POV-Ray : Newsgroups : povray.binaries.images : more rad at the office (60Kb) Server Time
21 Jul 2026 18:19:44 EDT (-0400)
  more rad at the office (60Kb) (Message 14 to 23 of 23)
Subject: Re: more rad at the office (60Kb)
Date: 22 Dec 2001 14:13:36
Message: <3c24db60@news.povray.org>
Modelling:
as usual everything looks very well modelled (ok except the phone, which
looks a bit too much like a superellipsoid). But I somehow feel the lack of
wires and cables everywhere. It would add so much to the realism. And where
is everybody at 8:25? :)
Texturing:
the wood looks very good IMO. I find the floor excellent too (I love how the
light bulbs reflect on it).
The only thing I would complain of is that some metallic textures look a bit
too *white*.
Lighting:
absolutely great! Absolutely photorealistic. The best thing here (and the
most important one).
Render time:
30 h for such a scene sounds really fast.
Jonathan.
Date: 22 Dec 2001 14:32:19
Message: <3C24DFB1.7475506A@bellsouth.net>
*DROOL*
Psst...have POV running on your rendered computer ;)
Tim Cook
http://personal.lig.bellsouth.net/lig/z/9/z993126
Version: 3.12
Date: 22 Dec 2001 21:04:35
Message: <3C253CA3.AB376771@faricy.net>
Lighting looks pretty good.  Even with the temporary textures and models
it almost looks real, though I can see apots where I think you'll try to
make improvements...
Date: 23 Dec 2001 13:13:18
Message: <3c261ebe@news.povray.org>
Tony[B] wrote:
> 3 Comments:
> 1) What focal blur?
  Ah! That's it! It must be imperceptible. It is acting here like aa, but
softer, altought it need many samples... :(
> 2) I'd make the black cushion of the chair on the right a bit bigger. I
> don't like the way the metal cuts through it. Seems flimsy.
  Yes, bad quick-modelling: must be corrected.
> 3) That's a pretty long render time! Good luck with the final. :)
  :( Will see..
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 23 Dec 2001 13:16:35
Message: <3c261f82@news.povray.org>
JRG wrote:
> Modelling:
> of wires and cables everywhere. It would add so much to the realism. And
> where is everybody at 8:25? :)
  Cables are the next thing to add. And, FYI, it is 8:25 P.M.! All workers
are at home, but someone left the lights turned on. I'm planning some funny
storytelling here... :)
> Texturing:
> bit too *white*.
  Yes, I used a dummy texture too clear. Corrected for the next WIP.
  Thanks!
Date: 24 Dec 2001 10:10:39
Message: <3c27456f$1@news.povray.org>
Well this discussion is completely over my head, but looks good anyway!
Wish MY office was so neat. . .
-Dayv
"Jaime Vives Piqueres" <jai### [at] ignoranciaorg> wrote in message
news:3c24b720@news.povray.org...
> Hi Hugo:
> > I am very impressed by this! Both the lighting and modelling. There are
> > many well defined objects. I suppose you've made them over the
years..Your
> > homepage has many objects too.. great stuff!  :o)  But 30 hours
rendertime
> > is scaring, a little..
>   Thanks! Yes, most of the objects are "stock" objects, some other are
> still placeholders. And 30h is very fast, really. Without saved radiosity
> data it would take at least a 50% more. At first, it was even more slow
> because I've put the lights inside CSG diference objects. Now, with
unions,
> it renders much faster (I must remember this).
> > Will you explain the lighting technique for us, once
> > you are satisfied with it?
>   Yes, it is an include file with a very short macro and some constants.
It
> is mostly based on using very strong intensities and very short
> attenuation.  Not a try to get something "physically correct", but
> arbitrarily based on real color and lumens data to mantain a realistic
> relation between diferent lights in the same scene. Basically, you call
the
> macro this way:
>   lamplight(COLOR_INCANDESCENT,LUMENS_INCANDESCENT_60W)
>   or
>   lamplight(COLOR_FLUOR_UNIVERSAL_WHITE,LUMENS_FLUOR_18W)
>   and it returns a light_source properly adjusted, taking into account two
> global constants previously defined: REFERENCE_WHITE and
> MAXIMUM_LUMENS_ALLOWED. It's up to you to build the light container (bulb,
> lamp, etc...).
>   Pretty simple in code, but I expended some months understanding some
> concepts about light. I will show it soon...
> > Did you find out why radiosity artifacts were
> > gone when using a saved rad file?
>   Oh! Yes... I followed the advice from Kari of using this setup for the
> load scene:
>   radiosity{
>     pretrace_start 1 pretrace_end 1
>     always_sample off
>     load "rad_file"
>   But as this is using default error bound, wich was greater than the one
I
> used for the saved data, the final render "smoothed" the artifacts. Seems
> that when loading rad data error_bound is taken into account. For ideal
> results with high quality settings you should use also the same error
bound
> as in the "dummy" render. But it also helps to get "quick-but-clean"
> results with radiosity.
> > Does it really work to use a rad file
> > taken from a lower-resolution image?
>   I tried it with the "official" cornell-box scene done by Kari (very
> good!), and it shows very similar results with saved data from a previous
> render at 1/3 resolution. Substracting the original image from the
"tricky"
> one shows an almost black image (I had to increase brightness to see the
> diferenced zones). Of course, the original image is better, much more
> smooth, but this is still a great trick for lazy people like me (or
you...;)
>   Bye!
> La Persistencia de la Ignorancia
Date: 25 Dec 2001 05:20:26
Message: <slrna2gkef.plb.steve@zero-pps.localdomain>
On a floor like that I bet you could go really fast on a
wheeley chair.
 10:14am  up 78 days,  2:01,  2 users,  load average: 1.06, 1.06, 1.01
Date: 26 Dec 2001 13:42:12
Message: <3C2A1A43.8070001@209software.com>
The only thing that says 'raytrace' to me in the scene are the
completely straight-line wood textures on the bookshelf and desktop.
 They need turbulence.
Date: 27 Dec 2001 21:45:19
Message: <3c2bd0c0.10491541@localhost>
On Sat, 22 Dec 2001 12:16:16 +0100, Jaime Vives Piqueres
<jai### [at] ignoranciaorg> wrote:
>--nextPart1334872.iZASKD2KPV
>Content-Type: text/plain; charset=iso-8859-15
>Content-Transfer-Encoding: 8Bit
>Hi!
snippage
>  Comments/criticism about the lighting and blurred reflections are welcome
>(most of the modelling and texturing is still "temporary").
You know, it took me over 30 seconds to realize that was
*not* a photo.  The phone gave it away.  *Very* realistic
image!
Pete
Date: 2 Jan 2002 20:02:42
Message: <3c33adb2@news.povray.org>
news:3c246b4d@news.povray.org...
    Very, very nice Jaime. I've learnt something from this.... thanks.  :)
      ~Steve~
