POV-Ray : Newsgroups : povray.binaries.images : Cavorite Sphere, First Men in the Moon by H.G. Wells Server Time
12 Sep 2025 05:10:11 EDT (-0400)
  Cavorite Sphere, First Men in the Moon by H.G. Wells (Message 1 to 10 of 11)
Subject: Cavorite Sphere, First Men in the Moon by H.G. Wells
Date: 30 Nov 2001 22:14:10
Message: <3c084b02@news.povray.org>
Based this on a photo of a model I found, which is at
 http://home.btconnect.com/COMET-MINIATURES/images/moonball.jpg
Not done yet but since I started on it this afternoon (yea! I got busy and
made something, and quickly too!) I've since found other pictures of models
which vary quite a bit.
Can't decide if I should add the shock absorbers on the top and bottom.
Anyone know the book and whether it has them all over?  Would appreciate
knowing that if so, I can probably find a online reference to the book too.
Render time was 1 hour for this one.  Has photons and radiosity applied,
although photons didn't seem to do anything for it.
text{ttf"arial","bob h",.1,0pigment{rgb 9}translate<-1,-.2,3>}
Download 'Cavorite-sphere.jpg' (55 KB)
Preview of image 'Cavorite-sphere.jpg'
Subject: Re: Cavorite Sphere, First Men in the Moon by H.G. Wells
Date: 30 Nov 2001 23:10:19
Message: <3C085737.4001F9D8@hotmail.com>
I like your textures and color combinatins Bob.
Tor Olav
Date: 1 Dec 2001 08:10:14
Message: <3c08d6b6@news.povray.org>
A sort of Yellow submarine who likes the moon...
Subject: Re: [94K Jpg] Cavorite Sphere, First Men in the Moon by H.G. Wells
Date: 1 Dec 2001 11:46:40
Message: <3c090970@news.povray.org>
And on the Moon this time.  The isosurface didn't come out perfectly.
Wanted to show the model with bolts around portal frames and additional
plungers around top (too many perhaps).  Started on the interior, has a
quilted texture.
This rendered in 4 hours 29 minutes, much longer than the 1 hour without
isosurface, in 3.5.beta.8.  A lot different looking from before because of
the radiosity and lack of a sky.
The antialiasing really takes away from the metal texture, it has more
detail without it so guess I need to adjust on that.
Thanks for the comments.
Download 'Cavorite-Sphere_on_Moon.jpg' (69 KB)
Preview of image 'Cavorite-Sphere_on_Moon.jpg'
Date: 1 Dec 2001 15:39:43
Message: <3c09400f@news.povray.org>
I remeber the movie, although the title eludes me right now. It was one of
my favourites when I was a child.
Nice model.
Ruy
Date: 1 Dec 2001 19:21:49
Message: <3c09741d@news.povray.org>
"bob h" <omn### [at] charternet> wrote in message
news:3c084b02@news.povray.org...
too.
Nice job, Bob.  I really liked the rivets that you put around the plates and
the orange color of the sphere.  They made it look more "real" to me.  I
liked the landing legs all around, but if I were inside, I would want it to
land on the bottom only.  Artistically, I liked your idea better than a
platonic solid, which is what I envisioned when I read the story.
I remember reading the story and they talked about shutters made of the
Cavorite that could be opened and closed to control the motion of the ship
by tacking between gravitational bodies.  I think the glass ball with
rollerblind shutters of gravity proof material would look pretty cool as
well.  I found the text for H. G. Wells "First Man in the Moon" on the
Project Gutenberg web site:
http://promo.net/pg/
From that source chapter 3:
"It's like this," he said. "Last time I ran this stuff that cuts things
off from gravitation into a flat tank with an overlap that held it down.
And directly it had cooled and the manufacture was completed all that
uproar happened, nothing above it weighed anything, the air went squirting
up, the house squirted up, and if the stuff itself hadn't squirted up too,
I don't Know what would have happened! But suppose the substance is loose,
and quite free to go up? "
"It will go up at once!"
"Exactly. With no more disturbance than firing a big gun."
"But what good will that do? "
"I'm going up with it! "
I put down my teacup and stared at him.
"Imagine a sphere," he explained, "large enough to hold two people and
their luggage. It will be made of steel lined with thick glass; it will
contain a proper store of solidified air, concentrated food, water
distilling apparatus, and so forth. And enamelled, as it were, on the
outer steel - "
"Cavorite? "
"Yes."
"But how will you get inside? "
"There was a similar problem about a dumpling."
"Yes, I know. But how?"
"That's perfectly easy. An air-tight manhole is all that is needed. That,
of course, will have to be a little complicated; there will have to be a
valve, so that things may be thrown out, if necessary, without much loss
of air."
"Like Jules Verne's thing in A Trip to the Moon."
But Cavor was not a reader of fiction.
"I begin to see," I said slowly. "And you could get in and screw yourself
up while the Cavorite was warm, and as soon as it cooled it would become
impervious to gravitation, and off you would fly -"
"At a tangent."
"You would go off in a straight line - " I stopped abruptly. "What is to
prevent the thing travelling in a straight line into space for ever?" I
asked. "You're not safe to get anywhere, and if you do - how will you get
back? "
"I've just thought of that," said Cavor. "That's what I meant when I said
the thing is finished. The inner glass sphere can be air-tight, and,
except for the manhole, continuous, and the steel sphere can be made in
sections, each section capable of rolling up after the fashion of a roller
blind. These can easily be worked by springs, and released and checked by
electricity conveyed by platinum wires fused through the glass.  All that
is merely a question of detail. So you see, that except for the thickness
of the blind rollers, the Cavorite exterior of the sphere will consist of
windows or blinds, whichever you like to call them. Well, when all these
windows or blinds are shut, no light, no heat, no gravitation, no radiant
energy of any sort will get at the inside of the sphere, it will fly on
through space in a straight line, as you say. But open a window, imagine
one of the windows open. Then at once any heavy body that chances to be in
that direction will attract us "
I sat taking it in.
"You see?" he said.
Date: 1 Dec 2001 19:53:13
Message: <3C097C52.8C04CFF4@faricy.net>
Cool image, nice textures.
Date: 1 Dec 2001 20:16:36
Message: <3c0980f4@news.povray.org>
That's great Steven, thanks.  I can't seem to get the web site to locate the
story myself (tried "Men" and "Man") but your excerpt really helps.  I
forgot about those shutters to open and close so the Corvite could be
controlled.  That explains the pictures I saw of different models.  So I
have some additions to do now.
"Steven Vogel" <svo### [at] iconnnet> wrote in message
news:3c09741d@news.povray.org...
> too.
and
to
> outer steel - "
> "Cavorite? "
> "Yes."
> of air."
> "At a tangent."
> back? "
> I sat taking it in.
> "You see?" he said.
Date: 2 Dec 2001 01:44:00
Message: <3C09CE89.E1C8EE72@faricy.net>
http://promo.net/cgi-promo/pg/cat.cgi?&label=ID&ftpsite=ftp://indian.cse.msu.edu/pub/mirrors/Gutenberg/&alpha=1033
Date: 2 Dec 2001 15:49:02
Message: <3c0a93be$2@news.povray.org>
Excellent, thanks David.
