POV-Ray : Newsgroups : povray.binaries.images : Sleeping Lovers Server Time
26 Mar 2026 15:01:12 EDT (-0400)
  Sleeping Lovers (Message 1 to 8 of 8)
Subject: Sleeping Lovers
Date: 4 Nov 2001 15:47:53
Message: <3be5a979@news.povray.org>
Hi
    This is just something I put together today out of the isosurfaces
and macros found in Pov3.5, it took just under 2 hours to render on my
350Mhz computer, any comments are welcome.
bri
Download 'sleeping lovers.jpg' (130 KB)
Preview of image 'sleeping lovers.jpg'
Subject: Re: Sleeping Lovers
Date: 4 Nov 2001 17:48:04
Message: <3BE5C504.BC7FE60C@skynet.be>
Looks like a Hypgnosis record sleeve !
Fabien.
Date: 4 Nov 2001 19:03:33
Message: <3BE5D7C5.D0CA9977@hotmail.com>
> Fabien.
Yin Yang
Dan Johnson
http://www.geocities.com/zapob
Date: 4 Nov 2001 19:09:14
Message: <3be5d8aa$1@news.povray.org>
"bri.wood" <bri### [at] ntlworldcom> wrote in message
news:3be5a979@news.povray.org...
> Hi
> bri
Simple but very cool.  The metal and (is that) glass textures are great.  The
only thing I'd probably do is change the ground.  It looks like the platform is
floating on a reddish fluid of some sort.
Michael
camera{location<8,20>look_at<6,0,4>}light_source{<8,8>rgb 1}difference{union{
#macro M(D,J)#local R=asc(substr(D,J,1))-32;<div(R,10)*2,mod(R,10)>#end#macro
E(D,B,R)prism{-D,4+D,R#local C=1;#while(C<R+1)M(B,C)#local C=C+1;#end}#end E(
0," (2:FPKAD80* U_dZU"18)sphere{2,2}#macro T(N)cylinder{<9,-N,3><9,4+N,3>3-N}
#end T(0)}T(2)E(1"45LNXUK4"8)pigment{rgb x+y/2}}//(c)2001 MDJohnson(Redbeard)
Date: 4 Nov 2001 21:00:22
Message: <3be5f2b6$1@news.povray.org>
Hmm. The metal things look like commas ;-)
Very nice image overall. What's the cushion? Blobs?
//Mahalis
camera{location<0,0.25,-2> look_at 0.5*y} #declare T=texture{pigment{crackle
scale 0.5 rotate 90 turbulence 0.75 color_map{[0 rgb 1][0.05 rgb 1][0.1
rgb<1,0.25,1>][0.25 rgbf 1][1 rgbf 1]}} finish{ambient 1}} #declare
c=difference{torus{0.5,0.1 rotate -90*x}box{<0.7,0,0.2>,<-0.7,-0.7,-0.2>}}
merge{object{c translate<0.5,0.5,0>} object{c translate<-0.5,0.5,0>}
cylinder{<1,0.5,0>,<1,0,0>,0.1} cylinder{<-1,0.5,0>,<-1,0,0>,0.1}
cylinder{0.5*y,0,0.1} texture{T}}
> Hi
> bri
Date: 4 Nov 2001 21:32:55
Message: <3be5fa57@news.povray.org>
The metal things are isosurfaces, f_comma and the cushion is another
isosurface, f_pillow with the bottom cut off with a plane.
bri
Mahalis <don### [at] fakeycom> wrote in message
news:3be5f2b6$1@news.povray.org...
> file://Mahalis
1][0.1
> > Hi
isosurfaces
on my
> > bri
Date: 5 Nov 2001 04:54:41
Message: <3be661e1@news.povray.org>
"bri.wood" <bri### [at] ntlworldcom> wrote.
> bri
Thank you for using f_comma function.   I made the function to express Yin
Yang
as Dan Johnson pointed out.
R. Suzuki
Date: 5 Nov 2001 15:00:45
Message: <3be6efed@news.povray.org>
"Fabien Mosen" <fab### [at] skynetbe> escreveu na mensagem
news:3BE5C504.BC7FE60C@skynet.be...
You are right. I can even hear the Pink Floyd looooooong solo on the
background...
