharp edges). So, a good 5/4 of the
> Cheers.
> [Image]
Thank you, Txemi!
Aw, come on!
