POV-Ray : Newsgroups : povray.binaries.images : Not a Sphere (91K) Server Time
12 Nov 2026 16:24:13 EST (-0500)
  Not a Sphere (91K) (Message 11 to 14 of 14)
<<< Previous 10 Messages Goto Initial 14 Messages
Subject: Re: Not a Sphere (91K)
Date: 14 Oct 2001 18:33:46
Message: <3BCA125F.CABCEAD8@hotmail.com>
Tor Olav Kristensen wrote:
> #declare Step = 360/60;
> #declare Cx = 0;
> #while(Cx < 180)
>   sphere {
>     <0, 1, 0>, 0.06
>     rotate Cx*x
>     texture { T_Gold_3C }
>   #declare Cx = Cx + Step;
> #end // while
I just also wanted to mention
that the code below does the same
as the above code.
#declare MySphere =
sphere {
  <0, 0, 0>, 0.06
#declare Cx = 0;
#while(Cx < 180)
  object {
    MySphere
    translate y
    rotate Cx*x
  #declare Cx = Cx + 6;
#end // while
If you like, you can write
rotate <Cx, 0, 0> instead of
rotate Cx*x
(Note that when using other
textures, that are not the same
at every point in 3D-space, the
result from the two examples
above will become different.)
Tor Olav
Date: 26 Oct 2001 03:43:25
Message: <3BD9127D.2C0DF43A@pobox.com>
> "Arie L. Stavchansky" <nat### [at] hotmailcom> wrote
> > I know it is alot to ask, but can you please explain this code and
> > algorithm in English?  I don't have a very strong math background
> > and would like to understand how it is done.  This is amazing stuff!
Bill DeWitt wrote:
> RTFM
>     The short version is this.
> "#declare Cx" means create a variable
> "#while" means start a conditional loop
> "box" means make a box at the location set up by the math
> "#declare Cx = CX + Step" increments the variable
> "#end" sends it back to the #while until the condition is fulfilled
>     Everything else is gravy.
Arie asked for help with the math, not the programming syntax.
Anton Sherwood
Date: 26 Oct 2001 04:49:01
Message: <3bd9237d@news.povray.org>
"Anton Sherwood" <bro### [at] poboxcom> wrote in message
news:3BD9127D.2C0DF43A@pobox.com...
    Seems to me he asked for both. But since you went to such great lengths
to provide help for the math, I saw that all that was left needing was help
with the code. Together we made a great team, don't you think.
Date: 27 Oct 2001 00:27:35
Message: <3BDA393A.E098B8EF@pobox.com>
> lengths to provide help for the math, . . .
it must be said: that was TOK, not me
Anton Sherwood
