POV-Ray : Newsgroups : povray.binaries.images : Problem with smooth heightfield Server Time
23 Jul 2026 05:32:14 EDT (-0400)
  Problem with smooth heightfield (Message 11 to 20 of 22)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: Problem with smooth heightfield
Date: 10 Oct 2001 16:56:14
Message: <3BC4B5EE.2E13A371@gmx.de>
JRG wrote:
> Uh? Something like Ategeros? ;)
> Remember that there are people who are waiting for that.
I know, but it's quite problematic, things have grown over the years and
the structure of the program quite difficult to handle (in fact
*structure* is seriously missing :-).
I'm considering starting new from scratch, before i would like to release
an experimental version of the current state, but there are serious
problems with things becoming very slow after some time of use.  If i for
example apply a filter 100 times it's getting slower and slower and i
can't find the reason...
Date: 10 Oct 2001 17:00:55
Message: <3bc4b707@news.povray.org>
Hugo <hua### [at] post3teledk> schrieb in im Newsbeitrag:
3bc4b311@news.povray.org...
> Hi,
> Thanks for the suggestion. I figured out myself that the 8 bit resolution
> was the problem. However, wouldn't it be possible to make an "interpolate"
> feature that make them appear as smooth as 16 bit?  For the user, it would
> be easier to stick with 8 bit bitmaps because many paintprograms don't
> support 16 bit greys.. I don't have one, that do.
You could use your image as a image_map in a function then you could
use interpolate.
Date: 10 Oct 2001 17:13:43
Message: <3bc4ba07$1@news.povray.org>
"Christoph Hormann" <chr### [at] gmxde> ha scritto nel messaggio
news:3BC4B5EE.2E13A371@gmx.de...
I lost you here... I know NOTHING about programming and similia so forgive
me if I say something silly: I always thought to h-f  utilities as image
processors which, through a series of fractal (or not) algorithms, alter (or
create from scratch) a bitmap in order to get a grayscale image usable in
POV. Once you apply a filter, you've got a new bitmap ready for other
filtering processes. No matter how many times you apply one or more filters,
every time the h-f utility treats the bitmap as if *it were the first time
it saw it*. Please tell me if I'm wrong.
Jonathan
> Christoph
> IsoWood include, radiosity tutorial, TransSkin and other
> things on: http://www.schunter.etc.tu-bs.de/~chris/
Date: 10 Oct 2001 17:24:25
Message: <3bc4bc89@news.povray.org>
"Simon" <sim### [at] 12movede> wrote in message
news:3bc4b707@news.povray.org...
resolution
"interpolate"
would
> use interpolate.
A 'smooth' keyword exists and from what I read no one mentioned that.  Only
good on 256 color image files though from what I know.
Bob H.
Date: 10 Oct 2001 17:32:05
Message: <3bc4be55@news.povray.org>
news:3BC49D3F.5D87E8EB@gmx.de...
> Here are three 128x128 16 bit png's:
> hf_pov35_16.png      generated with POV 3.5 beta 6
Yeah gee, that's what I was talking about before, chaotic.  Odd thing is
that a Targa file will look much the same way, except for not being
grayscale, and yet can render as a HF fine.  What I saw in the PNG-made HF
was partially okay and mostly not.  Chaotic mosaics mostly.
Bob H.
> hf_pov31_16.png      generated with POV 3.1
> hf_xxx_16.png        generated with other program
> Christoph
Date: 10 Oct 2001 17:32:38
Message: <3BC4BE76.ACE1E01E@gmx.de>
'smooth' in heightfield only interpolates the normal vectors.  Geometry is
not influenced.
Date: 10 Oct 2001 17:32:57
Message: <3BC4BE89.81EE0305@gmx.de>
That's the theory, but since it is an interactive program, there are
things done after the steps (like displaying the changed bitmap) and
somewhere there must be the problem...
Date: 10 Oct 2001 17:40:51
Message: <3BC4C05B.EACE2539@gmx.de>
Yes, it's the same pattern, but it's not chaotic, it's simply the less
significant byte, like the green channel in the tga file.
Date: 10 Oct 2001 17:41:32
Message: <3bc4c08c@news.povray.org>
So, theorically, if you apply a filter with Ategeros, save the output, then
reload it and apply a new filter the problem shouldn't sussist. I don't
think this is a *so serious* bug for a (first) beta release... :-)
BTW who would want to apply 100 filters alltogether?
Jonathan
news:3BC4BE89.81EE0305@gmx.de...
forgive
(or
in
filters,
time
> Christoph
Date: 10 Oct 2001 17:46:24
Message: <3BC4C1AC.6759C511@gmx.de>
If you restart the application in between too. ;-)
When doing an animation...
And a lot of erosion filters need to be applied a lot of times to get good
results.
