Psychomech wrote:
> Great work!
Thanks!
>but one thing isn't the corckscrew part on backwards???? all the ones i
> have had in the past had points at the end of the screw not where the screw meets
with
> the shaft.
Mine begins very thin, quickly grows and then slowly gets thinner, but not as thin as
it is at the beginning. The problem here is that if I made the screw a bit thinner it
would look too 'fat' (it sounds like an oxymoron, but it's true: as I reduced the
radius the screw looked more like a swirly candle). I played one hour with the
parameters of f_helix2 and got unpredictable results. This is the best compromise I
could get.
#local j=text{ttf"arial""JRG".2,0}#local J=0;#while(J<10)#local R=0;#while
(R<2)#local G=0;#while(G<1)#if(inside(j<R,G.1>))object{j scale.025translate
<R-1G-J/20J/-40+2>pigment{rgb<9J>}}#debug"O"#else#debug" "#end#local G=G+
.025;#end#local R=R+.05;#debug"\n"#end#local J=J+1;#end// JRG
Home: http://digilander.iol.it/jrgpov //New: Kitchen scene WIP
ok must be my screwed (forgive the pun) up perception....
JRG wrote:
> Psychomech wrote:
> > Great work!
> Thanks!
> with
> > the shaft.
as
it
> could get.
On Sat, 5 Jan 2002 17:20:13 +0100, JRG wrote:
>This is a simple corkscrew modelled for the elsewhere mentioned kitchen scene. The
>modelling was a bit more tricky this time, mostly because I wanted smooth transitions
>between the surfaces (i.e. I didn't want to get sharp edges). So, a good 5/4 of the
>model consists of blobs.
That's exelent, and I agree you can't beat a good blob.
Steve email mailto:ste### [at] zeropps uklinux net
%HAV-A-NICEDAY Error not enough coffee 0 pps.
or http://start.at/zero-pps
11:46am up 90 days, 3:34, 2 users, load average: 1.05, 1.03, 1.05
On Sat, 5 Jan 2002 18:13:07 +0100, JRG wrote:
>At the moment I have a coffee-percolator, a corkscrew, and nothing else...
>Still much work to do! ;)
There's some coffee cups and a sugar bowl here:
http://www.zeropps.uklinux.net/gallery.html
All hand coded apart from the word "Sugar" on the sugar bowl (created in
softext I think), feel free to use as you please.
11:49am up 90 days, 3:36, 2 users, load average: 1.00, 1.02, 1.04
I thank you. But modelling is real fun so, the more the objects to be modelled, the
more the fun, isn't it? ;)
Blanche...
Au fait que tire Bush ?
impossible to traduce, sorry...
3C3### [at] skynet be...
> JRG wrote:
> > Tire-bouchon is the French word for corkscrew.
> In France, that particular kind of corkscrew is sometimes
> called a "de Gaulle", as a reference to General de Gaulle's
> typical attitude with his arms lifted.
> http://www.charles-de-gaulle.org/degaulle/photos/vie26g.htm
> Fabien.
Very nice.
Is it a working model? Can you make an animation of it?
-tgq
JRG wrote in message <3c373e27@news.povray.org>...
>If I have time, I will then come up with a little 'kitchen objects
collection' which
>I can put on my website.
Why don't you submit the objects to the POV-Ray Objects Collection?
Mark
"Trevor Quayle" <Tin### [at] hotmail com> ha scritto nel messaggio
news:3c39f130$1@news.povray.org...
> Very nice.
Thank you.
It is. I could, but I don't know how much interesting the result would be (you mean
something like a 'dancing corkscrew'? :).
> -tgq
"Mark Wagner" <mar### [at] gte net> ha scritto nel messaggio
news:3c412626@news.povray.org...
> collection' which
<voice=Homer> Uh? I don't know... </voice>
