POV-Ray : Newsgroups : povray.binaries.images : A different approach to blurred reflection (PNG, 80kbu) Server Time
23 Jul 2026 06:12:21 EDT (-0400)
  A different approach to blurred reflection (PNG, 80kbu) (Message 23 to 32 of 42)
Subject: Re: A different approach to blurred reflection (PNG, 80kbu)
Date: 19 Oct 2001 12:55:02
Message: <3bd05ae6$1@news.povray.org>
Hmm... In the reflective sphere, you can see a highlight on the spheres in
front of it but yet from this angle, it doesn't appear like there is a
highlight on the back side of the front spheres.
Similarly with the green cylinder.  It has no highlights on this side of the
sphere but yet in the reflection, you can see a highlight.
Despite finding these errors, I have no clue how you did it.
Date: 19 Oct 2001 12:58:38
Message: <3bd05bbe$1@news.povray.org>
Did you use an inverse focal blur? i.e., blur where it would normally be
crisp clarity, and clarity where it would normally be blurry?
David
Date: 19 Oct 2001 13:14:28
Message: <3bd05f74$1@news.povray.org>
No, this is correct behavior.  Highlights aren't actual markings on the
objects but depend are a reflection of the light sources (and others), so
you shouldn't expect the hightlights in the reflection to show up in the
same place as they arfe on the real objects.
-tgq
"Richard Dault" <rda### [at] NOSPAMentredeacom> wrote in message
news:3bd05ae6$1@news.povray.org...
the
Date: 19 Oct 2001 13:19:18
Message: <3bd06096@news.povray.org>
The objects have no_reflection and the sphere is reflecting a bigger version
of the scene with focal_blur? (does it make any sense?)
Jonathan.
"Warp" <war### [at] tagpovrayorg> ha scritto nel messaggio
news:3bcfdd7a@news.povray.org...
>   I tried a different approach to blurred reflection. Didn't work
extremely
> well (which isn't a surprise knowing the algorithm...). Sorry for the PNG,
> but I didn't want JPG artifacts to destroy anything, and it isn't that
big.
>   Now you can start guessing how I did it. As you can see, I did not use
> antialiasing (I deliberately rendered the image without antialiasing to
show
> that I did not use the antialiasing trick). And yes, I rendered it
completely
> with POV-Ray 3.5beta in one run (ie, I did not use any external programs,
just
> POV-Ray and one single .pov file).
>   You can also watch for what is wrong in the reflection... Something that
> just cannot be corrected with this technique :)
> #macro N(D,I)#if(I<6)cylinder{M()#local D[I]=div(D[I],104);M().5,2pigment{
> rgb M()}}N(D,(D[I]>99?I:I+1))#end#end#macro M()<mod(D[I],13)-6,mod(div(D[I
> ],13),8)-3,10>#end blob{N(array[6]{11117333955,
> 7382340,3358,3900569407,970,4254934330},0)}//                     - Warp -
Date: 19 Oct 2001 13:23:17
Message: <3bd06185@news.povray.org>
I mean, it looks like that sphere is not reflecting those very objects (just
have a look to the wrong reflections of the checkered plane).
"JRG" <jrg### [at] hotmailcom> ha scritto nel messaggio
news:3bd06096@news.povray.org...
version
> Jonathan.
> extremely
PNG,
> big.
> show
> completely
programs,
> just
that
Warp -
Date: 19 Oct 2001 13:40:11
Message: <3bd0657b$1@news.povray.org>
Richard Dault <rda### [at] NOSPAMentredeacom> wrote in message
the
Speaking for myself, I think that those highlights that you
pointed out are correct.  The highlight in the reflection *is*
positioned differently than in the direct view, but that is as
it should be.
I'm still a pov novice, though, so I have no guesses as to
method.
Tom Bates
Date: 19 Oct 2001 14:02:50
Message: <oU7BIHA4lG07EwxC@econym.demon.co.uk>
Wasn't it Warp who wrote:
>  I tried a different approach to blurred reflection. Didn't work extremely
>but I didn't want JPG artifacts to destroy anything, and it isn't that big.
>antialiasing (I deliberately rendered the image without antialiasing to show
>that I did not use the antialiasing trick). And yes, I rendered it completely
>with POV-Ray 3.5beta in one run (ie, I did not use any external programs, just
My guess would be that there's a complicated optical illusion going on
here. Somehow the sphere is very much larger and further away than it
appears, and those reflections aren't reflections of the other objects,
but of a different set of similar, but larger, objects.
Could we be looking though an elliptical hole in the chequered plane?
The blur is achieved through focal blur.
There may be a small no_image sphere in the foreground which casts the
shadow.
Mike Williams
Gentleman of Leisure
Date: 19 Oct 2001 14:03:04
Message: <3bd06ad8@news.povray.org>
Yup, you're right.  I have no idea what I was thinking....  For a minute
there, my mind re-wrote the laws of physics.
"Trevor Quayle" <Tin### [at] hotmailcom> wrote in message
news:3bd05f74$1@news.povray.org...
> -tgq
Date: 19 Oct 2001 15:15:13
Message: <3bd07bc1@news.povray.org>
David Heys <sou### [at] gcinet> wrote:
: Did you use an inverse focal blur? i.e., blur where it would normally be
: crisp clarity, and clarity where it would normally be blurry?
  Uh?
  (Meaning "no" and "I don't understand what do you mean"... :) )
Date: 19 Oct 2001 15:18:22
Message: <3bd07c7d@news.povray.org>
Mike Williams <mik### [at] nospamplease> wrote:
: My guess would be that there's a complicated optical illusion going on
: here. Somehow the sphere is very much larger and further away than it
: appears, and those reflections aren't reflections of the other objects,
: but of a different set of similar, but larger, objects.
  Nope. The sphere is truely located where it appears to be and of the size
it appears to be. No trick there.
  But your idea sounds interesting anyways (although I'm not sure if it can
be achieved in practice...).
