POV-Ray : Newsgroups : povray.binaries.images : rad prob Server Time
22 Jul 2026 23:29:55 EDT (-0400)
  rad prob (Message 11 to 12 of 12)
Subject: Re: rad prob
Date: 17 Nov 2001 09:08:04
Message: <3bf66f44@news.povray.org>
news: 3bf4295c@news.povray.org...
> Notice the black marks aon the window arches. Any ideas what is causing
them
> or how I can get rid of them?
Just thought of something (of little help) : there's an old problem with
smoothed meshes, even high-res ones, that makes the outline of a mesh black
and very apparent in some places, even with radiosity. I've been living with
this for a long while (it may be not very noticeable when the texture is
dark) but I don't have a workaround. In fact I had to brush out these
artefacts in a image editor more than once.
I guess it's worth a note in povray.pre-beta though, if only to have this
mentioned in the documentation.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 17 Nov 2001 13:29:22
Message: <3bf6ac82@news.povray.org>
"Mick Hazelgrove" <mic### [at] mhazelgrovefsnetcouk> wrote in message
news:3bf4295c@news.povray.org...
> From: "Mick Hazelgrove" <mic### [at] mhazelgrovefsnetcouk>
> Subject:
> Date: 15 November 2001 20:13
> Hi
> Notice the black marks aon the window arches. Any ideas what is causing them
> I suspect they are due to radiosity settings. The arches are basic triangle
> meshes created in hamapatch and converted to pov by 3dwin.
> Radiosity settings I'm using
>     radiosity{
>        pretrace_start 1//0.08
>        pretrace_end   1//0.04  //.004
>        count 400  // 2-400 in final
>        nearest_count 8
>        error_bound 0.15
>        recursion_limit 2
>        low_error_factor 0.5
>        gray_threshold 0
>        minimum_reuse 0.015
>        brightness 1.0
>        adc_bailout 0.01/2
>    normal on
>    media on
Well, except for one potentially problematic spot on the rightmost keystone, I
don't think this will really be an issue for you as you progress. Realistically,
dirt and grime will collect in these same areas making them darker anyway.
OK. This isn't a solution. But, if it is difficult to correct as Gilles
suggests, maybe this will help you move on. :D
Batronyx ^"^
