POV-Ray : Newsgroups : povray.binaries.images : tire-bouchon Server Time
16 Apr 2026 08:06:32 EDT (-0400)
  tire-bouchon (Message 11 to 20 of 28)
<<< Previous 10 Messages Goto Latest 10 Messages Next 8 Messages >>>
Subject: Re: tire-bouchon
Date: 5 Jan 2002 14:02:23
Message: <3c374dbf$1@news.povray.org>
Well good luck with the exams and I will keep an eye open for the updates.
Davey B
Date: 5 Jan 2002 17:27:50
Message: <3c377de5@news.povray.org>
JRG wrote:
> Thank you very much! I'm using a standard photographic set to show (and
> model) every single object. Just a box, one light behind the camera, one
> light in front of the camera and another one just over the origin.
  Ah! The old 3-light system... fine.
> 'tirabuzon' sounds funny too. Is it used normally? I aks because Altavista
> suggested me a 'sacacorchos'...:)
 That's the funny part: today it is not used for this appareil,  but for
ringlets (you see the similarity, isn't?). The change on the use must be
really old, tough...
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 5 Jan 2002 19:06:51
Message: <3c37951b@news.povray.org>
LOL!
Actually, here's what I've found:
1 m. Sacacorchos.
2 fig. Rizo de cabello largo y pendiente en espiral.
3 DEP. Salto en el que el cuerpo del deportista imita con su movimiento la forma de
So ringlet is just the figurative meaning.
#local j=text{ttf"arial""JRG".2,0}#local J=0;#while(J<10)#local R=0;#while
(R<2)#local G=0;#while(G<1)#if(inside(j<R,G.1>))object{j scale.025translate
<R-1G-J/20J/-40+2>pigment{rgb<9J>}}#debug"O"#else#debug" "#end#local G=G+
.025;#end#local R=R+.05;#debug"\n"#end#local J=J+1;#end// JRG
Home: http://digilander.iol.it/jrgpov  //New: Kitchen scene WIP
Date: 5 Jan 2002 20:06:17
Message: <3c37a309@news.povray.org>
news:3c3727e0@news.povray.org...
Er... Ummm... fantast... Unbeliev....
(I have no words, sorry)
> So, a good 5/4 of the  model consists of blobs.
Txemi Jendrix
tji### [at] euskalnetnet
http://www.geocities.com/txemijendrix
Date: 5 Jan 2002 22:06:24
Message: <3c37bf30@news.povray.org>
"JRG" <jrg### [at] hotmailcom> wrote in message news:3c3727e0@news.povray.org...
> This is a simple corkscrew modelled for the elsewhere mentioned kitchen scene.
The
> modelling was a bit more tricky this time, mostly because I wanted smooth
transitions
> between the surfaces (i.e. I didn't want to get sharp edges). So, a good 5/4
of the
> Cheers.
This is excellent! As was/is your coffeepot. I used to think I was pretty good
with POV, but scenes like this let me know I'm just a "wannabe" :)
light_source{0,1}#macro c(J,a)sphere{0,1pigment{rgb z}scale a translate J+O}
#end#macro B(R,V,O)c(0,4)intersection{c(V,R)difference{c(-z*4x+10)c(-z*4.1x+
10)c(0<7.5,45,5>)}}#end B(12,0z*25)B(8y*4<0,12,50>)          // Batronyx ^"^
Date: 6 Jan 2002 03:09:01
Message: <3C3805AF.B55E1794@home.com>
Great work!  but one thing isn't the corckscrew part on backwards????   all the ones i
have had in the past had points at the end of the screw not where the screw meets with
the shaft.
JRG wrote:
> This is a simple corkscrew modelled for the elsewhere mentioned kitchen scene. The
transitions
> between the surfaces (i.e. I didn't want to get sharp edges). So, a good 5/4 of the
> Cheers.
Date: 6 Jan 2002 05:27:56
Message: <3c3826ac@news.povray.org>
Thank you, Txemi!
Date: 6 Jan 2002 05:34:08
Message: <3c382820@news.povray.org>
Aw, come on!
Date: 6 Jan 2002 05:48:56
Message: <3c382b98$1@news.povray.org>
Psychomech wrote:
> Great work!
Thanks!
with
> the shaft.
Mine begins very thin, quickly grows and then slowly gets thinner, but not as thin as
it is at the beginning. The problem here is that if I made the screw a bit thinner it
would look too 'fat' (it sounds like an oxymoron, but it's true: as I reduced the
radius the screw looked more like a swirly candle). I played one hour with the
parameters of f_helix2 and got unpredictable results. This is the best compromise I
could get.
Date: 6 Jan 2002 07:36:39
Message: <3C3844E3.F89E0A0E@home.com>
ok must be my screwed (forgive the pun) up perception....
JRG wrote:
> Psychomech wrote:
> > Great work!
> Thanks!
> with
> > the shaft.
as
it
> could get.
