POV-Ray : Newsgroups : povray.binaries.images : Superb radiosity Server Time
23 Jul 2026 05:33:06 EDT (-0400)
  Superb radiosity (Message 11 to 15 of 15)
Subject: Re: Superb radiosity
Date: 13 Oct 2001 04:30:15
Message: <3BC7FB98.88E3B61@engineer.com>
Warp wrote:
> I have the feeling that POV-Ray still has some
> problems of radiosity being different from render to render...)
I have never noticed this but there still seems to be some
problems with scale and directional bias.
_____________
Kari Kivisalo
Date: 13 Oct 2001 04:49:34
Message: <3bc8001e@news.povray.org>
Kari Kivisalo <ray### [at] engineercom> wrote:
: While solving this one you introduced another problem.
: It's not realistic anymore :)
  Isn't that quite subjective?
  What makes it so unrealistic in your opinion?
Date: 13 Oct 2001 05:29:34
Message: <3BC8097F.6D820E96@engineer.com>
I ment it's not a simulation anymore when parameters
are bent at will. The image can _look_ realistic even
if it's not a realistic simulation :)
_____________
Kari Kivisalo
Date: 13 Oct 2001 05:34:57
Message: <3BC80AC1.A8FEF364@engineer.com>
Rune wrote:
> You made a good-looking and convincing workaround, but in cases where
> complete realism is vital, such a workaround is not good enough I think.
I believe Gilles too has employed this trick with great success.
You know, as long as the image looks good...
_____________
Kari Kivisalo
Date: 15 Oct 2001 02:13:30
Message: <3bca7e8a@news.povray.org>
"Jari Juslin" <zds### [at] ikifi> wrote in message news:3BC788B5.5A8A0B70@iki.fi...
> Kari Kivisalo wrote:
> > You just described a scene where dynamic range compression
> > should perform well. Another way is to design the lighting
> > to limited contrast ratio.
> Is there still no other program than full version of Photoshop that can
> do it? If so, is the algorithm how difficult or un-known or patented? If
> the algorithm is available somewhere, it shouldn't be very difficult to
> write a little app to do that compression.
I'm not sure if I understand you correctly. Corel PhotoPaint is free for Linux
from corel.com...
- Nekar
Version: 6.0.282 / Virus Database: 150 - Release Date: 2001/09/25
