POV-Ray : Newsgroups : povray.binaries.images : more rad at the office (60Kb) Server Time
19 Apr 2026 20:23:51 EDT (-0400)
  more rad at the office (60Kb) (Message 1 to 10 of 23)
Subject: more rad at the office (60Kb)
Date: 22 Dec 2001 06:15:32
Message: <3c246b4d@news.povray.org>
Hi!
  I wanted to know how slow this scene will be, with all the "hard"
features turned on:
  + Blurred reflections, with the use of very fine normals and focal_blur
  (little aperture, 32 samples, variance 0).
  + Radiosity data reused from a "dummy" version of the same scene, with
  1/3 resolution, no area_lights, no normals and plain colors. This faked
  version uses the same geometry, but more intense lights to add some
  brigthness to the final scene.
  + 18 big area_lights
  Render time was about 30h, on AMD 1.2Ghz. Fortunatelly, I think adding
more objects and details for the final render will not slow down it much
more... will see.
  Comments/criticism about the lighting and blurred reflections are welcome
(most of the modelling and texturing is still "temporary").
Jaime Vives Piqueres
http://www.ignorancia.org
Download 'office.jpg' (59 KB)
Preview of image 'office.jpg'
Subject: Re: more rad at the office (60Kb)
Date: 22 Dec 2001 07:36:05
Message: <3c247e35$1@news.povray.org>
I am very impressed by this! Both the lighting and modelling. There are many
well defined objects. I suppose you've made them over the years..Your
homepage has many objects too.. great stuff!  :o)  But 30 hours rendertime
is scaring, a little..Will you explain the lighting technique for us, once
you are satisfied with it? Did you find out why radiosity artifacts were
gone when using a saved rad file?  Does it really work to use a rad file
taken from a lower-resolution image?
Hugo
Date: 22 Dec 2001 08:20:26
Message: <3c24889a$1@news.povray.org>
"Hugo" <hua### [at] post3teledk> wrote in message
news:3c247e35$1@news.povray.org...
> [a lot of comments and questions]
> Does it really work to use a rad file taken from a lower-resolution image?
It would seem so ;-}
Date: 22 Dec 2001 08:21:47
Message: <3c2488eb$1@news.povray.org>
Amazing- in detail, photorealism, and render time ;-)
It's about time I got some new wallpaper..
Date: 22 Dec 2001 10:03:27
Message: <3C249E47.6070704@videotron.ca>
Jaime Vives Piqueres wrote:
> Hi!
> features turned on:
Looks quite amazing!
I could only find one small thing to nitpick about:  the highlight in
the top right-hand corner of the bookshelf looks a bit out of place.
Oh!  And i didn't know you could still smoke in spanish offices!
/*   videotron.ca  */}camera{location<6,1.25,-6>look_at a orthographic}
Date: 22 Dec 2001 10:03:55
Message: <3c24a0db@news.povray.org>
Now that looks like a busy office. One complaint allowed?  OK - the
files in the rear cabinet are too tidy :)
Myself, I still have not got the patience to play with radiosity.
Alf
Date: 22 Dec 2001 11:00:04
Message: <3c24ae04@news.povray.org>
First glance of this looks like a photograph, always did really.
The pens in the cup might be better if more random and leaning against the
side in a more obvious way, even if you didn't ask for comments on those
kinds of things.
The small normals seem to cause a little too much noise IMHO, as can be seen
on the foreground desk drawers.  Maybe averaging those with another to blend
them out some could be an improvement?  You say you are not finished with
the texturing though.
Far as radiosity and lighting goes I can only say that it looks very good.
text{ttf"timrom""bob h"0,0pigment{rgb 7}translate 7*z}
Date: 22 Dec 2001 11:38:57
Message: <3c24b720@news.povray.org>
Hi Hugo:
> many well defined objects. I suppose you've made them over the years..Your
  Thanks! Yes, most of the objects are "stock" objects, some other are
still placeholders. And 30h is very fast, really. Without saved radiosity
data it would take at least a 50% more. At first, it was even more slow
because I've put the lights inside CSG diference objects. Now, with unions,
it renders much faster (I must remember this).
  Yes, it is an include file with a very short macro and some constants. It
is mostly based on using very strong intensities and very short
attenuation.  Not a try to get something "physically correct", but
arbitrarily based on real color and lumens data to mantain a realistic
relation between diferent lights in the same scene. Basically, you call the
macro this way:
  lamplight(COLOR_INCANDESCENT,LUMENS_INCANDESCENT_60W)
  or
  lamplight(COLOR_FLUOR_UNIVERSAL_WHITE,LUMENS_FLUOR_18W)
  and it returns a light_source properly adjusted, taking into account two
global constants previously defined: REFERENCE_WHITE and
MAXIMUM_LUMENS_ALLOWED. It's up to you to build the light container (bulb,
lamp, etc...).
  Pretty simple in code, but I expended some months understanding some
concepts about light. I will show it soon...
  Oh! Yes... I followed the advice from Kari of using this setup for the
load scene:
  radiosity{
    pretrace_start 1 pretrace_end 1
    always_sample off
    load "rad_file"
  But as this is using default error bound, wich was greater than the one I
used for the saved data, the final render "smoothed" the artifacts. Seems
that when loading rad data error_bound is taken into account. For ideal
results with high quality settings you should use also the same error bound
as in the "dummy" render. But it also helps to get "quick-but-clean"
results with radiosity.
  I tried it with the "official" cornell-box scene done by Kari (very
good!), and it shows very similar results with saved data from a previous
render at 1/3 resolution. Substracting the original image from the "tricky"
one shows an almost black image (I had to increase brightness to see the
diferenced zones). Of course, the original image is better, much more
smooth, but this is still a great trick for lazy people like me (or you...;)
  Bye!
Date: 22 Dec 2001 11:55:12
Message: <3c24baef@news.povray.org>
 Thanks!
 I've not used hightlights, only reflection and normals. That highlitgh is
the blurred reflection of one of the ceil lamps. I think it is realistic
for the kind of "plastic wood" look I'm trying to create. :(
  No, you can't, but no one cares. Ashtrays are still a classic object for
spanish offices., and only on very public places people is forced to not
smoke. No-smokers are too tolerant here. :)
Date: 22 Dec 2001 11:59:19
Message: <3c24bbe6@news.povray.org>
  Totally right! I must measure a real one...
  This "save and load" trick is a good excuse to start. Give it a try!
