POV-Ray : Newsgroups : povray.binaries.images : Grass-iso [50kb] Server Time
12 Sep 2025 05:33:23 EDT (-0400)
  Grass-iso [50kb] (Message 1 to 7 of 7)
Subject: Grass-iso [50kb]
Date: 30 Nov 2001 04:46:13
Message: <3c075565@news.povray.org>
I know others have done this already, but nothing like rolling your own...
Grass iso-surface, rendered with radiosity. Getting there....
#macro G(D,E,F)#local I=array[3]{D,E,F}#local B=0;triangle{#while(
B<3)#while(I[B])A[mod(I[B],10)]+#local I[B]=div(I[B],10);#end<-5,-
2,9>#local B=B+1;#end}#end #local A=array[7]{x,x*2,x*4,y,y*2,y*4,z
}light_source{-x*6-z*9,1}mesh{G(105,10,146)G(105,246,10)G(105,56,
146)G(105,1256,246)G(1256,126,220)G(22156,2216,201)pigment{rgb 1}}//TM
Download 'a2.jpg' (50 KB)
Preview of image 'a2.jpg'
Subject: Re: Grass-iso [50kb]
Date: 30 Nov 2001 06:21:21
Message: <3c076bb1@news.povray.org>
Tom Melly schrieb in Nachricht <3c075565@news.povray.org>...
Looks good!
What was the rendertime for this.
Did you use R. Suzuki's method or another one? (This is a hidden request for
the code :o))
Marc-Hendrik
Date: 30 Nov 2001 07:04:10
Message: <3c0775ba$1@news.povray.org>
"Marc-Hendrik Bremer" <Mar### [at] t-onlinede> wrote in message
news:3c076bb1@news.povray.org...
> Looks good!
Thanks!
> the code :o))
For the full 800*600 with AA it took 10 hours (the image I posted was just a bit
of it).
No, the code is my own - I recall the Suzuki image, but I have no idea how
similiar or not my code is. Here it is...
global_settings {
  assumed_gamma 1.0
  noise_generator 2
  radiosity {
    pretrace_start 0.08           // start pretrace at this size
    pretrace_end   0.04           // end pretrace at this size
    count 35                      // higher -> higher quality (1..1600) [35]
    nearest_count 5               // higher -> higher quality (1..10) [5]
    error_bound 1.8               // higher -> smoother, less accurate [1.8]
    recursion_limit 3             // how much interreflections are calculated
(1..5+) [3]
    low_error_factor .5           // reduce error_bound during last pretrace
step
    gray_threshold 0.0            // increase for weakening colors (0..1) [0]
    minimum_reuse 0.015           // reuse of old radiosity samples [0.015]
    brightness 1                  // brightness of radiosity effects (0..1) [1]
    adc_bailout 0.01/2
  location  <0.0, 5.0, -2.5>
  look_at   <0.0, 0.0,  5.0>
sky_sphere {pigment{rgb<0.0,0.1,0.8>}}
light_source {
  <0, 0, 0>            // light's position (translated below)
  color rgb <1, 1, 1>  // light's color
  translate <-30, 30, -30>
#declare GS = 20;
#declare GH = 2;
#include "functions.inc"
#include "finish.inc"
#declare fn_Grass = function(x,y,z){
  y +
  min(
    0,
    sin(  // x sin, add curve, add offset planting
      ((x + ((f_noise3d(x*10,0,z*10)+y)^2)/5 ) + f_noise3d(0,0,z))*GS*3
    ) / GH + // -1/GH > 1/GH
    sin(
      ((z + ((f_noise3d(x*10,0,z*10)+y)^2)/5 ) + f_noise3d(x,0,0))*GS*2
    ) / GH  // -1/GH > 1/GH // -2/GH > 2/GH
isosurface {
  function{fn_Grass(x, y, z)}        // alternative declared function
  contained_by{box{<-25,-0.1,-2.5>,<25,1.1,30>}}
  accuracy 0.001                      // accuracy of calculation [0.001]
  max_gradient 20                      // maximum gradient the function can have
[1.1]
  evaluate 1, 1.2, 0.99             // evaluate the maximum gradient
  pigment{ForestGreen}
Date: 30 Nov 2001 07:05:43
Message: <3c077617@news.povray.org>
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3c0775ba$1@news.povray.org...
bit
> of it).
On a P3 733 using 3.5.7.icl
Date: 30 Nov 2001 07:23:00
Message: <3C077A22.A8C56173@gmx.de>
> of it).
> [code]
You might get some improvement in quality and speed by using the
'Radiosity_OutdoorLight' settings (or similar) from 'rad_def.inc'.
Date: 30 Nov 2001 08:06:42
Message: <3c078462@news.povray.org>
news:3C077A22.A8C56173@gmx.de...
Ta for the tip - note to self, take a look at ALL the includes...
Date: 30 Nov 2001 08:42:42
Message: <3c078cd2@news.povray.org>
Tom Melly schrieb in Nachricht <3c0775ba$1@news.povray.org>...
Thanks, I'll have a look at it. Gilles Tran's mesh-grass is very good
considering render speed, but as it can't be used in CSG it's very difficult
to "lay" something in it, if it's not short enough.
Thanks again,
Marc-Hendrik
