Started this 4 or 5 days ago and finally got this far, my main problem are
the radiosity artifacts below the casings. Second proplem is the media I
used for the sun, needs a little tweaking. Anyone have any
suggestions/comments?
radiosity settings are as follows ( tweaked from the balcony sample file )
radiosity {
pretrace_start .08
pretrace_end .001
count 750
nearest_count 4
error_bound .3
recursion_limit 1
low_error_factor .5
gray_threshold 0
minimum_reuse .015
brightness 1
adc_bailout .01/2
media on
Download 'theplanets.jpg' (67 KB)
Preview of image 'theplanets.jpg'
I am sure the sun is the largest item in the solar system
PGP Public Key
It's not entirely to scale. Well, the planets are but eveything else isn't.
artistic liscense =)
Kevin
"Rick [Kitty5]" <ric### [at] kitty5com> wrote in message
news:3c32f5c0@news.povray.org...
are
> Rick
> Kitty5 WebDesign - http://Kitty5.com
> POV-Ray News & Resources - http://Povray.co.uk
> TEL : +44 (01270) 501101 - FAX : +44 (01270) 251105 - ICQ : 15776037
> PGP Public Key
Kevin Loney wrote:
> Second proplem is the media I used for the sun, needs a little
> tweaking.
I like the sun, it really looks like bright gas sphere.
/"\ | iki.
\ / ASCII Ribbon Campaign | fi/
X Against HTML Mail | zds
On Mon, 31 Dec 2001 21:13:37 -0700, "Kevin Loney" <klo### [at] pt2mcom> wrote:
Obviously the sun isn't to scale, but it would be pretty hard to get a
recognizable overview of the entire scene it it would be.
Any reason why you've chosen to not put the sun on a pedestal, like you've
done to all the planets?
Also, I notice that you've included Earth's moon, but left out the moons of
the other planets...
Marc van den Dikkenberg
The PowerBasic Archives -- http://www.xlsior.org
"Marc van den Dikkenberg" <exc### [at] xs4allnl> wrote in message
news:D8w4PHmockJHtU52bRd9Nr8zXcAh@4ax.com...
are
Exactly what I was thinking
If i'd used a pedestal for the sun then to make it look correct, I would
have had to use photons, I've been trying to avoid that, I've benn rendering
the final for the last 3 days.
of
phobos and deimos the moons of mars are odd shapes and I really don't want
to model them, second I was having trouble locating good satellite images of
the other moons.
Kevin
Does anyone have this pov file? I cannot find it anywhere, nor can I find
Kevin's website. I have search all of google and the binary files.
Thank in advance,
Bret
> radiosity {
> pretrace_start .08
> pretrace_end .001
> count 750
> nearest_count 4
> error_bound .3
> recursion_limit 1
> low_error_factor .5
> gray_threshold 0
> minimum_reuse .015
> brightness 1
> adc_bailout .01/2
> media on
