POV-Ray : Newsgroups : povray.binaries.images : Problem with smooth heightfield Server Time
23 Jul 2026 05:32:14 EDT (-0400)
  Problem with smooth heightfield (Message 13 to 22 of 22)
Subject: Re: Problem with smooth heightfield
Date: 10 Oct 2001 17:13:43
Message: <3bc4ba07$1@news.povray.org>
"Christoph Hormann" <chr### [at] gmxde> ha scritto nel messaggio
news:3BC4B5EE.2E13A371@gmx.de...
> I know, but it's quite problematic, things have grown over the years and
> the structure of the program quite difficult to handle (in fact
> *structure* is seriously missing :-).
> I'm considering starting new from scratch, before i would like to release
> an experimental version of the current state, but there are serious
> problems with things becoming very slow after some time of use.  If i for
> example apply a filter 100 times it's getting slower and slower and i
> can't find the reason...
I lost you here... I know NOTHING about programming and similia so forgive
me if I say something silly: I always thought to h-f  utilities as image
processors which, through a series of fractal (or not) algorithms, alter (or
create from scratch) a bitmap in order to get a grayscale image usable in
POV. Once you apply a filter, you've got a new bitmap ready for other
filtering processes. No matter how many times you apply one or more filters,
every time the h-f utility treats the bitmap as if *it were the first time
it saw it*. Please tell me if I'm wrong.
Jonathan
> Christoph
> IsoWood include, radiosity tutorial, TransSkin and other
> things on: http://www.schunter.etc.tu-bs.de/~chris/
Date: 10 Oct 2001 17:24:25
Message: <3bc4bc89@news.povray.org>
"Simon" <sim### [at] 12movede> wrote in message
news:3bc4b707@news.povray.org...
> Hugo <hua### [at] post3teledk> schrieb in im Newsbeitrag:
> 3bc4b311@news.povray.org...
> > Thanks for the suggestion. I figured out myself that the 8 bit
resolution
> > was the problem. However, wouldn't it be possible to make an
"interpolate"
> > feature that make them appear as smooth as 16 bit?  For the user, it
would
> > be easier to stick with 8 bit bitmaps because many paintprograms don't
> > support 16 bit greys.. I don't have one, that do.
> You could use your image as a image_map in a function then you could
> use interpolate.
A 'smooth' keyword exists and from what I read no one mentioned that.  Only
good on 256 color image files though from what I know.
Bob H.
Date: 10 Oct 2001 17:32:05
Message: <3bc4be55@news.povray.org>
news:3BC49D3F.5D87E8EB@gmx.de...
> Here are three 128x128 16 bit png's:
> hf_pov35_16.png      generated with POV 3.5 beta 6
Yeah gee, that's what I was talking about before, chaotic.  Odd thing is
that a Targa file will look much the same way, except for not being
grayscale, and yet can render as a HF fine.  What I saw in the PNG-made HF
was partially okay and mostly not.  Chaotic mosaics mostly.
Bob H.
> hf_pov31_16.png      generated with POV 3.1
> hf_xxx_16.png        generated with other program
> Christoph
Date: 10 Oct 2001 17:32:38
Message: <3BC4BE76.ACE1E01E@gmx.de>
'smooth' in heightfield only interpolates the normal vectors.  Geometry is
not influenced.
Date: 10 Oct 2001 17:32:57
Message: <3BC4BE89.81EE0305@gmx.de>
That's the theory, but since it is an interactive program, there are
things done after the steps (like displaying the changed bitmap) and
somewhere there must be the problem...
Date: 10 Oct 2001 17:40:51
Message: <3BC4C05B.EACE2539@gmx.de>
Yes, it's the same pattern, but it's not chaotic, it's simply the less
significant byte, like the green channel in the tga file.
Date: 10 Oct 2001 17:41:32
Message: <3bc4c08c@news.povray.org>
So, theorically, if you apply a filter with Ategeros, save the output, then
reload it and apply a new filter the problem shouldn't sussist. I don't
think this is a *so serious* bug for a (first) beta release... :-)
BTW who would want to apply 100 filters alltogether?
Jonathan
news:3BC4BE89.81EE0305@gmx.de...
forgive
(or
in
filters,
time
> Christoph
Date: 10 Oct 2001 17:46:24
Message: <3BC4C1AC.6759C511@gmx.de>
If you restart the application in between too. ;-)
When doing an animation...
And a lot of erosion filters need to be applied a lot of times to get good
results.
Date: 10 Oct 2001 17:52:07
Message: <slrn9s9goa.a1t.ron.parker@fwi.com>
On Wed, 10 Oct 2001 21:10:55 +0200, Christoph Hormann wrote:
>This is a multi-part message in MIME format.
>--------------53C58C8C78D6DC69CDEC24AB
>Content-Type: text/plain; charset=us-ascii
>Content-Transfer-Encoding: 7bit
>Ron Parker wrote:
>> By all means.  I'd like to see what the difference is, since I haven't
>> seen any problems with the PNGs POV outputs.
Only one of those works correctly with pngtopnm.  The others all have the
words in the wrong order.  I suppose this could be a flaw in pngtopnm, but
I prefer to believe that it's a flaw in everything else.
#local R=<7084844682857967,0787982,826975826580>;#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
Date: 10 Oct 2001 18:08:18
Message: <3BC4C6CF.25AB0957@gmx.de>
Including all image viewers and paint programs that display the files with
8 bit?
Not to mention all past Povray versions and gforge etc.
