POV-Ray : Newsgroups : povray.binaries.images : Iso-Media Speckles Server Time
12 Sep 2025 10:06:03 EDT (-0400)
  Iso-Media Speckles (Message 1 to 10 of 11)
Subject: Iso-Media Speckles
Date: 14 Nov 2001 11:23:07
Message: <3bf29a6b@news.povray.org>
Any ideas on how I can get rid of or reduce the speckling in this
isosurface?  It seems that the more convoluted the surface is the more
speckled it gets.  I have tried playing with the intervals, samples, and
max_gradient without much success.  Massive amounts of AA help a little
but they don't remove the speckles, just blur them in.  Is there
something that I am overlooking?
Skip
Download 'iso-8859-1' (1 KB)
Subject: Re: Iso-Media Speckles
Date: 14 Nov 2001 11:32:30
Message: <bq65vtkq78scf6d96s6n2bbofhhggapiph@4ax.com>
On Wed, 14 Nov 2001 10:23:20 -0600, "Skip Talbot" <sta### [at] uiucedu> wrote:
> Any ideas on how I can get rid of or reduce the speckling in this isosurface?
Nice. Could you provide some source ? It seems you should start with eval
(described i.e. here http://www.povray.org/working-docs/id000167.html#6_5_4_5 ).
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 14 Nov 2001 11:36:59
Message: <3bf29dab@news.povray.org>
Did you try  to use "evaluate" in order to find out the proper
"max_gradient"? If not, take a look at the docs, specifically 6.5.4.
Although you increased it, the ammount might still be insuficient (the
largest number I've had to use in one of my isosurfaces was 248). If it's
not that, then I don't have a clue.
BTW, nice cloud. Do you intend to post the source?
Ruy
Date: 14 Nov 2001 14:36:59
Message: <3bf2c7db$1@news.povray.org>
Evaluate gave me a max_gradient of 24.556.  The speckles were unchanged at
this value.  As for the source... here's the cloud so far:
#declare F=function{pigment{
  spotted
  turbulence 5
  color_map { [0 rgb 0.6][1 rgb 0.0] }
  scale .125
isosurface
        function { x^2 + 4*y^2 + z^2 -.25  +
(F(x*0.2,y*0.2,z*0.2).red-0.31)  }
        max_gradient 3
        contained_by{sphere{0,.75}}
pigment {rgbf 1 }
        interior {
        media {
                scattering {2, 5 extinction .5 }
                method 3
                intervals 1
   double_illuminate
   hollow
Skip
news:bq65vtkq78scf6d96s6n2bbofhhggapiph@4ax.com...
isosurface?
> ABX
1}}
}}isosurface{ file://ABX
1}}//POV35
Date: 14 Nov 2001 14:41:18
Message: <3bf2c8de$1@news.povray.org>
I tried a max_gradient of 2000 and got the same results.  A max_trace_level
of 10000 did not help either.  I'll post the cloud to p.t.s-f when its
completed.  I'm using it for my bomber scenes.
Skip
Ruy <ruy### [at] hipernetcombr> wrote in message news:3bf29dab@news.povray.org...
> Ruy
Date: 14 Nov 2001 14:46:19
Message: <3bf2ca0b$1@news.povray.org>
Try increasing max_trace_level.
-tgq
Date: 14 Nov 2001 15:01:09
Message: <3bf2cd85$1@news.povray.org>
I think I found it, try adjusting accuracy in the iso (default is 0.001,
0.0001 appeared ok)
-tgq
"Skip Talbot" <sta### [at] uiucedu> wrote in message
news:3bf2c8de$1@news.povray.org...
max_trace_level
> Skip
it's
> > Ruy
Date: 14 Nov 2001 16:02:05
Message: <3bf2dbcd@news.povray.org>
Yep, that did the trick!  Thanks for the suggestions everyone.
Skip
Trevor Quayle <Tin### [at] hotmailcom> wrote in message
news:3bf2cd85$1@news.povray.org...
> 0.0001 appeared ok)
> -tgq
> max_trace_level
> > Skip
> it's
> > > Ruy
Date: 14 Nov 2001 19:21:45
Message: <3bf30a99$1@news.povray.org>
It looks like a tissue on self-destruct :-)
Nice image.
//Mahalis
camera{location<0,0.25,-2> look_at 0.5*y} #declare
T=texture{pigment{crackle scale 0.5 rotate 90 turbulence 0.75
color_map{[0 rgb 1][0.05 rgb 1][0.1 rgb<1,0.25,1>][0.25 rgbf 1][1 rgbf
1]}} finish{ambient 1}} #declare c=difference{torus{0.5,0.1 rotate
-90*x}box{<0.7,0,0.2>,<-0.7,-0.7,-0.2>}}  merge{object{c
translate<0.5,0.5,0>} object{c translate<-0.5,0.5,0>}
cylinder{<1,0.5,0>,<1,0,0>,0.1} cylinder{<-1,0.5,0>,<-1,0,0>,0.1}
cylinder{0.5*y,0,0.1} texture{T}}
news:3bf29a6b@news.povray.org...
  Skip
Download 'iso-8859-1' (2 KB)
Date: 14 Nov 2001 22:41:23
Message: <3bf33963@news.povray.org>
Here's an updated pic without the speckles
Skip
  Mahalis <don### [at] fakeycom> wrote in message
news:3bf30a99$1@news.povray.org...
  Nice image.
  //Mahalis
    Skip
Download 'iso-8859-1' (3 KB)
