POV-Ray : Newsgroups : povray.binaries.images : is this a bug? (~14k) - iso35_01.jpg (1/1) Server Time
16 May 2026 03:45:27 EDT (-0400)
  is this a bug? (~14k) - iso35_01.jpg (1/1) (Message 1 to 10 of 25)
Subject: is this a bug? (~14k) - iso35_01.jpg (1/1)
Date: 4 Oct 2001 20:50:55
Message: <3bbce60b.1409922@localhost>
Been playing with isosurfaces in 3.5 and I am wondering
if the attached image is a bug or not.  It happens using
f_noise3d and with f_noise_generator using generator 0 or 1.
Using f_noise_generator with a generator of 2 does not produce
the problem.
	.pov source posted on povray.scenes.text-files
Pete
Download 'iso35_01.jpg' (14 KB)
Preview of image 'iso35_01.jpg'
Subject: Re: is this a bug? (~14k) - iso35_01.jpg (1/1)
Date: 4 Oct 2001 21:12:18
Message: <MPG.162727bd7171df9b98969c@news.povray.org>
In article <3bbce60b.1409922@localhost>, PeterC@nym.alias.net.almost
says...
This is a typical problem resulting from an insufficient max_gradient.
Not a bug.
Lutz-Peter
Date: 5 Oct 2001 02:20:42
Message: <3BBD520F.DA8D9449@gmx.de>
> the problem.
Sorry, but sometimes i wonder why we put much work into the documentation
if it's not read.
Reading the corresponding chapters from the docs when working on a new
feature is really a good idea, nearly everytime i read a chapter i
recognize something new or what i forgot.
Date: 5 Oct 2001 04:19:55
Message: <3BBD6CAA.3169E1B4@home.com>
hmmm looks like a silhouette of a phoenix
> the problem.
> Pete
Date: 5 Oct 2001 09:50:11
Message: <3bbdba92@news.povray.org>
http://www.students.tut.fi/~warp/povVFAQ/languageVFAQ.html#isosurfacebug
Date: 5 Oct 2001 12:02:18
Message: <3bbdd98a@news.povray.org>
Warp schrieb in Nachricht <3bbdba92@news.povray.org>...
Wouldn't it be good to mention "accuracy" in this VFAQ-Answer, too?
Marc-Hendrik
Date: 5 Oct 2001 12:53:27
Message: <3BBDE65F.62377969@gmx.de>
For what reason? I don't remember many people having problems with that,
and the meaning is pretty self explanatory.
Date: 5 Oct 2001 14:07:12
Message: <3bbdf6d0@news.povray.org>
Christoph Hormann schrieb in Nachricht <3BBDE65F.62377969@gmx.de>...
Because in my opinion those artefacts are not always caused by an inaccurate
max_gradient. Esp. those where big parts are missing or disappearing seems
to me more like an inaccurate accuracy then a max_gradient problem (which
are those black spots like in the scene the thread started with). I may be
wrong in this, but that's how I experienced it in the past.
In addition max_gradient and accuracy seems not to be independent if I
remember an article of the original isosurface-patch writer some weeks ago
correct (unfortunately it was in one of those "Hey folks!"-threats and I
can't find it). While max-gradient seems to determine the "step-width" of
the algorithm, accuracy tells when to stop to look for an ray-intersection.
Is this wrong?
Of course, max-gradient is far more often the problem, which leads to those
artefacts.
Marc-Hendrik
Date: 5 Oct 2001 15:17:35
Message: <3BBE0827.BE2E41F3@gmx.de>
Accuracy just influences how small details are visible, lower values lead
to more detailed surfaces and usually require higher max_gradient.  Just
try it, the default value of 0.001 is quite low, if you use for example
0.1 on a RMF function isosurface, you will get a not very detailed
surface.
Date: 5 Oct 2001 16:27:24
Message: <3bbe17ac@news.povray.org>
Christoph Hormann schrieb in Nachricht <3BBE0827.BE2E41F3@gmx.de>...
>surface.
While you are right that higher accuracy values decrease the level of
detail, it has other influences, too.
I just tried it with an old scene and attached the resulting image. I
increased the accuracy value by far (0.1 instead of 0.000001) and left
anything else the way it was (after converting to 3.5 language of course).
Pov reports, that I should decrease max_gradient to lower rentertime  (5.141
instead of 6). In my opinion that black part is one of those isosurface
artefacts.
Marc-Hendrik
Download 'landschaft low acc.jpg' (12 KB)
Preview of image 'landschaft low acc.jpg'
