POV-Ray : Newsgroups : povray.binaries.images : Another WIP Server Time
3 May 2026 15:48:09 EDT (-0400)
  Another WIP (Message 32 to 41 of 41)
Subject: Re: Another WIP
Date: 11 Nov 2001 13:25:10
Message: <3BEEC1DB.16B232F0@skynet.be>
Jack wrote:
> It is a kitchen to be built, but like I said the rendering is a WIP. There
> should be a window in the obvious empty space on the wall--nothing I can do
> about placing cabinets over that. With that in mind, what do you suggest?
Do a wider-angle rendering of it (simple raytracing), so I can see
everything, and state me clearly the function of each device.
Fabien.
Date: 11 Nov 2001 15:06:12
Message: <3BC5EDB1.6419841D@engineer.com>
John David Haiducek wrote:
> I had thought that Photoshop's "Lighten" mode did addition. Am I wrong
> about that?
Try 50% gray bg layer + 50% gray lighten layer. It's not white.
I just tried all the modes in 5.5 and none of them was additive.
The only way to add images is via Image/Calculations but it's
not good for interactive editing.
_____________
Kari Kivisalo
Date: 11 Nov 2001 15:18:09
Message: <3BC5F07F.A6EF0A5@engineer.com>
Fabien Mosen wrote:
> > Default radiosity brightness is the correct one so no need to
> > touch that.
> Some "exposure" filtering would be good, in the future, though.
When a new MegaPOV version does gamma correction after
post_process and input to curves is not limited exposure
can be done with post_process.
_____________
Kari Kivisalo
Date: 11 Nov 2001 23:41:44
Message: <3bef5308$1@news.povray.org>
You're seeing all that I have done.
"Fabien Mosen" <fab### [at] skynetbe> wrote in message
news:3BEEC1DB.16B232F0@skynet.be...
There
do
suggest?
> Fabien.
Date: 12 Nov 2001 00:47:50
Message: <3BEF61DC.AA575AE@skynet.be>
Of course not !
There is missing space to the right, especially.
Fabien.
Date: 12 Nov 2001 01:43:59
Message: <hlruut428a7ni65g34te45grbvktu80loe@4ax.com>
On Sun, 11 Nov 2001 08:02:17 -0500, John David Haiducek
>about that?
If layer A is above layer B, then for a pixel [x,y]:
f_lighten(A,B,[x,y]) = (lum(A,[x,y])>lum(B,[x,y]))?A[x,y]:B[x,y]
If you want to do addition, try screen mode or image/channel
composition.
Peter Popov ICQ : 15002700
Date: 13 Nov 2001 00:30:17
Message: <3BC7C363.916A741F@engineer.com>
> composition.
screen mode: A + B - A*B
_____________
Kari Kivisalo
Date: 13 Nov 2001 01:06:21
Message: <gud1vtgvnuv5601sa8re33qmjjlqhg3rb4@4ax.com>
On Sat, 13 Oct 2001 07:30:27 +0300, Kari Kivisalo
I didn't know that. Do you have the mathematical description of the
other non-trivial ones such as Overlay or Soft/Hard Light? I don't see
them in the manual.
Date: 13 Nov 2001 01:36:23
Message: <3BC7D2E2.298BB390@engineer.com>
Quick web search didn't turn up any equations for these
so I tried a few combinations to find out what screen mode
does.
_____________
Kari Kivisalo
Date: 14 Nov 2001 22:33:50
Message: <3BF3386A.6F481666@faricy.net>
Hmm, looks pretty good.  Some textures are a little too translucenty
looking IMHO.  (Actually they might make good subsurface scattering
fakes... ;)
