POV-Ray : Newsgroups : povray.binaries.images : First image in a long time, just testing "new" stuff Server Time
24 Mar 2026 07:28:52 EDT (-0400)
  First image in a long time, just testing "new" stuff (Message 11 to 20 of 26)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re: First image in a long time, just testing "new" stuff
Date: 29 Oct 2001 07:36:22
Message: <3bdd4d46@news.povray.org>
Warp wrote:
>   The image looks very good.
>   However, there's something strange there. I think that you clearly
wanted
> to make glass torii. However, for some reason they look like made of
plastic
> instead.
>   What is their ior? Also perhaps the highlights should be sharper.
Yes I haven't played with the highlights yet, so I left them fairly dull
(more like some kind of plastic).  The IOR is 1.15, so the highlights should
be much tighter.
Lance.
thezone.firewave.com.au
www.firewave.com.au
Date: 29 Oct 2001 09:28:33
Message: <3bdd6791@news.povray.org>
"Lance Birch" <-> wrote in message news:3bdcc5f5@news.povray.org...
> I'm not sure, with RC5 running I can get both processors doing 100% (if not
> with a little bit or kernel action here and there).  I'll have to
> investigate it further.  AFAIK POV-Ray is single-threaded as well, but even
> still, setting it to the highest thread priority should get it using 100% of
> one processor.  I'll have to try manually setting it in the task manager on
> pvengine.
Incidentally, if you download beta.7 (available in the next 24 hours), you will
find that on NT it prints a summary of actual kernel+user time after each render.
I added this to allow for more accurate benchmarking, regardless of what other
processes are running on the machine (in the process of which I discovered that,
for some reason, NT doesn't seem to include time spent updating graphics or the
UI in either time count, which to an extent suits me, though I wasn't expecting
it).
-- Chris
Date: 29 Oct 2001 10:01:47
Message: <3bdd6f5b@news.povray.org>
not
even
100% of
on
> > pvengine.
will
render.
other
that,
or the
expecting
> it).
Thanks Chris, this'll be an interesting thing to watch.  I've been
monitoring the way it's prioritised across both processors and it seems to
get the equivalent of 100% of one processor (regardless of the assigned
affinity), which is good :)
Lance.
www.firewave.com.au
Date: 29 Oct 2001 10:26:40
Message: <3bdd7530@news.povray.org>
Nice image. Can you share the photons and radiosity parameters with us?
Ruy
Date: 29 Oct 2001 12:23:10
Message: <3bdd907e@news.povray.org>
Lance Birch <-> wrote:
: The IOR is 1.15
  That explains a lot. They just didn't have that glass-refraction look.
  The IOR for glass is 1.5, and for water it's 1.33. So what you have modelled
are torii made of some gas which is a bit denser than air. In fact, those
torii couldn't exist in the real world (a material of that density would just
vaporize as any gas). No wonder why they looked odd... :P
Date: 29 Oct 2001 17:09:17
Message: <3bddd38d@news.povray.org>
> : The IOR is 1.15
modelled
just
Yes I know all the values for different materials... I was more just going
for artistic mertic ;)
Lance.
www.firewave.com.au
Date: 29 Oct 2001 17:12:26
Message: <3bddd44a@news.povray.org>
I started with the standard radiosity settings from the Insert menu and work
my way along.  The photons are fairly self explanatory.  I don't think the
radiosity has too much effect in the image, except with the grey sky sphere
I put in for the sky.  The ambient light does a lot of the work too.
global_settings {
  radiosity {
    pretrace_start 0.08
    pretrace_end 0.04
    error_bound 1.8
    recursion_limit 3
    low_error_factor .5
    gray_threshold 0.0
    minimum_reuse 0.015
    brightness 1
    adc_bailout 0.01/2
    normal on
    count 1600
    nearest_count 7
  photons {
     count 6000000
     autostop 0
     jitter 1
  ambient_light rgb <2,0.25,0>
Lance.
www.firewave.com.au
Date: 29 Oct 2001 17:29:06
Message: <3bddd832$1@news.povray.org>
AFAIK POV 3.5 radiosity looks much better with ambient set to 0 (except the
sky of course).
The motto is: "let radiosity do it!"
Jonathan.
"Lance Birch" <-> ha scritto nel messaggio news:3bddd44a@news.povray.org...
work
sphere
> global_settings {
>   radiosity {
>     pretrace_start 0.08
>     pretrace_end 0.04
>     error_bound 1.8
>     recursion_limit 3
>     low_error_factor .5
>     gray_threshold 0.0
>     minimum_reuse 0.015
>     brightness 1
>     adc_bailout 0.01/2
>     normal on
>     count 1600
>     nearest_count 7
>   photons {
>      count 6000000
>      autostop 0
>      jitter 1
> Lance.
> www.firewave.com.au
Date: 29 Oct 2001 18:50:25
Message: <3BDDEAEC.8040905@videotron.ca>
Wow!  What would be the odds of getting both Netscape 6.2 and POV 3.5.b7
on the same day!!!
/*   videotron.ca  */}camera{location<6,1.25,-6>look_at a orthographic}
Date: 29 Oct 2001 22:18:31
Message: <3bde1c07@news.povray.org>
"JRG" <jrg### [at] hotmailcom> wrote in message
news:3bddd832$1@news.povray.org...
the
> sky of course).
Yes but I always love maxing out colours to get better contrast :)
Lance.
www.firewave.com.au
