POV-Ray : Newsgroups : povray.binaries.images : A different approach to blurred reflection (PNG, 80kbu) Server Time
23 Jul 2026 04:04:12 EDT (-0400)
  A different approach to blurred reflection (PNG, 80kbu) (Message 33 to 42 of 42)
Subject: Re: A different approach to blurred reflection (PNG, 80kbu)
Date: 19 Oct 2001 15:23:19
Message: <3bd07da7@news.povray.org>
JRG <jrg### [at] hotmailcom> wrote:
: The objects have no_reflection and the sphere is reflecting a bigger version
: of the scene with focal_blur? (does it make any sense?)
  You are very, very close, but still not the correct answer.
  Note that using focal blur would have smoothed at least some of the jagged
lines, no matter how long the area of sharpness is.
  However your idea could work quite well. You could test that.
  I'll post the answer to the problem to this thread as a separate article.
Subject: The answer (Was: A different approach to blurred reflection (PNG, 80kbu))
Date: 19 Oct 2001 15:42:53
Message: <3bd0823b@news.povray.org>
I used a technique pretty common in scanline-rendering for "faking" fast
reflections: Environment mapping.
  In environment mapping a spherical view of the scene from the point of view
of the object is first created and then, when the object is rendered, its
surface color is blended with the environment map with an algorithm pretty
similar to raytracing (the environment map acts like a sky_sphere and "rays"
are reflected from the surface of the object to this sky sphere; of course
no real "rays" need to be shot, but just calculate the point where the
"reflected ray" would hit the sky sphere and take the proper color from the
environment map).
  Environment mapping works well only if the other objects in the scene are
far enough from the object. If there are objects too close, they will be
distorted in unnatural ways in the "reflection" (as can be seen for example
in the reflected checkered floor in my image).
  Also environment mapping in scanline rendering doesn't work well with
self-reflecting objects nor mutually reflecting objects (but it *does* work
in raytracing!).
  (A variant of this is to use cube mapping, which is basically the same thing,
but the "sky sphere" is a cube instead. The advantage of this is that the
environment map is much easier to calculate by scanline rendering.)
  What I did was to make a 2-frames animation: The first frame creates the
environment map using the spherical camera and focal blur (as many guessed).
(Of course focal blur doesn't work with the spherical camera in the current
POV-Ray, as I have reported in p.b-t, so I had to fix it before I could make
this image.) The camera was located in the center of the sphere and the
sphere just had a no_image specified to it (it had to be there for the
shadow).
  The second frame of this "animation" loads the first frame and puts it
as a sky_sphere (I could do this because the sky is not seen directly in the
image). All the other objects now get the no_reflection tag so that the sphere
will reflect the sky_sphere instead.
  And that's it.
  (If you wonder if this environment map trick would work with other objects
than just a sphere, the answer is yes. As I said before, this is a pretty
common technique used in scanline-rendering to add "reflections" to any
object. It's just that all the other objects have to be far enough for it
to look good.)
  And here is the first frame of the animation, ie. the environment map:
Download 'envmap.png' (114 KB)
Preview of image 'envmap.png'
Subject: Re: The answer (Was: A different approach to blurred reflection (PNG, 80kbu))
Date: 19 Oct 2001 16:31:00
Message: <3bd08d84$1@news.povray.org>
Interesting idea. The major flaw being, it seems, that the reflection isn't
coming from the point where the ray from the camera intersected the sphere;
rather, it's always coming from the center of the sphere. Which is a good
enough approximation, I assume, if the reflected objects are far enough away
from the sphere that the diference isn't noticeable.
But does focal blur blur objects the same amount at the same distance that
regular reflection blur would do?
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
news:3bd0823b@news.povray.org...
view
"rays"
the
> environment map).
are
example
work
> in raytracing!).
thing,
guessed).
current
make
> shadow).
the
sphere
>   And that's it.
objects
> to look good.)
Date: 19 Oct 2001 16:45:11
Message: <3bd090d7$1@news.povray.org>
I thought maybe something like that, until you said it wasn't an image map.
-tgq
Date: 19 Oct 2001 17:00:57
Message: <3BD094A1.A042397A@gmx.de>
About what i said, just somehow the other way round... ;-)
Date: 20 Oct 2001 00:14:33
Message: <3BD0FAE6.8CD16B09@faricy.net>
But, in a way, doesn't focal blur include aa?
Date: 20 Oct 2001 00:34:51
Message: <slrn9t1veu.ipl.ron.parker@fwi.com>
Couldn't you just use the first frame as a pigment for the sphere?
#local R=rgb 99;#local P=R-R;#local F=pigment{gradient x}box{0,1pigment{gradient
y pigment_map{[.5F pigment_map{[.3R][.3F color_map{[.15red 99][.15P]}rotate z*45
translate x]}]#local H=pigment{gradient y color_map{[.5P][.5R]}scale 1/3}[.5F
pigment_map{[.3R][.3H][.7H][.7R]}]}}}camera{location.5-3*z}//only my opinions
Date: 20 Oct 2001 01:49:16
Message: <3bd1105b@news.povray.org>
Trevor Quayle <Tin### [at] hotmailcom> wrote:
: I thought maybe something like that, until you said it wasn't an image map.
  I said that it wasn't an image map applied to the sphere and the sphere
is truely reflective and has just a pigment { rgb <1,.8,.6> }.
Date: 20 Oct 2001 01:50:46
Message: <3bd110b5@news.povray.org>
Christoph Hormann <chr### [at] gmxde> wrote:
: About what i said, just somehow the other way round... ;-)
  Yes, but the image map is not applied to the sphere (if you apply the image
map to the sphere, it doesn't look nothing like a reflection anymore).
Date: 20 Oct 2001 01:54:21
Message: <3bd1118d@news.povray.org>
Ron Parker <ron### [at] povrayorg> wrote:
: Couldn't you just use the first frame as a pigment for the sphere?
  Nope. If I did, then it wouldn't "reflect" its surroundings, but the
surroundings would be projected on the surface of the sphere, which is a
completely different thing (and looks like that).
  Also it would not work with any other object than the sphere. As I said,
the environment mapping technique works with other shapes as well.
