POV-Ray : Newsgroups : povray.binaries.images : Trombone Server Time
2 Mar 2026 11:00:32 EST (-0500)
  Trombone (Message 1 to 6 of 6)
Subject: Trombone
Date: 25 Nov 2001 10:18:34
Message: <3c010bca@news.povray.org>
I just created a trombone model in sPatch, and I thought I'd share it with
the rest of you. The source is in p.b.scene-files.
/ Martin Magnusson
Download 'trombone.jpg' (21 KB)
Preview of image 'trombone.jpg'
Subject: Re: Trombone
Date: 25 Nov 2001 16:20:04
Message: <3C015FCB.41015384@skynet.be>
Do you play trombone ?  It's very hard.  I tried once, and obtained
nothing but horrible sounds...
Fabien.
Date: 25 Nov 2001 16:56:41
Message: <3c016919@news.povray.org>
Well yes, I do. If you want you can check out www.blecket.org, that's the
band I'm playing in.
> It's very hard.
Not very... Not if you compare to trumpets and clarinets and stuff anyway.
It's just one slide to keep track of, and not a bunch of valves and things.
/ Martin
Date: 25 Nov 2001 21:50:10
Message: <3C01AEB8.24FA4213@faricy.net>
> > It's very hard.
I imagine it's the amberture that's hard.  I play clarinet.  You blow
and it makes sound, it's pretty easy.  (Double-reed instruments are
another matter.)  Lots of keys are good too.  They keep you from having
to move quickly between notes or do awkward slides, because there's
(usually) a key nearby for the next note.  And a key or valve you just
press, unlike a trombone or violin where you have to find the right
spot.  (String players usually can't, that's why they do a tremolo.)
Date: 26 Nov 2001 06:19:43
Message: <t4940u80tc4dqgili8ms88if8qq4brdn9l@4ax.com>
On Sun, 25 Nov 2001 20:53:44 -0600, David Fontaine <dav### [at] faricynet>
Having struggled with it for some months, I must disagree. It's easy
only after you get used to it. Which holds true for every instrument
The mouthpiece alone makes the best instrument for torturing a cat
that I've ever seen (or heard) :))
Peter Popov ICQ : 15002700
Date: 26 Nov 2001 21:51:08
Message: <3C030072.48A9D3E3@faricy.net>
Pull the corners of your lips back and say eeeeee.  Do something a
little similar into the clarinet.  :)  Well, you have to build those
muscles a little and it gets less tiring.
