POV-Ray : Newsgroups : povray.binaries.images : A different approach to blurred reflection (PNG, 80kbu) Server Time
23 Jul 2026 07:59:25 EDT (-0400)
  A different approach to blurred reflection (PNG, 80kbu) (Message 13 to 22 of 42)
Subject: Re: A different approach to blurred reflection (PNG, 80kbu)
Date: 19 Oct 2001 08:09:23
Message: <3bd017f3$1@news.povray.org>
The reflected image seems brighter.
-tgq
Date: 19 Oct 2001 08:32:21
Message: <3bd01d55@news.povray.org>
"Warp" <war### [at] tagpovrayorg> escreveu na mensagem
news:3bcfdd7a@news.povray.org...
>   You can also watch for what is wrong in the reflection... Something that
> just cannot be corrected with this technique :)
The reflective sphere's shadow does not seem to be blurred in the
reflection. Is that it?
Date: 19 Oct 2001 08:36:19
Message: <3bd01e43$1@news.povray.org>
"Ruy" <ruy### [at] hipernetcombr> wrote in message
news:3bd01d55@news.povray.org...
that
It shouldn't be, at least not very much compared to objects further from the
sphere.
-tgq
Date: 19 Oct 2001 09:06:07
Message: <3bd0253f@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3bd00adb@news.povray.org...
> Nekar Xenos <j-p### [at] citywalkcoza> wrote:
> : A reflective sphere inside a slightly larger transparent sphere filled with
> : scattering media?
>   Nope, nothing like that.
Do you think it might work with scattering media?
- Nekar
> #macro N(D,I)#if(I<6)cylinder{M()#local D[I]=div(D[I],104);M().5,2pigment{
> rgb M()}}N(D,(D[I]>99?I:I+1))#end#end#macro M()<mod(D[I],13)-6,mod(div(D[I
> ],13),8)-3,10>#end blob{N(array[6]{11117333955,
> 7382340,3358,3900569407,970,4254934330},0)}//                     - Warp -
Version: 6.0.282 / Virus Database: 150 - Release Date: 2001/09/25
Date: 19 Oct 2001 09:07:44
Message: <3BD025CA.21963239@atosorigin.com>
Warp wrote:
> Christoph Hormann <chr### [at] gmxde> wrote:
> : The reflection geometry looks a bit wrong,
>   You are right.
> : i would say an image map
> : applied to the sphere...
>   Nope. The sphere is truely reflective and has just a
> pigment { rgb <1,.8,.6> }
I would say :
each blurred object has an alter-ego slightly bigger, but
nearly transparent, with no_image and no_shadow,
maybe with an IOR, at the same place as the object.
Just like adding a glass surface to the blured object ?
Date: 19 Oct 2001 11:28:54
Message: <3bd046b6@news.povray.org>
: Do you think it might work with scattering media?
  I don't think so. You can only diminish the visibility of things with it,
not blur.
Date: 19 Oct 2001 11:29:53
Message: <3bd046f0@news.povray.org>
: I would say :
: each blurred object has an alter-ego slightly bigger, but
: nearly transparent, with no_image and no_shadow,
: maybe with an IOR, at the same place as the object.
: Just like adding a glass surface to the blured object ?
  Eh... No :)
Date: 19 Oct 2001 11:30:21
Message: <3bd0470d@news.povray.org>
Daniel Schwen <sch### [at] geocitiescom> wrote:
: Motion Blur?
  In pov3.5? I don't think so.
Date: 19 Oct 2001 11:31:47
Message: <3bd04763@news.povray.org>
Trevor Quayle <Tin### [at] hotmailcom> wrote:
: The reflected image seems brighter.
  That's not the problem with it. And it looks brighter because the sphere
has a non-black color (specifically rgb <1,.8,.6>).
Date: 19 Oct 2001 11:33:15
Message: <3bd047bb@news.povray.org>
Ruy <ruy### [at] hipernetcombr> wrote:
: The reflective sphere's shadow does not seem to be blurred in the
: reflection.
  That's how it should be. It's very close to the sphere and thus minimally
blurred.
  Blurred reflection means that objects which are closer are blurred less
than objects that are farther away.
