POV-Ray : Newsgroups : povray.binaries.images : is this a bug? (~14k) - iso35_01.jpg (1/1) Server Time
3 Mar 2026 01:59:37 EST (-0500)
  is this a bug? (~14k) - iso35_01.jpg (1/1) (Message 21 to 25 of 25)
Subject: Re: is this a bug? (~14k) - iso35_01.jpg (1/1)
Date: 9 Oct 2001 18:45:54
Message: <3bc379ec.1376991@localhost>
On Fri, 5 Oct 2001 03:14:04 +0200, Lutz-Peter Hooge <lpv### [at] gmxde>
wrote:
>In article <3bbce60b.1409922@localhost>, PeterC@nym.alias.net.almost
>says...
>> 	Been playing with isosurfaces in 3.5 and I am wondering
>> if the attached image is a bug or not.
>This is a typical problem resulting from an insufficient max_gradient.
>Not a bug.
>Lutz-Peter
Thanks for the help.  Since I've never used Mega-POV, this whole
isosurface thing is completely new to me.
Pete
Date: 9 Oct 2001 18:45:55
Message: <3bc37787.763746@localhost>
On Fri, 05 Oct 2001 08:24:15 +0200, Christoph Hormann
<chr### [at] gmxde> wrote:
--snippage--
>Sorry, but sometimes i wonder why we put much work into the documentation
>if it's not read.
Rather than playing dump-on-the-newbie as well as Oh-So-High-And
-Mighty, you *could* have referred me to the relevent section of the
documentation that I glaringly overlooked.
In other words, you expended the effort to reply to my posting
but contributed nothing.
Fortunately, others on these newsgroups with a less negative
frame of mind have posted helpful and informative posts.
Good day
Date: 10 Oct 2001 04:03:17
Message: <3BC400AF.4BC49C2E@gmx.de>
Sad you see it that way, looking for 'isosurface' in the help index will
bring you immediately it the relevant sections (isosurface
object/tutorial) and there you will find both the information needed to
solve the problem and the hints to understand it.
I do not like this attitude.  If you don't appreciate the way i answered
your question that's ok, but you should not expect that everytime you have
a question someone will directly give a solution for it.  It was perfectly
possible to find a solution from what i answered.
Date: 10 Oct 2001 05:47:43
Message: <3bc4193f$1@news.povray.org>
Christoph wrote:
>Marc-Hendrik Bremer wrote:
>> Wouldn't it be good to mention "accuracy" in this VFAQ-Answer, too?
>For what reason? I don't remember many people having problems with
>that, and the meaning is pretty self explanatory.
There is a plobrem on "accuracy" if the thickness of the isosurface
is thinner than the accuracy value.  For example, following isosurface
will generate artifacts(artefacts).
isosurface {
        function {-0.002+abs(-3.0+f_r(x,y,z))}
        contained_by { sphere { 0, 3.1 } }
        accuracy 0.01
Thus if the isosurface has a fine-structure, the "accuracy" value
should be less than the size of the fine-structure.
R. Suzuki
Date: 10 Oct 2001 06:02:04
Message: <3BC41C9B.BB3CDF94@gmx.de>
> isosurface {
>         accuracy 0.01
Yes, it seems quite natural, same happens when tesselating such
isosurfaces.  I think there is nothing you can do about it.
BTW, you can create nice moire-like patterns with that method. :-)
