I just created a trombone model in sPatch, and I thought I'd share it with
the rest of you. The source is in p.b.scene-files.
/ Martin Magnusson
Download 'trombone.jpg' (21 KB)
Preview of image 'trombone.jpg'
Do you play trombone ? It's very hard. I tried once, and obtained
nothing but horrible sounds...
Fabien.
Well yes, I do. If you want you can check out www.blecket.org, that's the
band I'm playing in.
> It's very hard.
Not very... Not if you compare to trumpets and clarinets and stuff anyway.
It's just one slide to keep track of, and not a bunch of valves and things.
/ Martin
> > It's very hard.
I imagine it's the amberture that's hard. I play clarinet. You blow
and it makes sound, it's pretty easy. (Double-reed instruments are
another matter.) Lots of keys are good too. They keep you from having
to move quickly between notes or do awkward slides, because there's
(usually) a key nearby for the next note. And a key or valve you just
press, unlike a trombone or violin where you have to find the right
spot. (String players usually can't, that's why they do a tremolo.)
David Fontaine <dav### [at] faricynet> ICQ 55354965
My raytracing gallery: http://davidf.faricy.net/
On Sun, 25 Nov 2001 20:53:44 -0600, David Fontaine <dav### [at] faricynet>
Having struggled with it for some months, I must disagree. It's easy
only after you get used to it. Which holds true for every instrument
The mouthpiece alone makes the best instrument for torturing a cat
that I've ever seen (or heard) :))
Peter Popov ICQ : 15002700
Personal e-mail : pet### [at] vipbg
TAG e-mail : pet### [at] tagpovrayorg
Pull the corners of your lips back and say eeeeee. Do something a
little similar into the clarinet. :) Well, you have to build those
muscles a little and it gets less tiring.
